Replace Rear Struts or nah?
Old Oct 16, 2018 | 09:31 AM
zoopzop's Avatar
Two shops told me that "due to the mileage" (I'm at 181k) my rear struts need to be replaced. One shop told me that the rear tires "looked to be wearing a little unevenly". I don't hear anything coming from the rear and the car rides well. Should I bother replacing these or can they wait until 190k or 200k miles? I'm going to do the work myself, just wondering if they tires are already "a little unevenly worn" if it's worth it to replace the rears now or just wait until 10 or 20 thousand more miles.
Old Oct 16, 2018 | 09:57 AM
DMZ's Avatar
DMZ
Head a da Family
2 Questions:
1 - Does each corner of the car go right back into position when you bounce on it?
2 - Are they leaking?
An answer of NO to both questions means leave them alone and save your money. I've got 295K miles and still have the original shocks/struts.
Shops are out to sell work!
Old Oct 16, 2018 | 11:08 AM
well show us what your tires look like so we can make a better determination
zoopzop's Avatar
Not leaking.I went out and pushed down on the back of the car it didn't bounce at all, just went back to position. Phew! Saves me some money lol. One shop told me that the ball joint is bad on one side. Can I test for that while I'm replacing the front struts? (passenger side piston is leaking, so, that one is done)? Is it an up and down wiggle or a side to side wiggle lol?
Old Oct 16, 2018 | 11:09 AM
You may just need an alignment.. if the tires are wearing bad and cupping or theres significant negative camber then maybe you do need to replace them sooner rather than later.. or just keep buying new tires.
Old Oct 16, 2018 | 12:25 PM
zoopzop's Avatar
Here's some photos of the tires
Old Oct 16, 2018 | 12:30 PM
zoopzop's Avatar
Here's the pictures of the tires:
Old Oct 16, 2018 | 01:32 PM
they don't look too bad, possibly just minor negative camber.. Do an alignment if you haven't yet and i bet you'll see you'll need to zero our the toe and just minor (maybe -1.2 - -1.7 in camber.
Old Oct 16, 2018 | 01:40 PM
zoopzop's Avatar
I'll post whatever the shop does xD what am I not seeing? To me they look like normal tires in good shape
Old Oct 17, 2018 | 04:14 PM
stevemk07's Avatar
My old tl would not go back into spec due to camber. I suspect it was due to the old springs not having as much push as they used to but I may be wrong... Ate my tires pretty quick. Your dont as bad as mine were though.
Old Oct 17, 2018 | 07:20 PM
TSX-S2000's Avatar
I thought camber was not adjustable on our cars.
Old Oct 18, 2018 | 09:06 AM
djw88's Avatar
as long as the ride isn't bouncy and isn't making a clunking noise just get an alignment.
on the other hand spending $260 on new loaded rear struts and not having to deal with them for another 100k miles isnt a bad idea, they are cheap.
Old Oct 18, 2018 | 10:59 AM
It's not. By replacing the struts, you're bringing the suspension back to "factory" level which helps alleviate the negative camber.
Old Oct 19, 2018 | 04:40 PM
zoopzop's Avatar
I ended up just doing the front struts. They were no where near as hard as I thought they'd be to do and I'm kicking myself for the literally thousands of dollars I've spend having shops do that sort of piddly shit. The outer tie rods were another story. Couldn't get those off. Paid a back yard guy to come and do it. He only did the one side. Now I shall pay another back yard guy to do the other side and hope the alignment isn't so fucked I can't make it to the shop lmfao.
JterrorC
19
Jun 26, 2009 06:11 PM
dark inspire
21
Mar 14, 2005 04:03 PM
Dafmann
Jul 14, 2002 07:44 PM
mblock66
Mar 25, 2002 01:07 PM
