In need of manual for mid mount rubber bushing
Old 04-06-2013, 12:56 PM
Desert Life Sucks!!
sauceja's Avatar
Parts numbers 10/11 10 is for the passenger side. I am replacing this and trying to find out what the manual says.
Do the bottom two bolts go in first then the top bolt or do you tighten the top bolt and tighten the bottom bolt.
The subframe is farther away from the body after the mount broke and the bolts on the bottom do not line up to the same place on the old mount when tightening the top bolt first.
I believe this is causing my car to pull right.
Any insight would be appreciated. I have been searching this issue all morning and there are no hot links in the garage to this issue.
Similiar problems in this thread:
https://acurazine.com/forums/3g-tl-2004-2008-93/how-does-transmission-mount-car-858528/
Old 04-07-2013, 03:08 AM
paperboy42190's Avatar
Received 1,162 Likes on 847 Posts
doesnt really matter which one you tighten first....however if its not lining up you will have to probably loosen the other side one too if not some other stuff too
Old 04-07-2013, 10:01 AM
Desert Life Sucks!!
sauceja's Avatar
When I tightened the lower bolts first and then tightened the top bolt it stretched the rubber something fierce.
I had to loosen the bottom bolts to get the mount to shift a little upwards.
I am not sure if this is a load bearing mount or just to keep suspension from traveling kind of like a fixed bump stop.
It is in, but I guess I will need a manual anyway, may have to find one.
cycdaniel
12-17-2019 10:58 AM
BKSleeper
10-07-2015 10:20 AM
V-tecAc
09-21-2015 09:25 AM
milehightypes
09-10-2015 12:07 PM
gqdabien
09-08-2015 11:41 PM
Quick Reply: In need of manual for mid mount rubber bushing
