G-109: DIY-Eliminate LED Bulb Induced Hyper flashing WITHOUT LOAD RESISTORS
Old 06-05-2012, 11:00 PM
  #801
Desert Life Sucks!!
sauceja's Avatar
Originally Posted by andy00kwok
Hello Friend I had a 07 TLS and I had just did what u did, and it come out perfect no more fast blink, Thanks for that. But however the parking light don't come on. Do u had that problem on your car?? I had been replace with 2 different kind of 1157 leds from ebay.
It could be possible that you have them both backwards.
Led's have to be plugged in the right way. If you plug them in and they don't work. Twist out the light and put in the opposite you took it out.
That has worked for me on a couple bulbs.
Not sure if you knew this thats why I am taking the time to type it out. GL
Old 06-06-2012, 05:50 PM
  #802
Desert Life Sucks!!
sauceja's Avatar
^After re-reading that I am sure you have that figured out ^
rydjohnson - thanks and sent you a couple bucks
Time to get my rear LED on.
rydjohnson (06-19-2012)
Old 06-08-2012, 09:36 PM
  #803
BRB..Shifting!
VieTLover's Avatar
How do you take out the relay?? I tried taking it out and it will not budge! my fingers hurt for trying for 30mins lol
Old 06-08-2012, 11:06 PM
  #804
skd2k1's Avatar
put flat head screwdrivers on both sides and pull...should come out relatively easily then.
Old 06-09-2012, 12:16 AM
  #805
tagalog4life's Avatar
Do you think this mod will work for 05 RL? And could this possibly be the reson why when i try to install HIDs for my fog lights that one will start flashing? please help.
Old 06-09-2012, 12:22 AM
  #806
Desert Life Sucks!!
sauceja's Avatar
It should work for an RL, it was founded by the Ridgeline first I believe.
And as far as your HID fog problem flashing or "flickering" you need to run it with a relay to get constant power. Read through this to get an idea of what I mean.
https://acurazine.com/forums/3g-tl-2004-2008-93/g-029-diy-independent-fog-lights-stock-switch-772633/
tagalog4life (06-09-2012)
Old 06-10-2012, 03:14 PM
  #807
King of NYC
rockyfeller's Avatar
OK so I've now been hit with the relay flasher quirks. Great.
This mod worked flawlessly for a number of months. Absolutely loved it. Had 4 load resistors for the last 5yrs, this was a better idea than generating all that heat.
Then what started to happen is my signals wouldn't work occasionally. (pretty dangerous when making a turn/lane change and you don't realize it till someone is honking at you!) Once you play with them (on/off or play with the hazzards) they'd work again. I pulled the relay and figured it was a solder point, so I applied pressure here and there. The flasher relay worked fine for a few more days.
Then it reached a point now where it doesn't FLASH at all. It will flash ONCE and that's it. If I reactivate the signal from the stalk (on/off) in rapid succession it doesn't work at all. If I wait about .5 sec from the last flash it will flash again ONCE. Same with the hazards, just one flash, then dead. So I've been driving around manually flashing my signals, up/down, up/down, one flash at a time like a dummy, lol.
Yesterday I pulled the relay and totally examined the resistors, resoldered tested and resoldered. Same issue. I think my relay is toast. I don't know if someone else has had this problem but from my reading it seems like I'm the only one.
If I get a new relay I don't want this to happen again and waste $50. I am thinking bout doing those load resistors again. Only problem is trying to get to the front headlight wiring. I'd have to pull my front bumper again for the 750th time! Arrgh!
Anybody know the part number on the Mitsuba relay?
Old 06-11-2012, 11:28 AM
  #808
Starcraft II addict
Buda's Avatar
First time hearing of this. Someone does need to sit down and do the proper calculations to determine actual load on the circuit with stock lights versus LEDs and then calculate the proper resistance as compared to the shunt resistor. I had wanted to do that but haven't had the time.
