Need help finding wiring
Old Oct 26, 2008 | 08:56 PM
techguy's Avatar
Need assistance. I searched the site but was not able to find the specifics for what I am looking for. I searched the 3G garage and Google. I need to get to the dome supervision wire. I read that it is the "green/red" wire that is part of the green 5 pin plug rear of fuse box. Does anyone have any pics or specific directions on how to access this? What do you need to remove to see/locate it? Someone said it can also be found on the A pillar. How do you safely remove the airbag cover on the A pillar to get to the wiring.
Old Oct 26, 2008 | 09:35 PM
Tripnbeats's Avatar
what year is the car?
Old Oct 26, 2008 | 09:38 PM
Tripnbeats's Avatar
the green red is the door trigger...the dome light supervision is black/white located in passenger side fusebox behind the dash.....both of those lines are negative polarity.... what alarm are u installing?
Old Oct 26, 2008 | 09:39 PM
Tripnbeats's Avatar
oh and all the years from 04 to 08 the wire is black/white same location
Old Oct 26, 2008 | 09:44 PM
Tripnbeats's Avatar
in some reference material they say just to use the door trigger. unless u trace the line from the dome light down the pillar. i used a bypass module on the car to make life easier and that it interfaces directly to the CAN.
Old Oct 26, 2008 | 11:15 PM
techguy's Avatar
It is an 04 TL. I am not installing an alarm. I want to hook up additional lights for the foot well. I want the lights to turn on when the dome lights are turned on. It is not door specific. I just want to get either a + or - 12V when the dome lights are on.
Old Oct 27, 2008 | 08:57 AM
Tripnbeats's Avatar
yea go from the each individual door trigger..makes it easier and they are negative.
Old Oct 27, 2008 | 09:28 AM
techguy's Avatar
I do not want to wire for each door. Just one wire that turns hot when any door is open or when the dome lights are turned on via the master switch by the sunroof switch. Do you have access to pics or any specifics as to how to find this wire?
Old Oct 27, 2008 | 09:37 AM
Tripnbeats's Avatar
i do but I just got back from canada so things are in a heap of crap....in a few hours ill have more details i just have to find my service manual and electrical schematics manual
gatrhumpy
19
Dec 31, 2015 04:22 PM
SUPRMN84
Oct 7, 2015 09:46 PM
johnpancakes014
Sep 27, 2015 12:58 PM
STL TL-S
Sep 23, 2015 08:52 PM
g1underground
Mid-Atlantic
Sep 23, 2015 01:18 AM
