The definitive LED thread: All you'll ever need to know about LED's 3G Garage #G-076
#88
I posted this in my other thread but ill quote it here so ppl can see what it looks like.
THESE LIGHTS ARE THE ONES IN POST # 7 RECOMMENDED BY KENNEDY - Much brighter in person and I'm 200% satisfied with them.
Originally Posted by JLJL
here are some before n after pics
i take shitty pics sorry haha - all the pics were taken WITHOUT FLASH
BEFORE
[IMG][/IMG]
AFTER
[IMG][/IMG]
BEFORE
AFTER
BEFORE
AFTER
BEFORE
AFTER
BEFORE
AFTER
BEFORE
[IMG][/IMG]
AFTER
[IMG][/IMG]
BEFORE
AFTER
BEFORE
AFTER
BEFORE
AFTER
BEFORE
AFTER
#90
Does anyone know if the supernova leds can be used anywhere else?
I ask because i got myself into a situation where i bought a set from someone. One led got lost through mail because of a hole due to flimsy packaging. And the person i got them from won't respond...
I'll have to buy another set for the plates.. or maybe not because of the bad luck i've had with every of my recent car-related purchases...
#91
already ordered another set for you. I haven't cashed your check either.
relax. no gonna shaft you.
#93
Originally Posted by Kennedy
LED technology is ever evolving. I've changed my setup a bit. Here's where I'm at today:
- 4 interior dome lights:
www.superbrightleds.com - WLED-WHP
- License plate lights:
www.superlumination.com - SuperNova
http://superlumination.com/194.htm
Same LED at 1/2 price:
http://cgi.ebay.com/ebaymotors/2x-25...spagenameZWDVW
Would you say the WLED-WHP bulbs are brighter and possibly whiter than the SuperNova that you use for the license plate lights?
I am currently using the SuperNova's as my license plate lights, but I don't like the slight blueish color that it gives out. I was thinking of trying the WLED-WHP bulbs since they're suppose to be between cool white and warm white.
Would you recommend the WLED-WHP bulbs for the license plate lights?
Thanks!
#95
Thanks!
Thanks!
No the WLED-WHP are bluer than the SuperNova's. I am running the WLED's in my plates now because I don't have any luck with SuperNova's. The WLED's are not as bright.
#96
Supernova's are definately brighter than WLED-WHP.
My SuperNovas are holding up fine, you have to lightly bend the contact wire to make sure it gets good contact. I was having intermittent outtages as well, adjusting the contact wire fixed it.
I've found the Supernova's to have some pretty wild variations in color hue. The Autolumination versions are physically identical, but seem to have a more yellow cast Halo effect.
The ebay versions, again identical physically, seem to have a more purple blue cast. I prefer the autolumination version, but not enough to command nearly 2X the price.
#97
I kinda concur with this statement.
I emailed Autolumination about this, but they replied stating that they do not do a color test prior to shipping them out, so there's a chance that they won't match. My option was to buy another pair of bulbs and try to match it.
#100
Originally Posted by HiHenry.com
Can we use this
for all the interior/door lights?!
They don't work as well. Much larger than the SBL version, doesn't use the reflector as well.
Feel free to try it, but the SBLs perfrom better there.
#102
ok instead of making my own thread i figure id post my dilemma here. i have had a set of PIAA TERA 6000K Ultra White LED (9005) for awhile now. for a very short time it was in my RDX. i used it for my DRLs. of course the DRL light came on inside the car. i took it off because it got kinda irritating. just today i figure ill install it in my Type-S and see what it looks like. now for the problem. i installed one side then turned on the car to see what it looks like. looks good! of course the DRL light is on inside. then i did the other side. i went to turn on the car and both of them do not work and no DRL light inside. so i thought the LED was bad. reversed the lights and both work fine. anyone have any idea whats wrong? on the same note i figured out how to get rid of your DRLs without having a light go on in the MID...
#103
DNP,
I believe someone else had the exact same issue with the V-led DRL bulb. I think its because the DRLs are wired in series or something. he figured out a way to re-wire them on his 07. ill try to find the thread and link you.
#104
here's the link. SCV_76 did the conversion/mod for it:
https://acurazine.com/forums/showthr...highlight=DRLs
#107
#108
P/N for the door lights
Just ordered everything.
4x int lights - white
2x door lights - white
2x backup lights - white
2x vanity mirror - white
1x trunk light - white
2x license plate light - white
total came to around $116 ouch.
Not too sure if ALL WHITE on NBP is a good idea but we'll see hMm. if you guys convince me to get other colors ill return some of em =P
i will post before and after picture after i install them! thanks again guys. and thanks x100 to you Kennedy!
#111
Originally Posted by livndlife
Can someone tell me how to get to the license plate lights? Is it just peeling back the trunk lining? Thanks !
#114
ya i kinda wanted to do BLUE or RED door lights but just went with white all around to serve the "purpose" of the light i dunno if ill regret it or not
all white would def be good if u have a WDP but i have NBP so not sure (i have black 2toned int) so yeah we'll see =X ill post pics after i install em all
I've got all blue on my WDP, and they look amazing. 06 with the blue guages =).
It's McDonald's.... I'm lovin' it.
#115
Originally Posted by ityper
Hi thanks for the pictures. I wonder, the reverse lights, how bright would you say they are compared to the stock? Did the led's make a big difference as far as illumination?
#116
Originally Posted by kfhughes
I'm wondering the same thing. I've got Dom's backup unit with Wendy's camera and at night sometimes things are still too dark to see with the stock reverse lights. If these LEDs are noticeably brighter, then it would be worth the $40.
#118
hey guys im planin to order the leds really soon, but i was wonderin is 1 order a pair or juss one bulb per order, also do u guys think wled-x4 is good enough for license plate and interior lights? thanks for replys
#119
They usually come in pairs. Its usually described under product description.
