LED Blue Door/White Dome Lights Mod???!
#201
TLover
1 Post
Originally Posted by maecrispy
In case anyone still wants to see pics of the LED's for domes and doors (shows difference in light color between white LED's and stock dome bulbs.)
http://homepage.mac.com/maecrispy/PhotoAlbum7.html
the white LEDs look good, but do they bother the driver at night from the high intesity white colo. and do you think the W6 for the front are too bright or not?
thanx
#202
Team SSM
They're not too bright, actually its less brighter than the normal bulbs, But they look cool.
Oh I finally put in my LEDs and they look great, White in domes and Blue leds in doors. Honestly the BLue leds(in the doors) look tight at night, during the day they look like hmmmm I guesssss rice(just see a light faint blue circle), but noone notices it during the day.
Also I found it REALLY REALLY hard to take out the LEDs I inserted into the Rear domes. The bulbs were easier, well I just used the shrink tubes (thanks GotJazz, It worked great), but its impossible to take out the rear leds, well at least for me.
#203
Originally Posted by tlxlr8s
you have two pics of the doors, one says door lights and one says door courtesy lights, is there a diff?
thanx
thanx
As far as the white led's for domes, it actually worked out good as far as night driving. I find that I can drive much more comfortably with the WLED-W6's in the domes than with the stock bulbs in. Overall amount of lighting, even with the 6 led bulbs is down compared to the stock bulbs.
Of course, passenger will have a bit more trouble reading at night. Overall light is diminished as LED's throw their light forward while the stock bulbs radiate. Since LED's don't radiate light to the sides, much of the reflected light doesn't exist so you end up getting a fairly focused light pattern. Very cool looking IMHO but not quite as good for readability.
#204
I personally had no problems with it whatsoever.
I think guys with larger fingers will have a harder time taking the bulbs out. I'm a rock climber (finger strength) and I have small fingers. I did find that if I worked the tips of my fingers closer to the base of the bulbs (where it inserts into the socket), it was easier to pull out. Again, easier for guys with smaller fingers.
#205
i know. there is just red or blue in the drop down menu.
maybe someone can call them.
http://www.superbrightleds.com/nostock&newleds.htm
Looks like I'm waiting...
#206
TLover
1 Post
Originally Posted by TLJohn
I ordered from them last night. Their out of stock page lists the T13-W being expected in on 4/30/04.
so the trunks are WLED and the plates dome and doors are too right? what about the hood and glove box?
#207
what about the WLED-W6 they aren't on the list and i cant find them in the order list.
#209
TL-SHAWD 6MT Rocks!
anybody tried replacing the rear or front turn signals with LED's?
I know they sell a module so it would not blink so fast.
(because of the difference in resistance)
#210
So whats the FINAL word on these lights?
Should I get the WLED or the TLED ones and also what are you'll suggestions about the Blue (wled b6) VS. White (wled w6) FRONT dome lights?
#211
Don't get us started!
Condoleeza Ricer sez:
"Try replacing the side marker lights in the front with blue LEDs."
Is that over the top? Do they fit? Is it legal? :cop:
Inquiring minds want to know.
#212
#213
Team Anthracite Webmaster
hi guys,
i took a gamble and bought this
http://cgi.ebay.com/ebaymotors/ws/eB...K%3AMEBWN%3AIT
because the supercheapLED's site is out of the 6-LED white ones. it's a gamble but i'm willing to risk 8 bucks, not that big of an investment. 9 LEDs, if that's true that should be kinda cool to see.
will report back when i get them.
#214
Team SSM
Originally Posted by zeezz
hi guys,
#215
Team SSM
Originally Posted by EggrollXpress61
omg dont get it in the hood OR the glove box OR the Trunk! WAYYYYY TO RICEY. And Im about as ricey as they come. Asian Pride btw I have mine in Doors, Domes (front 2 white, back seat Blue. BEST look/combo out there!), and License plate. if yall wanna see License plate pics w/ the lights, give me a holla. Ill post em up IF ya want.
#217
Team Nighthawk-C.M.A.
I must be pretty friken stupid. Where is the hood light? I open my hood and no light turns on. Have not found it in the manual yet. Only on page 60 something (not much bathroom time yet). Is there a trick or am I just missing one. I feel totally dumb asking this, sorry.
#218
#222
TL-SHAWD 6MT Rocks!
Originally Posted by SmokeTL
I had replaced the rear turn signal with leds, I didn't like the lighting during the day, at night they are more noticable. they were washed with direct sunlight.
how many LED's did you use per bulb ?
were they WLED ?
maybe the 9 LED version would work better...
#226
Side Marker Light swap?
Has anyone changed the bulbs in the front fender side marker lights to LEDs?
