The Official "Does This Fit My Car?" Thread
#721
94 DC4 RS LSV/Turbo
as always you're pushing the limits on what is even possible on other cars... but like I said on aim, you should be good, it is just .5" wider than the widest someone non fender flared has gone... the only other with x11 is rodney... which is why I mentioned ask him... but I am pretty certain you are good
ps. wheel whore
ps. wheel whore
#722
Exhaust stuff
Year: 2004
Model: Base
Color: Anthracite Metallic
Item you would like fitment to be verified:
ATLP J-Pipe
ATLP Racepipe
Greddy EVO2 Catback
Will all of these just be an easy bolt on and off type thing? Also will I pass inspection with all of these mods? Is the hole in the bumper big enough for the muffler tips? Lastly, what is the estimated HP gain from all these mods together? Your answers will be valued quite well!!!
Model: Base
ATLP J-Pipe
ATLP Racepipe
Greddy EVO2 Catback
#724
Hello,
I don't know if this question was posted before. Forgive me if it has been posted in the past....
Year: 2005
Trim: Base
Color: SSM
Item you would like fitment verified:
I've noticed that the 07-08 TLs have color keyed mud guards. My TL has the black ones... I just wanted to know if the mud guards from 07-08 would fit on the 05 TL and if the paint colors are similar enough to match.
Thanks.
Year: 2005
Trim: Base
Color: SSM
Thanks.
#725
94 DC4 RS LSV/Turbo
Hello,
Year: 2005
Trim: Base
Color: SSM
Thanks.
Year: 2005
Trim: Base
Color: SSM
Thanks.
you will fail a visual inspection but you will pass knox
#727
IDK if texas has a visual inspection. I don't think they do. But if so does that mean my CAI will cause me problems. The inspection people usually don't look under the hood. But does that also mean every time I want to pass inspection I have to swap the exhausts?
#729
2004 ssm acura tl
Year: 2004
trim: tl base
Item you would like fitment verified: will a 2007 2008 type s bumper fit my 2004
trim: tl base
#731
94 DC4 RS LSV/Turbo
cai is not part of inspection (except in california it requires a carb sticker)
#732
If I get the ATLP High Flow Catalyst will I pass emissions? Or if I have the Racepipe do I need to just swap it with the stock catalyst every year for inspection? Is the high flw catalyst any different in performance?
#733
94 DC4 RS LSV/Turbo
Well the high flow cat should def pass a simple visual inspection, I'd believe
But if yougot the racepipe and installed the heatshield it would pass also
#734
ok, so i can use the stock heat shield and i will pass emissions? that is what i am concerned about, not the visual inspection. texas doesnt have a visual inspection.
#735
94 DC4 RS LSV/Turbo
you will pass
I'm pretty sure texas doesn't dyno cars that are this new... So they probably only plug into ur obd port... 3rd cat has no sensors and even if they did dyno your car it would pass since the gasses pass thru a pair of cats prior to the 3rd cat...
Glad I could help
Glad I could help
#736
you will pass
Glad I could help
Glad I could help
#737
Year: 2004
Model: Base
Item you would like fitment to be verified: 2003 TL Type S Rotors
Part Numbers appear to be the same Part# 45251-TA6-A00
Model: Base
#739
https://acurazine.com/forums/3g-tl-audio-bluetooth-electronics-navigation-94/completed-non-navi-factory-navi-conversion-600316/
#740
94 DC4 RS LSV/Turbo
you can easily get all the parts you need from ebay to get a factory nav in your car... for more info see the Audio, Bluetooth, Electronics & Navigation section of this forum
#742
Year: 04
Trim: base
Color: antracito
Item you would like fitment verified:i heard that the full coilover of the 03-05 accord fits on the 04-06 tl base ,,, wanted to find out before buying it
Trim: base
Color: antracito
#743
94 DC4 RS LSV/Turbo
no problem
and at the same time ... you will have to modify the strut mount and or drill extra holes on your actual car... it has been done before
do I suggest it... no... contact excelerateperformance.com
he should be able to outfit you with a proper coilover setup of your choice
#746
Former Whyner
https://acurazine.com/forums/3g-tl-audio-bluetooth-electronics-navigation-94/cluster-acura-tl-07-fit-acura-tl-04-yes-no-747809/
#749
07-08 Blue foot lights
I'm probably not the first to ask this, but searching hasn't helped, and this thread is now too long to go through post by post:
Year: 04
Trim: Base Non-nav
Color: DMM (Not that it matters)
Item you would like fitment verified:07-08 blue footwell light system.
At oemacuraparts I found "34760-S3V-A01 LIGHT ASSY., FOOT" for both the driver and passenger side, but no indication of how they are mounted and powered. I have the 04 service manual, but of course it doesn't have footwell lights.
Year: 04
Trim: Base Non-nav
#750
94 DC4 RS LSV/Turbo
save some time... do them using led's of your choice in the footwell
pretty sure you don't want them to be on ALL THE TIME... so you wire them to the courtesy lights on ur door, or to the dome light... alternatively if you want them on all the time you'd have to wire them to the light inside of the center console...
it's been done before, wish I could find the thread...
#751
Year: 2004
Trim: 6-speed manual without nav
Color: Silver
2007-2008 front bumper. I also want the yellow HID Fog lights. Or is it easier if i just get the dealership to cut out the front grill and put in the type s grill and put the fogs in or should i just buy the whole 2007-2008 bumper?
Color: Silver
#752
94 DC4 RS LSV/Turbo
Year: 2004
Color: Silver
Color: Silver
yellow hid foglights would be 3000k
dealer is a ripoff... you can use the type s lower grills should be simple
#753
http://oemacuraparts.com/partlocator...layCatalogid=0
btw is there a difference between Type-S grills and just regular 07-08 grill?
also could u please give me a link of where i can get the fog lights and the bulbs?
#755
94 DC4 RS LSV/Turbo
foglights and bulbs you can get on ebay... the difference between type s and non is is as follows
S
/0----| ACURA |----0\
non-s
\0----| ACURA |----0/
come to think of it you have to use the non s grills, the type s grills won't work with the opening
S
non-s
#757
Year: 05
Trim: base
Color: white
i was looking into some wheels for my car and i came into conclusion that i love these rims for the price and all.
exe image
i was wondering if the 19x8.5 fit the front with 35 offset
and the back with 19x9.5 with 40 offset
i have tein ss dropped almost all the way down.
i was wondering if it will fit and what will be my best choices in terms of tire size and fittment.
thanks in advance
Trim: base
Color: white
exe image
thanks in advance
#758
94 DC4 RS LSV/Turbo
Year: 05
Trim: base
Color: white
exe image
thanks in advance
Trim: base
Color: white
exe image
thanks in advance
fr
235/35-19
or
245/35-19
rr
245/35-19
255/30-19
