automatic transmission fluid change diy?
i try searching through the forum for a diy auto trans fluid change....after searching for awhile i couldnt find it and gave up
. can someone link or provide a diy for a atf change? and what is a 3x3 (i hear that alot in the forum but not sure what it is). Some people also recommend the redline atf fluid over the honda atf z1 -- where do you get the redline fluid from?
thanks.
. can someone link or provide a diy for a atf change? and what is a 3x3 (i hear that alot in the forum but not sure what it is). Some people also recommend the redline atf fluid over the honda atf z1 -- where do you get the redline fluid from?thanks.
There is a lot of information in the 3G Service Department formerly known as the 3G Garage. It is a 'sticky' on the main 3G page.
Here is the link from the Service Dept: https://acurazine.com/forums/3g-tl-2004-2008-93/rr-journals-atf-drain-refill-3g-garage-c-012-a-556044/
There are countless threads on Redline and where members can get it.
Kthai417, along from what ggesq posted, a "3X3" means to fill up the transmission fluid reservoir one time, drive for about five miles, empty and drain, fill it up a second time, drive for about five miles, empty and drain, and fill it up a final time. This gets out all of the dirty ATF from the system.
here's my thread i did not to long ago...might help.
https://acurazine.com/forums/3g-tl-2004-2008-93/my-30-000-mile-service-loads-pics-video-777798/
The RR Journals: ATF drain and refill 3G Garage #C-012 (click here)
C-026: DIY Changing ATF (with Pics) (click here)
Racing ATF (click here)
Time to change transmission fluid? (click here)
AMSOIL Synthetic Transmission Fluid VS Redline D4 ATF (click here)
Did a 3x3 today with Redline D4, with some first impressions (click here)
Tranny fluid change at 17k? (click here)
Auto-trans fluid change method? (click here)
mada51589
Jan 9, 2025 04:40 PM
nanos
Nov 12, 2015 08:41 PM
Mike Bertram
Sep 10, 2015 09:27 AM
HeloDown
Sep 8, 2015 06:51 PM
Kudos!