As far as putting back on the load resistors, why are you putting them up front? There's no reason for it and its a lot of work. Put them in the trunk. If you undo the trim pieces on the sides in the trunk (as if you where swapping out the side markers and look above the tail lights you will see a flat platform that is perfect for placing the load resistors (I used adhesive backed velcro). Then you just run the wiring down to the turn signal wires going into the rear tails. I've done this on multiple vehicles and this was my setup when I had the 4 ohm 100 watt resistors on each side (only 1 per side for that load resistor setup).
Old 06-14-2012, 11:35 AM
  #809
King of NYC
Good points, the rear is definitely easier to get to, I know exactly where to put them. See, I'm confused with this, I've asked on other threads, and I've never seen a clear answer.
What I did originally is the 50watt 6ohm resistors, one on each corner. probably overkill, but it worked so I didn't ask questions. I know there are other load resistors labeled as needed only 1 per side. So that means if I just connect 2 load resistors just to the rear signals (4ohm 100watt as you mentioned) they will create load for the whole system? If so I am on going to get on to this right now!
Old 06-14-2012, 11:47 AM
  #810
King of NYC
Just to take VLED's example; they label the 6ohm 50watt resistors are good for 2 bulbs (even though I used 1 for each bulb for a total of 4) and the 3ohm 50watt resistors are good for 4 bulbs. This is the first time I'm hearing about 4ohm 100watt resistors you've mentioned.
I know one thing, if you use 6ohm 50watt resistors on the back signals by themselves without doing the fronts, you will still get hyperflash from the flasher.
Old 06-15-2012, 12:33 PM
  #811
Starcraft II addict
Buda's Avatar
Here's what I remember about how all this started out. The use of the 3 ohm 50 watt resistors was done first and it required 2 on each side. The initial install location was in the trunk behind the trim on the sides (not above the tail lights). However concerns about the heat they generated is what resulted in the install location being moved to the front.
About the time I was looking into getting LEDs put in the front/back a person posted up in one of the threads indicating that they had caculated the draw on the EOM bulbs had on the system versus using 2 3 ohm 50 watt resistors on each side. The use of four 3 ohm load resistors resulted in a higher draw on the circuit (and as such uneccessary heat being generated). He had calculated that the 4 ohm 100 watt resistor not only came in much closer to the stock draw but it also generated less heat and dissapated it better due to the larger heatsink. There was so many people back then that had already used the 3 ohm load resistors that the discussion went back to that and not many people ended up doing the 4 ohm resistors but there are some of us.
As for the install location I was told that by Kennedy (and he could have been the one to figure out the use of the 4 ohm load resistor but can't be certain).
I ran a single 4 ohm 100 watt load resistor on each side for years (until just recently when I did this mod and removed them) with absolutely no problems and no hyper blinking. I run switchbacks up front and normal leds in the back.
If you are interested I still have the two 4 ohm 100 watt load resistors that I took off my car. If they don't work for you I'll take them back.
rockyfeller (06-15-2012)
Old 06-15-2012, 01:28 PM
  #812
King of NYC
OK for everyone's info; the part number for the turn signal/hazzard relay (Mitsuba) is: 38300-SHJ-A04
Nowadays they sell enclosures (VLEDs and others sell em) for the load resistors which encase them but allow ventilation and heat dissipation. I would have preferred to stay with the flahser relay mod, but being forced to buy a new flasher means I'd rather take the safe route this time. My theory is all our electrical systems are slightly different due to what mods we've done hence the quirks on some cars. My car has a hefty sound system and all regular bulbs replaced. Everything is LED or HID. Puddle lights, door sills, lights in the subs, headrest monitors, pretty ridiculous. There is alterations in load/resistance etc. and alterations to the wiring all over the place. The more stock your car is, the less potential problems.
Buda, thanks man. I'll PM you.
Old 06-18-2012, 11:36 AM
  #813
Engineer in Training
LockDots's Avatar
Anyone have extra resistors laying around they'd like to sell me?
Old 06-18-2012, 04:09 PM
  #814
Starcraft II addict
Buda's Avatar
I have some .24 ohm resistors left (you'll need 2 for this mod). PM me if you want a pair of them.
