Need QUICK help .. RSB install
Old Nov 25, 2007 | 01:20 PM
BLACKURA_NY's Avatar
I have car ADD
ok, so i start to do my RSB install today (great bday gift) and as i remove the bolt holding the end link to the bushing.. it doesnt come out.. it loosens ALOT, then the rubber looking part inside the "bushing ?? " came out. so when i try unscrew the bolt, the rubber part keeps twisting..
did i fuck something up ??
Old Nov 25, 2007 | 03:15 PM
01tl4tl's Avatar
yep=broken, very common prob
try vise grips to hold it still
Old Nov 25, 2007 | 04:18 PM
I have car ADD
i used something grip the rubber, got the old bar out, and new bar in...
should the bar make some mild bangs and thumps while it settles in?? nothign too loud or noticeable, but i can hear it
Old Nov 25, 2007 | 04:28 PM
ballinfizzle89's Avatar
FizzyStatus!
Did you tighten it up all the way? JJ had the same problem, but he said the bolts were a litle loose.
Old Nov 25, 2007 | 05:42 PM
u1arunit's Avatar
Car Guy
It should not make any noise. Did you say that the end link ball stud came out of the socket? If so that is probably the noise you hear.
Old Nov 25, 2007 | 07:27 PM
I have car ADD
it never came COMPLETELY out of the socket just a little bit....im gonna re-tighten tomorrow after i've driven a few miles..
Old Nov 25, 2007 | 07:38 PM
Bearcat94's Avatar
AZ Community Team
Which RSB?
Progress 24mm?
Old Nov 25, 2007 | 07:45 PM
u1arunit's Avatar
Car Guy
Even if it's only loose it can make noise. Let us know how it goes after you've checked all the bolts again.
Old Nov 25, 2007 | 08:11 PM
aznbo187's Avatar
Loosen all the bolts, and align it correctly again. See if that helps.
Old Nov 25, 2007 | 09:13 PM
csmeance's Avatar
if there is a clunking or thumping noise, the brackets that hold on the rubber bushings (2 screws on each size, middle of bar) are loose, loosen them, make sure that the rubber or polyurethane brushings are firmly seated on the bar, then reinstall brackets until snug, I believe its 3o pounds of pressure.
Old Nov 25, 2007 | 09:16 PM
I have car ADD
yea its the progress...the noises were very faint when i first drove it (5 miles).... havent driven since. will drive tomorrow and if it still thumps, ill retighten
FYI , i gotta say this really is a job better left to the pro's.. or atleast somebody with a LIFT... lol.. doing it in the driveway really really sucked ass and getting those endlinks OFF are a pain in the ass too
Old Nov 26, 2007 | 02:26 AM
stillhere153's Avatar
94 DC4 RS LSV/Turbo
I used the stock bolts since they are of much better quality than stock (1ooo) miles ago... And still tight... The only thump I've heard from the rear shocks is when I come off of a speed bump... Makes the shock drop down a bit quicker than before and creates a mild thump only audible when all 4 windows are rolled down
csmeance
Jan 7, 2026 06:25 PM
Rdub81
ILX Photograph Gallery
Mar 17, 2016 03:02 PM
stogie1020
Nov 8, 2015 01:00 PM
thegipper
Oct 21, 2015 07:19 AM
TxRzrBk
Sep 17, 2015 01:07 PM
