Equalizer unit.
Old Apr 30, 2010 | 02:53 PM
stock to the bone's Avatar
Equalizer unit.
is it possible to install an equalizer unit in the TL without overriding the factory stereo control unit( using the original system but add more spice to the sound from the equalizer unit)? I just wanna add a little more customization to the Tl' sound system. Have anyone done it?
for example, a unit looks like this installed in the TL
EDIT: please move this thread to the 3G section.
Last edited by stock to the bone; Apr 30, 2010 at 02:54 PM. Reason: wrong section.
Old Apr 30, 2010 | 03:52 PM
DiamondJoeQuimby's Avatar
Codename Duchess
you could run something like an audio control DQS w/ the remote DDC and just run the 6 channels of output from the radio to the DQS then out to the factory amp. FWIW, something like that slider eq would be ghetto as hell. Not to mention noisy as hell. Did I mention ghetto?
Old Apr 30, 2010 | 09:48 PM
^ im sorry, can you rephrase what you said above to make it simplier. i am a complete newb to car electrical components. And i plan to install the eq unit inside the glove box compartment.
Old Apr 30, 2010 | 11:54 PM
D'sNBP's Avatar
hates potatoville
Bro I had that exact model eq in a Ford Escort back in 1994, no offense. It's very old and HUGE. I'm sure it wouldn't even fit in the glove compartment at all. Look around online and you'll find some that are far better than the one pictured. Hopefully someone who already have an eq in their whip will chime in to help you.
Old May 1, 2010 | 12:39 AM
princelybug's Avatar
LIST/RAMEN/WING MAHSTA 짱
Don't do it.
Old May 1, 2010 | 03:16 AM
oemplusmore's Avatar
Post #2 was the most accurate info for adding a eq between the stock head unit and amp but you might be better off with an Audio Control 3.1 or 4.1 in the glove box. Also, you would need an experienced installer to wire everything neatly and correctly.
If are in the quest for better sound from your stock stereo there are far easier alternatives that would yield better results. just swapping out the front speakers and tweeters will do this. you probably realize the midrange is real muddy sounding and the highs are kinda bright. Search the forums there are drop in alternatives that people have had success with, from infinty i believe. Our stock stereo is a good starting point. it's everything else that can be replaced for better sound.
Soul_Deamon
Nov 13, 2018 04:44 PM
jpadilla
3G RLX (2013+)
Nov 18, 2017 07:13 PM
Sep 17, 2015 08:57 PM
Sep 17, 2015 10:09 AM
mav888
1G RDX (2007-2012)
Sep 8, 2015 11:49 AM