Old 06-18-2012, 04:11 PM
  #815
takin care of Business in
swoosh's Avatar
Received 4,732 Likes on 4,064 Posts
^^^ 2 ???
i should be good enough....am using 1 x -.22ohm resistor...
Old 06-18-2012, 04:45 PM
  #816
LockDots's Avatar
Going to PM you in a minute. Spank you berry much.
Originally Posted by swoosh
^^^ 2 ???
My 120 switchback from autolumination just came in today and I plan on getting RED LED turns for the rear eventually. So what I'm going to do is solder in 2 .24ohm resistors in parallel. This way when I get the rears in I'll just have to remove one of the resistors and i'm done. This way I don't have to touch the solder connection on the PCB.
Old 06-18-2012, 04:47 PM
  #817
swoosh's Avatar
^^^ ok you got me there
i have LED's upfront and in the rear (all 4 corners) and i used (this mod in the thread) to get rid of the hyperblinking by using 1 x 0.22 OHM resistor in the relay....
if you dont wanna touch the relay and use some other method in all honestly dont crap the thread up....this is a thread to eliminate hyper blinking without using load resistors by modifying the RELAY !!!
Old 06-18-2012, 05:00 PM
  #818
LockDots's Avatar
um, i'm not sure how I'm crapping the thread, i am afterall modifying the flasher relay in almost the same way everyone else is doing with the difference being that instead of adding a resistor later on I'd only be removing one.
Old 06-18-2012, 05:50 PM
  #819
vietxquangstah's Avatar
Uh... Why don't you just solder a 0.22 (or 0.24) ohm resistor in and simply call it a day?
If you only have LEDs in the front right now and stock halogens in the rear, a 0.24 is still enough to run the front LED with no hyperflash while still having the rear halogens flash normally.
When you upgrade to LEDs in the rear than just simply swap the halogen out for the LED rear turn signal and that's it. No need to go back to the relay to "remove" the extra resistor that you soldered...
1 and done.
Using 2 resistors just to run 1 pair of LEDs is a hassle.. Use 1 resistor and you can run all halogens, 1 pair LED, or even 2 pairs. Make sure the resistor is 0.22-0.24OHMs
Old 06-18-2012, 05:54 PM
  #820
LockDots's Avatar
1 and done.
I may just try that. I thought I read earlier in the thread (yeah, I read all of it in one sitting ) that someone had trouble with a .22/.24ohm resistor with only LEDs up front and halogens in the rear until he also put LEDs in the rear. I think it was RockStar if I remember correctly.
Old 06-18-2012, 09:02 PM
  #821
I don't know....
I had a 0.24OHM resistor installed and was only running 1 pair of LEDs and 1 pair of halogens for a month or two until I finally got LEDs front and rear. It worked just fine as far as I know.
Old 06-18-2012, 09:37 PM
  #822
LockDots's Avatar
yes you're right, I meant 7443...not 7440...I'm very aware of the difference since you'll recall the issue I had with the whites no turning off when the amber would blink (like the sidemarker blinking issue).
Anyway, in MY case...the ebay bulbs I used would NOT switch"back" correctly UNTIL I put in the rear LED's too. Just my experience and I started off with the .24 ohm resistor.
yeah, I thought it was him
Old 06-18-2012, 10:30 PM
  #823
swoosh's Avatar
well if you are getting the rear LED's later why not just get em now and avoid redoing the whole thing was my point
Old 06-18-2012, 11:29 PM
  #824
Starcraft II addict
Buda's Avatar
^^^ 2 ???
Oops I meant I have .12 ohm resistors ( x 2 = .24 ohm).
Old 06-18-2012, 11:42 PM
  #825
swoosh's Avatar
^^^ now it makes sooo much more sense
Old 06-19-2012, 07:59 AM
  #826
LockDots's Avatar
It's no big deal to me, getting that relay out really isn't a big deal. I'm constantly working my car anyway. I also work in the automotive electronics field and i'm always under a dash so it's really not extra work to me.
yeah, he PMed me about it lol, Either way I can make it work.
