Check engine light flash on hard accel.
Old Nov 20, 2003 | 12:53 PM
bigdomer's Avatar
I know at least one other person here had this same problem. Check engine light flashes for about 10-15 seconds after hard acceleration. I bring it up again because there evidently is a TSB on this issue and the dealer needs to do an ECM flash to the computer on the TL. Thus, whoever had/has this problem may want to condsider taking it in. I doubt there is any risk of damage, but it is quite distracting to have yellow lights flashing at you when you are accelerating quickly.
Old Nov 20, 2003 | 12:57 PM
Sherlock's Avatar
there is risk.
get it in the shop.. pronto. It's not physical breakage damage, but if it's the same bug, then it's Misfiring. The misfire is due to a bad Crank Angle Sensor that fails at W.O.T.
What it does is passes unburnt fuel into the 3 catalytic converters, they can burn most of it, but it's not good for them to receive large amounts.
The fix is to replace the crank angle sensor.
Now, there could be another, and it'd be interesting to see what they're flashing. But on mine (ser# 259) and another guy's Eurolithe, it was the C.A.S.
Old Nov 20, 2003 | 07:22 PM
goblehipcom's Avatar
bigdomer, I don't have this problem but I was curious what the build number of your TL is...thanks.
-Scorpio
Old Nov 20, 2003 | 07:42 PM
bigdomer's Avatar
build #5555.
Dealer contends its not the CAS. We'll see if it is fixed tomorrow. They of course had to keep it overnight because their computer to flash the ECM was broken and they overcommitted their service for today and could not get my other fixes done. Thus, I have a TSX loaner. Pretty nice little car.
Old Nov 20, 2003 | 07:49 PM
Sherlock's Avatar
Crock of BS
what a load.. their computer is broken.. gimme a break.. Call Acura concerns in a week or two after you get the car back and they will have the real work order on what was ordered and fixed. They get a copy of all of it.
Old Nov 21, 2003 | 09:31 AM
need4spd's Avatar
an Acura has-been
Bigdoomer and Sherlock,
I guess I get to join the club with you and Eurolithe, my check engine light started flashing today, they went out.
I was getting on the parkway and holding it in 2nd gear with SS, unfortunatly there was trafic so I did not upshift, and was in the 4K - 5K range for about a minute, then the picture of the engine (check engine) light came on flashing, then went out a few moments later when I switched back to auto mode.
It was scheduled to go in on Monday anyway.
I will let them know about the CAS and Flash.
Wish me luck.
Sherlock, at least they give out TSX's as loaners, I know you had to beg for one, I guess ATL is not as friendly on that.
Old Nov 21, 2003 | 11:27 AM
bigdomer's Avatar
Sounds like the same problem. I get mine back today. I will let you know which way they fixed it and I will try to recreate the situation this weekend to see if I can get it to come on again.
Old Nov 21, 2003 | 11:49 AM
need4spd's Avatar
an Acura has-been
Thanks!
Old Nov 21, 2003 | 01:25 PM
blk04TL's Avatar
Happened to me
Same thing happened to me about 300 miles ago - I've tried to recreate the problem and hasn't happened again. Will keep an eye on it.
Old Nov 21, 2003 | 02:03 PM
need4spd's Avatar
an Acura has-been
I tried it again at lunch, this time the light came on and stayed on.
I will know monday I guess.
Old Nov 21, 2003 | 04:20 PM
GoBig's Avatar
It's happened to me and I called the dealer but the service department has never heard of it. Where can I find the TSB write-up on it so I can present it to the service department? I looked at http://www.alldata.com/recalls/index.html but there's nothing on it.
Old Nov 21, 2003 | 04:27 PM
need4spd's Avatar
an Acura has-been
Mine did not know about it either, he was going to call the tech line.
Old Nov 21, 2003 | 04:42 PM
bigdomer's Avatar
Honda TSBs are real hard to find since they do not release them like some other manufacturers. My dealer just guessed that the ECM upgrade might fix it. I do not think that he found a TSB.
Old Nov 21, 2003 | 04:56 PM
need4spd's Avatar
an Acura has-been
Did it work, you were to pick it up today?
