What changes should be done to a new to me used engine?
Old Jan 5, 2021 | 02:32 PM
Glorygang600's Avatar
Dealing with a used Honda engine j35a6
I've purchased a water pump kit, serpentine belt, new ngk sparkplugs , and pcv valve
Should I worry about valve cover gaskets and should I or shouldn't I do a valve adjustment while I'm at it? or anything further for that matter such as head gasket and or rear main seal?
Old Jan 5, 2021 | 05:28 PM
I mean since it's already off why not do all of the seals? RMS, head gasket, cam and crank seals. re-seal the oil pan
Old Jan 5, 2021 | 07:10 PM
csmeance's Avatar
do all the seals that you can including the oil filter housing, RMS, valve covers, etc.
Old Jan 5, 2021 | 08:36 PM
horseshoez's Avatar
Latent car nut
I second and third the above two recommendations.
Old Jan 6, 2021 | 07:54 AM
08KBP_VA's Avatar
I fourth the above recommendation PLUS...I see you state WP kit, you mean TB kit? If not then I would do the TB and check all the pulleys.
Thinking bigger pic, I would also check your mounts, if you gotta pull motor easy swap of mounts depending on your mileage
Old Jan 6, 2021 | 01:08 PM
860_TypeS's Avatar
All of the above, plus if you ever plan on doing HFPCs or PCDs this would be the ideal time. Or even if you need to/want to replace the O2 sensors on stock precats. Big +1 on motor mounts.. Especially that rear mount.
Would be a good time to paint valve covers and intake manifold too if it's all gonna be off to adjust valves, if that's something you're intersted in.
Old Jan 6, 2021 | 02:22 PM
E39's Avatar
E39
Me personally, I would only do the cam and crank seals if and only if they are leaking. I would however do the rear main seal, cam cover cap seals, valve cover gaskets, oil pump reseal, and oil pan reseal.
Old Jan 6, 2021 | 07:47 PM
horseshoez's Avatar
Latent car nut
A lot of folks say that, dealership service departments included; that said, many of us have experienced oil leaks from the cam and crank seals somewhere around the 150,000 mile mark; including both of my J-Series engines.
Said another way, do the seals now while the engine is out of a car.
Relyk
18
Aug 28, 2022 10:31 AM
Mickeddie
6G TLX (2021+)
Dec 31, 2020 01:38 PM
Darksyne
Jun 4, 2018 11:40 AM
twentynothing
1G TL (1996-1998)
Jun 7, 2010 12:03 AM
3.0_Bullet
Jan 20, 2003 01:47 PM
