30 Pin blutooth connector.
Old Dec 1, 2012 | 06:11 PM
bull3t_six's Avatar
So I bought my TL used a few months back and I noticed in the glove box that there is an iPod/iPhone connector sitting in there. It seems to be running behind the nav unit. I can use it thru the XM mode with my phone plugged into it, but controlling is thru the radio is kind difficult. I bought this
Amazon Amazon
blutooth adapter and plugged it into the wire in the glove box, but im not getting audio. Phone is pairing just fine, but the radio display still says "no Ipod". Has anyone used one of these successfully before?
Old Dec 3, 2012 | 03:37 PM
geekybiker's Avatar
I looked into those a bunch this summer. Some of these sort of things do work, but they always seem to have issues. The cheap ones like you got tend to not pass the steering wheel controls. The better ones still have pairing issues. I haven't heard of anyone getting a satisfactory experience out of the 30 pin dongles. Most folks seem to get the blackberry music gateway. Its about $50, pairs well, but only has a headphone plug out. That'll go right to your aux port.
Old Dec 5, 2012 | 08:43 PM
bull3t_six's Avatar
That's the thing, I have the. 06 TL with nav, so I don't have an aux in. Right?
Old Dec 6, 2012 | 10:37 AM
geekybiker's Avatar
Right, but that 30 pin cable means that someone installed a isimple, or similar gateway that uses the XM radio. If you find the box it should have a port for a regular AUX cable as well. I have the isimple, and all the others are pretty similar.
Old Dec 6, 2012 | 11:02 AM
geekybiker's Avatar
Oh one thing to try as well- When you switch from any source to XM you have a few seconds to change the source on an isimple. Change to radio then to xm, use the tuning knob on the right to change source. It'll flash xm001,xm002, etc then flash the source. Yours is probably set to ipod. Try the other settings. I think AUX might work for you. I think there are 3-4 choice. Just keep playing back and see if any of them work. The source change disables after a few seconds, so don't forget to flip back to radio/cd then to xm if you want to try again.
Old Dec 6, 2012 | 02:53 PM
pohljm's Avatar
if its an ISimple it will be aux2 if you want to use the mini jack
Old Dec 6, 2012 | 03:37 PM
geekybiker's Avatar
The 30pin cable has two modes though. One is ipod, the other is for other devices. Maybe his bluetooth dongle will work on the other mode so he doesn't have to buy anything?
Old Dec 8, 2012 | 12:38 PM
bull3t_six's Avatar
This worked! Thank you so much man, I set it to AUX1. I had no idea that I could even switch inputs like that. I thought I had lost xm while isimple was installed too. Hopefully anyone who wants a wireless option with the 06 and older will see this thread.
cycdaniel
Dec 17, 2019 10:58 AM
Soul_Deamon
Nov 13, 2018 04:44 PM
copmagnet82
4G TL Problems & Fixes
Jun 29, 2016 08:09 AM
xsilverhawkx
Sep 28, 2015 06:51 PM
ivegotthenav
Sep 11, 2015 07:51 PM