Thanks,
Old Nov 21, 2003 | 06:12 PM
EmuMessenger's Avatar
I have found telling the service team I know about a problem makes them less willing to fix without "recreating" the problem.
Old Nov 21, 2003 | 08:10 PM
neuronbob's Avatar
I haven't had this problem. I use SS for engine braking in heavy traffic and have gone to 2nd accidentally a couple of times at 3.5-4k. Haven't noticed this issue. I tried WOT in the "D" setting a few times since I'm no longer in the engine break-in period and have not had any issues. Will keep you posted.
Old Nov 21, 2003 | 08:14 PM
I have 750 miles on my 5AT Build 8780 and have taken her close to redline a half-dozen times now that I am passed break-in (I use SS relatively frequently, just fyi). No CE lights yet, but I am keeping my eye on it as well.
-Scorpio
04 TL, AM/Quartz/5AT/Nav/Lip
94 RX-7, 308 rwhp@12psi
Old Nov 21, 2003 | 09:41 PM
bigdomer's Avatar
need4speed:
I tried hard accel a few times tonight and it did not come back on. I will keep pushing it over the weekend and let you know.
Old Nov 21, 2003 | 10:00 PM
need4spd's Avatar
an Acura has-been
-Scorpio
That never did it for me either, it was when it was kept above 4-5.5k rpms for 30-60 seconds when it happend, WOT is only there for a short time.
Bigdomer, thanks for trying and keeping me updated!
Old Nov 22, 2003 | 10:23 AM
I kept mine in second for about 30 seconds at 5000K, no light.
What's WOT?
Old Nov 22, 2003 | 10:36 AM
Originally posted by jgrahamiii
What's WOT?
WOT = Wide Open Throttle
Old Nov 24, 2003 | 12:19 AM
need4spd's Avatar
an Acura has-been
When my light came on, I was not at WOT, it was steady, and RPMS between 4k and 5.5k, FYI
Old Nov 26, 2003 | 08:44 PM
2k4TLkev's Avatar
R&D of Team Anthracite
hey need4spd...my engine light when on today, i was revving it to 5500 than the engine light blinked...it stay blinking for a good minute than stop...i dont think this is normal, have u or anyone got this taken care of by the dealer? i plan to bring it in on friday. Thanks
Old Nov 26, 2003 | 09:40 PM
need4spd's Avatar
an Acura has-been
2k4TLkev, it was in Monday and Tuesday, code was cyl 5 misfire. Tech line said to dealer to ONLY replace coil pack on cyl 5. I got it back yesterday, but did not have a chance to check it, other than to do a few WOT starts on to the highway, no light yet, but I did not have a chance to test it under the condition it went on in the first place. (I did not want to see the light on all weekend ) I will test it Sunday.
BTW - the first time it flashed and went off around 5k range, second time I did it, it STAYED on.
Some say it is the crank angle sensor, some say it is a reprogram of the PCM. Not sure they know yet, maybe the reprogram resets the trip point to a lesser range based on the CAS used in production???
Good luck!
Old Dec 1, 2003 | 07:51 AM
Turbowhat2's Avatar
Troublemaker
talked to service department and they said they heard about this problem. People were at first thinking it was hardware (such as Crankshaft position sensor), but Honda contacted them and said it was a software misfire code, and will reprogram new codes into my car.... the guy said it wasnt happening to all cars, so they arent fixing all of them, but just ones that are brought in.
Old Dec 11, 2003 | 09:34 AM
ulangca's Avatar
I started noticing it yesterday when doing hard acceleration between 1st & 2nd gears using the sport shift. It flashes then it goes away.
Turbowhat2...
was the reprogramming free of charge?
Old Dec 11, 2003 | 05:41 PM
Turbowhat2's Avatar
Troublemaker
yeah it was free... they also gave my car a free carwash for free too.
MikeYutkin
Sep 10, 2015 10:13 PM
Bahamanurse1
Sep 10, 2015 10:05 PM
HeloDown
Sep 8, 2015 06:51 PM
bryan zaragoza
Sep 8, 2015 12:28 AM
whitesoxsfan12
Sep 7, 2015 04:07 PM
