Downshift speed...
Old Sep 10, 2011 | 11:45 AM
9632tl's Avatar
Radical Member
Downshift speed...
When driving at, say, 55 or 60, if I floor it to pass, there is often a delay between the first shift down, and the second (or third)
Like the car isn't sure it wants to drop that extra gear yet.
Its not slipping, the fluid is new, and its Redline, and my pressure switches have been replaced. And ideas? Could it be the TPS?
Old Sep 10, 2011 | 01:43 PM
thisaznboi88's Avatar
i thinks it a combo of drive by wire lag and the transmission lagging also.
Old Sep 10, 2011 | 02:48 PM
I hate cars's Avatar
Mine does this as well. Unfortunately, the trans won't do a double downshift, only one at a time. What I have noticed is if I drive it pretty easy for a long time where when I get on the gas, only one downshift is usually required it learns this. If I floor it after driving it easy all the time it downshifts one gear and after a second, another gear. If I drive it aggressive all the time it there is much less delay. So while I'm pretty sure the trans is limited to a single downshift at a time, I think it can be sped up by resetting the ECU or driving aggressively all the time.
Old Sep 10, 2011 | 03:04 PM
9632tl's Avatar
Radical Member
well, its good to know that i am not the only one. seems like a logical explanation.
Old Sep 11, 2011 | 01:06 AM
paperboy42190's Avatar
or u can just use manual mode on ur car and forget about all this lol
Old Sep 11, 2011 | 09:27 AM
RaviNJCLs's Avatar
If it is essential for you to accelerate that quickly to pass another car I would use manual mode.
Old Sep 11, 2011 | 04:33 PM
9632tl's Avatar
Radical Member
I don't wanna
I hardly ever use manual mode, so I forget to use it. I guess I could just put it into "L"
Old Sep 11, 2011 | 10:10 PM
Bearcat94's Avatar
AZ Community Team
That's what I'd say too.
Anticipate your action, put it in the manu-matic mode, hit the lever 2x as you mash the gas, and off you go.
Old Sep 12, 2011 | 12:20 AM
4drviper's Avatar
I thought traditional (torque converter) automatics only shift one gear at a time,, so it'd be 5-4-3 so delay???
I don't recommend this, but I floor the gas a split second early.
Say, I wanna pass this car,,,,,, NOW!
then I'd step on it at the second last comma lol..
NOT RECOMMENDED,, but I do it and it only takes a few tries to get the timing dead on.
Old Sep 12, 2011 | 12:21 AM
4drviper's Avatar
I can't edit, so I just have to add another reply.. sorry about that.
Worked on all 6 automatic cars I had, including 07 TL
Old Sep 12, 2011 | 09:15 AM
Some like my GN will do a double or triple downshift at once. I can be crusing along in 4th and hit 1st or 2nd immediately without hitting 3rd first. The TL does get a lot quicker if you drive it hard a lot but you're right, in the TL's case and most automatics you're stuck with one gear at a time. The older cars seemed to be better in this respect.
Old Sep 12, 2011 | 09:19 AM
RaviNJCLs's Avatar
Originally Posted by 9632tl
I don't wanna
Then you sir need to stop bitching about it. :biggirn:
Old Sep 12, 2011 | 09:21 AM
RaviNJCLs's Avatar
I've also found that it is a lot easier to pass someone when you're already doing 65 mph. I use the manual every now and then, but usually I can just coast pass someone without having to floor it.
Mike Pilipenko
Mar 26, 2024 09:21 PM
kixo
Sep 5, 2015 08:54 PM
mrlemonjello
Sep 1, 2015 08:52 PM
Crazy Bimmer
May 2, 2010 06:34 PM
MikeS 18
Jan 28, 2001 05:34 PM