I think that would be cool to have blue bulbs there (if they're not visable from the front as that would be illegal.) :cop:
#227
Small fingers?
... and I have small fingers. I did find that if I worked the tips of my fingers closer to the base of the bulbs (where it inserts into the socket), it was easier to pull out. Again, easier for guys with smaller fingers.
Small fingers = small gloves
One of our members here said she got 5/8" heat shrink tubing from Radio Shaq and put it over the bulb, then turned it on. The heat shrinks the tubing around the bulb so, after you turn it off, you just tug on the tubing and take it out.
This won't work for the new LED bulbs, I suspect, since they don't get hot.
XP
(3 days and counting)
<biting nails>
#228
Cesspool of Knowledge
Originally Posted by xpditor42
... One of our members here said she got 5/8" heat shrink tubing from Radio Shaq and put it over the bulb, then turned it on. The heat shrinks the tubing around the bulb so, after you turn it off, you just tug on the tubing and take it out.
XP
<biting nails>
XP
<biting nails>
Wait ... I'd better check ...
Zip ... fumble ... fumble ... (a few nervous seconds pass)
Whew! I'm still a he.
And you're right, the new LED bulbs don't get hot enough to shrink the tubing. However, you can get 3/4" shrink tubing (the LEDs are a bit larger than the stock bulbs) and one of those fireplace/grill butane lighters and shrink the tubing with the lighter to remove the LEDs easier.
#229
Misleading advertising!
We all develop mental images of our e-correspondents and, informed by your avatar, I just saw you as a woman.
Did you ever consider that maybe...... well, you know... Is it possible you are a lesbian trapped in a man's body bathed in a techno-blue LED light?
JUST ASKING! JUST ASKING!
#230
were they WLED ?
were they WLED ?
edit: they were from APC. the only ones i could get over the counter at an auto part store.
#232
Originally Posted by IIHII-TL
any one try replacing the visor lights. i want a brighter light in there. LED? SIZE? Then i can use this light when i need a reeding light.
as far as the white light is concerned, i LOVE the white light. it is not too bright, and having the passenger light on while driving causes for little distraction (since LEDs have a very narrow viewing angle). when putting on these maplights, the light produced looks like NATURAL DAYLIGHT, rather than that yellowish garbage produced from standard filament-bulbs. I get the same light during the daytime by opening the sunroof
Also (as with the exterior LEDs), switching the lights on produce immediate light, rather than the quick fade (.2 seconds) seen in incandecents...that's being kinda picky, but when switching the light on and off quickly you definately see the difference.
#233
hi guys, just an update. i finally got the 9-LED white lights that i bought on ebay two weeks ago. they shipped from hong kong?? anyway, i'll get a chance to try them out later today. if it looks good i'll take some pics hopefully.
#234
oops, i was referring to the maplights, perhaps a festoon bulb would replace the visors? again I have the 2003 TL, but my current light is affixed into a tube (at the pivot point of the mirror lid) that illuminates when the lid is opened....from that, and from looking at the light itself through the diffusor, I would assume that a festoon bulb (4-LED) might work....
#237
WDP Director of R & D
I installed the WLED-6s in the doors and rear License plate area. I like them both. The blue looks good with the WDP and my white/blue state plate..
I don't think its too "ricey", and I'm 40+. I just love the blue!
#238
#239
Front side marker light "Blue" LED mod
OK guys,
I went for it tonight and installed blue LEDs in the front fender marker lights. It was actually quite easy. Front tires had to come off, removed only two of the black pop-plugs on inner fender cover, reached up and easily popped out the lens assembly, used Dremel tool to cut open back of lens housing, removed yellow LED circuit board, removed yellow LEDs, soldiered on blue, used 100% silicone to re-seal the lens housing, plugged back in, popped back in fender, reinstalled pop-plugs, and mounted tires. First side took about an hour total - ie - configure the circuit board and ensure LED's were installed with correct polarity, basically figure-it-out-time. Side two took maybe 30 min.
I used two WLED-B4's on each side. The stock yellows were actually two 1/4 inch square LEDS but given the circuit board/wiring each was a double LED, so overall brightness of 4 per side. I compared the WLED-B4's prior and thought they matched better than 2 single LED's. Overall when finished the brightness is very close to the rear reds yet a little brighter straight on due to the focused "beam" of the WLED's. Looks pretty good though.
If interested drop me a PM - I took several pictures along the way and afterwords.
Smitty
Smitty
#240
bulbs flicking
anyone noticing that the leds flicker?
hey i think i jinxed myself..one of my back lights (dome) are flicking now...i removed and placed it back same results..what did u do...did super bright lights replace the bulb?
