Hit Rev Limiter in AT
Old Oct 25, 2004 | 01:35 AM
donkeykang's Avatar
My cousin decided that he wanted to drive my car. Of course, I didn't want him to drive my car and him being a 6'3, 260 lb beefcake, I had no choice. He took my car out and we hit the freeway and he decided to floor it. Unknowingly he put it into SS and her floored it to redline and it lagged there. I was panicking like crazy and saw the 2 on the dash so I moved it back to normal drive after a few seconds or less. Is this gonna cause serious damage, or is it no big deal?
Old Oct 25, 2004 | 02:02 AM
rets's Avatar
Moderator Alumnus
2nd gear, huh?
Acura says:
...In second, third and fourth, the transmission won't upshift without a command from the driver; the ECU cuts off fuel flow to the engine if there is danger of over-revving the engine. The transmission will upshift itself to prevent engine damage in the rare situation where the fuel cutoff alone is unable to prevent further engine over revving (as could happen on a steep downhill)...
You should be fine. I remember the owner manual also addresses the similar concerns, please check it out.
Old Oct 25, 2004 | 02:05 AM
samkws's Avatar
Comptech Freak
once a while won't be harmful, that's where all the VTEC power come from!!!
i always hit to 6900rpm even my car redlines at 6250rpm, love that VTEC power
Old Oct 25, 2004 | 02:25 AM
rets's Avatar
Moderator Alumnus
I like this... "all OEM"... LOL...
Enjoy...
Old Oct 25, 2004 | 07:49 AM
ludachrisvt's Avatar
Wants an M3 in
how is that possible? the car rev limits at 6700 ... well mine seems to (i think)
Old Oct 25, 2004 | 08:05 AM
JackSprat01's Avatar
Licking Platters Clean
Get a new cousin. Blood is thicker than water, but I'd still want to hurt him badly.
Old Oct 25, 2004 | 08:38 AM
6mtV6's Avatar
I6
It's your TL. You don't have to let him drive.
Old Oct 25, 2004 | 09:50 AM
ensley696's Avatar
Don't think I would let him drive again?
Old Oct 25, 2004 | 09:52 AM
samkws's Avatar
Comptech Freak
forgot to mention mine is a secdond gen TL, therefore the rev limiter is at 6900rpm, but sometimes u get to bounce it to 7000rpm
it gets you up to 105mph on 3rd at 6900rpm and gives u a gd run if you need to race with somebody
3rd gen TL's rev limiter is at 6800rpm, did that in a test drive LOL
Old Oct 25, 2004 | 09:55 AM
samkws's Avatar
Comptech Freak
Originally Posted by rets
Enjoy...
LOL, thanks for the reps
not all OEM anymore~
Old Oct 25, 2004 | 10:57 AM
GaleForce's Avatar
You touch my tra la la...
The rev limiter is there so you DON'T do damage. You didn't do damage. End of story.
Its not such a big deal its a failsafe in there incase you forget to shift to keep you OUT of red.
Old Oct 25, 2004 | 03:36 PM
caball88's Avatar
like it said if you are on a steep downhill and the car hits the rev limiter, gravity will still be accelerating the car. if the car picks up speed past the 6700rpm mark it can over rev without even stepping on the gas.
Old Oct 25, 2004 | 11:07 PM
samkws's Avatar
Comptech Freak
gotta be a very steep hill to do so~
Old Oct 25, 2004 | 11:24 PM
rets's Avatar
Moderator Alumnus
If RPM is revving high and cut-off won't help, the tranny of 3G TL would upshift itself... you prolly won't see over-rev...
2nd gear, huh?
Acura says:
Old Oct 25, 2004 | 11:43 PM
Dr.Murdock's Avatar
Today i actually revved my car a little over redline for a real short time.
i hit 80mph (or maybe more) in 2nd gear
Old Oct 25, 2004 | 11:57 PM
blufox's Avatar
you can redline it till fuel-cut off without hurting it (i think) but that doesnt mean u should do it for kicks
Old Oct 26, 2004 | 12:16 AM
rets's Avatar
Moderator Alumnus
Hey, man, you're running too fast by 2nd gear. Downhills??
Old Oct 26, 2004 | 09:46 AM
samkws's Avatar
Comptech Freak
teh best is to shift b4 the redline for a bette acceleration
Old Oct 26, 2004 | 09:59 AM
Aegir's Avatar
Powered by Guinness
It should be OK, but you wouldn't want to make a habit of it!
Old Oct 26, 2004 | 12:51 PM
Dr.Murdock's Avatar
No, it was a highway straight away. As soon as i entered the highway and floored it. I know for sure it went past redline, but not exactly sure how far (maybe 7100 rpm). After i decided it was enough of redlining i shifted into 3rd and the rpm range was already between 4,500 and 5,000. My car usually masses at around 60-70(5?) mph when im driving it and pushing it to its redline in 2nd. These numbers do seem a bit high. What are the specs of the gear/speed?
Old Oct 26, 2004 | 04:04 PM
rets's Avatar
Moderator Alumnus
Usually, 2nd gear would go to Redline 6800 RPM around 67-75 MPH, the 3rd gear btwn 4500 and 5k would be around 70-82 MPH.
Old Oct 26, 2004 | 04:35 PM
Dr.Murdock's Avatar
So i was right. I was going a little over 80mph in second gear.
MrHeeltoe
20
Feb 23, 2023 01:54 PM
08KBP_VA
Oct 22, 2019 01:55 PM
F-C
Motorsports News
33
Aug 22, 2018 09:53 AM
MrHeeltoe
Sep 29, 2015 10:43 PM
MrHeeltoe
Sep 28, 2015 05:43 PM
