AcuraZine - Acura Enthusiast Community (https://acurazine.com/forums/)
-   3G TL (2004-2008) (https://acurazine.com/forums/3g-tl-2004-2008-93/)
-   -   In need of manual for mid mount rubber bushing (https://acurazine.com/forums/3g-tl-2004-2008-93/need-manual-mid-mount-rubber-bushing-884640/)
sauceja 04-06-2013 12:56 PM
http://www.acuraoemparts.com/delray/...sep401_b48.png
Parts numbers 10/11 10 is for the passenger side. I am replacing this and trying to find out what the manual says.
Do the bottom two bolts go in first then the top bolt or do you tighten the top bolt and tighten the bottom bolt.
The subframe is farther away from the body after the mount broke and the bolts on the bottom do not line up to the same place on the old mount when tightening the top bolt first.
I believe this is causing my car to pull right.
Any insight would be appreciated. I have been searching this issue all morning and there are no hot links in the garage to this issue.
Similiar problems in this thread:
https://acurazine.com/forums/3g-tl-2004-2008-93/how-does-transmission-mount-car-858528/
paperboy42190 04-07-2013 03:08 AM
doesnt really matter which one you tighten first....however if its not lining up you will have to probably loosen the other side one too if not some other stuff too
sauceja 04-07-2013 10:01 AM
When I tightened the lower bolts first and then tightened the top bolt it stretched the rubber something fierce.
I had to loosen the bottom bolts to get the mount to shift a little upwards.
I am not sure if this is a load bearing mount or just to keep suspension from traveling kind of like a fixed bump stop.
It is in, but I guess I will need a manual anyway, may have to find one.
