Exhaust bolts
Jeff
Exhaust bolts
I need the exhaust bolts that go from the xlr8 j pipe to the cat back and also need the bolts that go from the bottom of pre cats to the 2 ends of the j pipe..
are those bolts #16?? in the link
Acura Parts @ AcuraOEMparts.com - Genuine Acura OEM Parts from Delray Acura
but what about the 3 other bolts and nut that go from the xlr8 j pipe to the catback.. would that be #3 and #22
thanks boys
going to be installing the xlr8 system here soon but it only came with 2bolts and 2 nuts, the other one fell out of the package
thanks boys
forget buying those nuts and bolts from the dealer, they charged me over 20$ for the same bolts i saw at the auto parts store for much cheaper
You are correct with the part numbers, though.
#16 you won't need unless you snap the stud off your precat. It's like the studs on your hub, no need to replace unless broken when removing the lug, in your case, nut.
Oh Sickest TL (04-26-2015)
Jeff
Expect them to be seized and rusted
If your car was like mine, your mechanic will have to use a "damaged/rounded bolt remover" socket for the precat to jpipe nuts. That will destroy them, but at least you'll be able to get them off and replace with new nuts. The studs are fine on the pre-cat.
As for the jpipe to catback bolts, mine weren't even bolts anymore.
Just pure chunk of rust.
Oxy acetylene torch + hammer with chisel broke them off.
Correct.
Jeff
you da man GP.
EDIT: this is for the xlr8 system so i won't have the 3rd cat, does that matter in terms of the bolts? 10 bucks for a bolt tho? LOL wtf
I installed my RV6 V3 (no 3rd cat) using the exact same hardware.
neuronbob
23
07-16-2019 10:48 AM
joflewbyu2
10-08-2015 11:16 AM
