3G TL Navi audio not working
Old Jul 3, 2021 | 10:43 PM
eg22591's Avatar
7th Gear
Pressing the button for the audio on the Navi does nothing instead of taking me to the audio menu. Every single other button on the Navi works besides the audio one. The speakers work fine and when I checked in the diagnostic screen the audio button does seem to register when I press it. I don’t know why it’s not working and it’s been bothering me for a while. I can’t use the aux or radio and none of the other audio related buttons work. It’s a 07 TL type s
Old Jul 10, 2021 | 10:35 AM
pohljm's Avatar
I am unsure what you think pressing the Audio button is supposed to do? It takes you to the audio settings. I am not sure I understand your issue
Old Jul 10, 2021 | 05:28 PM
eg22591's Avatar
7th Gear
That’s the thing when I press the audio button nothing happens it doesn’t take me to the audio settings. I don’t know what’s wrong with it
Old Jul 10, 2021 | 10:25 PM
vpasla1's Avatar
What about the audio buttons on the steering wheel, like mode, channel, etc? Does mode allow you to change modes?
Old Jul 11, 2021 | 12:58 AM
eg22591's Avatar
7th Gear
Nothing happens when I pressed those buttons. I can’t do voice command either because HFL was disabled by the previous owner. I tried disconnecting and reconnecting the battery but nothing happened.
Old Jul 11, 2021 | 01:26 PM
pohljm's Avatar
Sounds like the HU to me, that is where those functions are handled. obviously not just a bad switch or others would function.
Old Jul 11, 2021 | 09:17 PM
eg22591's Avatar
7th Gear
What’s the HU?? Every other button on the Navi like the menu and map/guide works fine.
Old Jul 11, 2021 | 09:20 PM
Head Unit
Old Jul 12, 2021 | 05:50 PM
eg22591's Avatar
7th Gear
Is there anyway to fix the issue? I really miss playing music in the car :/
Old Jul 12, 2021 | 07:16 PM
csmeance's Avatar
when you undid the battery, how long was it unplugged for? It should have asked for a security code. If not, radio might be thinking it's stolen and not working. You'll either have to unplug the negative cable for much longer or send the radio in to pioneer for repair.
Old Jul 12, 2021 | 09:45 PM
eg22591's Avatar
7th Gear
About three weeks ago the battery was unplugged for probably 20-30 minutes because I went to go buy a new battery. After I saw the audio wasn’t working I unplugged the negative cable for about a minute and then plugged it back in. It did ask for a code and I managed to get one from Acura and it was correct. I’ll try leaving the negative cable unplugged for much longer then and see if it works :/
Old Jul 13, 2021 | 10:10 PM
eg22591's Avatar
7th Gear
So i unplugged the negative cable for about 15 minutes and plugged it back in. Asked for a code and after that it still won’t let me into the audio settings menu. Is there any other fix or is my only option to send it in for repair?
Old Jul 13, 2021 | 10:17 PM
i still dont understand the issue
AZ Matt
Mar 26, 2018 10:54 PM
TL.Driver
28
Apr 21, 2016 07:18 AM
chilimost
Jan 2, 2010 11:39 PM
scooter9802
Apr 17, 2009 10:05 PM
msterling21
Jan 27, 2006 01:30 PM