Old 06-19-2012, 09:05 AM
  #827
swoosh's Avatar
getting the relay out is a pain in the ASSSSSS !!!! but yeah i get what you are saying
Old 06-19-2012, 09:33 AM
  #828
LockDots's Avatar
I don't see what the big deal is, iv'e gotten it out a few times already to have a look at it. Maybe people don't see where they should be applying pressure. When I get around to doing it once I have the resistors I'll have to remember to take pictures to show people where to squeeze to make it a little easier.
Old 06-19-2012, 05:33 PM
  #829
rydjohnson's Avatar
No prob, glad to help ya sauceja... I have 7 more 0.24 ohm resistors if anyone wants them for cheap...
~$2 shipped
Old 06-19-2012, 05:46 PM
  #830
rockstar143's Avatar
Received 19,991 Likes on 14,500 Posts
Lockdots...1, definitely true, much easier once you know WHERE to pinch...but mine was a bitch to get out, plus...my clutch is right in the way, so probably much less clearance than you auto guys.
About the $2 shipped...that's a nice offer...people should jump on that. Still working flawlessly.
Old 06-20-2012, 08:04 AM
  #831
2007 6SMT Type-S
SurfingScotty's Avatar
I'm selling my pair of rear red LED's. I couldn't get this mod to work with my stock relay, had sucess with the second one for about 5 months but then my right turn signal would stay on even with the key out of the ignition. Had to disconnect the battery to get it to stop.
Anyone want my red LED's? $20.00 shipped. Text me if you want a pic (801) 915-1350
It's not a pain in the ass. You just need the right tool for the job. I have a clutch pedal in the way but I was still able to get mine out with a pair of vice grips...took a whole 10 seconds. Just SLOWLY increase the tension and test it before you decide to fully lock them down on the relay. If the tension is too high, you'll crack your relay.
Old 06-20-2012, 09:27 AM
  #832
swoosh's Avatar
^^^ lol no shit...pinching in the right place is the key....the point i was making is, its tough for a relay....it took me a good minute the first time around and 15-20 seconds the second time around....but either way, point is no reason for doing this twice when its not needed....
i rather spend the time to take the relay out and solder and put it back in (5-7 minutes) doing something else....i dont like redoing my mods
Old 06-20-2012, 03:46 PM
  #833
BRB..Shifting!
VieTLover's Avatar
I still do not know where to pinch to get my relay out =[ I want to leave the hyperblink club lol
Old 06-20-2012, 06:44 PM
  #834
^^^you will when you see it, it's obvious, just hard. Took me longer than a minute!
And I did crack it too.
Old 06-21-2012, 02:32 PM
  #835
2007 6SMT Type-S
I did my 1st time around. Second time I put my vice grips into their "locked" position, tightened, "unlocked" and tightened a quarter turn. "Locked" them down around the relay and it pulled out with ease. IMO, vise grips are the way to go. I spent a good 20 minutes the first time around with screw drivers, pliers, etc. b4 I went to the vice grips. Problem is by that time I was pissed and was over zealous with clamping down on them.
Old 06-22-2012, 04:36 PM
  #836
EvilVirus's Avatar
Received 1,120 Likes on 893 Posts
Just did mine and its all good
Old 06-22-2012, 06:07 PM
  #837
Hmmm...vice grips it is then! Next time, if there is one, I'll go that route.
Old 06-23-2012, 08:44 AM
  #838
EvilVirus's Avatar
Vice grips..............where's you all muscles?
Old 06-23-2012, 09:23 AM
  #839
it's to apply even pressure on both sides due to access issues, papo.
Old 06-24-2012, 02:39 PM
  #840
Desert Life Sucks!!
sauceja's Avatar
I was running a 0.12 ohm with just switchbacks and got weird blinking as far as the white coming on with type 2's.
I just installed rear LED blinkers without changing the resistor yet and have no hyper flash. I have a .24 ohm laying around if I encounter trouble but as for now I will run the .12 until then.
Will report back and see what happens.
Quick Reply: G-109: DIY-Eliminate LED Bulb Induced Hyper flashing WITHOUT LOAD RESISTORS
