The 3G Ramblings & General Discussion Thread (Trois)
#5081
3 miles per gallon = 300 smiles per gallon (rounded up to the nearest sh*t stained underwear).
I know the feeling though...when you get done doing something really awesome and you didn't jump a curb or flip the car and for a split second as the adrenaline is leaving you finally try and decide if you just had fun, got really fuking scared...or both.
#5083
My heart was pumping extra heavy the other day sitting in my cube just thinking about lighting up the tires. #cardio
#5085
BTdubs.. I hit reverse the other day and put my foot into the throttle because the the TL was sluggish AF in reverse. I think I got small kine whiplash.. and almost pulled a spacejam and hopped the curb.. I think it accelerates in reverse faster than the TL going forward.
justnspace (03-27-2015)
#5087
Justn.. if we did j turns in the 24 hour parking lot.. this might be the result.
#5088
Registered Bunny
Majofo (03-27-2015)
#5094
I'm getting too confident at this point.. I'm trying to be chill.
I meant it was a dog in reverse.. not slow to engage.
Franchise1124 (03-27-2015)
#5095
Confusing Name Guy
Iunno, mine is perfectly fine *knocks on wood*
In fact shifts in sport mode are surprisingly quick given all of the hate it gets
We'll see what it feels like after I go with Redline Type F + change the 3rd and 4th pressure switches
#5097
Registered Bunny
In slow in both terms. The slow engage is my pressure switches, obvs, from my 2nd to 3rd being harsher than normal. Still, 5AT on the V6 Hondas... god.
#5098
Confusing Name Guy
#5099
Registered Bunny
Used to be mighty fine, then... well it wasn't fine. I blame winter. I'm keeping it soft until I get to do the switches. Then I'll 3x3 this mofo. Don't have access to a garage though unless I bug my uncle about it and CBA rolling around in slushy snow to do shit like this obviously.
#5100
Confusing Name Guy
It's interesting because while the shift from 2nd to 3rd when using sport mode is definitely noticeably more "firm", its 100% smooth in auto for me - in fact its not really all that noticeable even when I'm looking for it. Now manually downshifting from 3rd to 2nd ... definitely harsh
#5102
Reverse and 2nd to 3rd doesn't involve pressure switch. It could be actuator, otherwise it's fluid and mechanical effort. Don't mix fluids.. what fluid are you on now and when did you change it?
#5103
Confusing Name Guy
#5105
Confusing Name Guy
Maj I'm curious as to what the pressure switch change does then? I get that it wouldn't do anything for reverse being slow to engage (that one seems like a no-brainer to me at least) but lots of people have said that their shifts from 2nd to 3rd were significantly smoother with an ATF swap and new pressure switches... or would that be primarily from the new ATF?
#5107
1-2-3 is actuator + accumulator + mechanical, no switch engagement. 3-4-5 engages switches at a certain line pressure, you change the switches because the spec on switch activation gets sloppy. There's nothing wrong with Honda ATF. Just don't drive 100k miles on it without changing it. Change it at least every 25-30k miles.
#5108
Just be careful with the ATF fill plug when popping it. I believe crabs had an issue with his fill plug at some point.
Otherwise changing your ATF is easier than changing your oil IMO.
#5109
Confusing Name Guy
#5110
he did the work, i was just supervising (like always ) and he broke the fill plug...cracked the threads to the tranny case by using a breaker bar.
wasnt able to screw the plug back in because the threads were missing on the tranny case.
#5111
Well.. that's a loaded question. If it's old ATF.. it might only be running because the fluid is nice and thick. datass.jpg
Honda ATF is fairly thin. So.. if there is a mechanical issue already, the thin stuff will polarize it. If your car has a history of ATF changes, you shouldn't worry. If you have +100k miles on it with no record of change.. might want to just let it run into the ground. Otherwise do a change and fill, drive around for a while just to make sure it's not problematic before doing further change and fills.
#5112
my friend had an auto TL and came to me because of my garage..
was his name Murphy?
I apply a certain pressure with impact extensions and breaker bar.. if it feels too tight, I tighten a bit then take a hammer to exert quick pressure to pop it.
#5114
Registered Bunny
3rd gear pressure switch engages at a much lower pressure because it's fucked. Car flicks to 3rd gear when it shouldn't. Grabs when it shouldn't, pretty much. Or at least that's what I heard.
Either way, I need to do both because this shit breaks apart. It's not a the slipping stage yet, but I imagine it would soon be. Used to be fine prior to winter, isn't so fine now.
I keep on putting off doing the 3x3 myself but it needs to get done for my own peace of mine - I just recently did my first oil change after picking the car up in November and in all honesty I think I just got very lucky with my purchase because like my mechanic said, the maintenance records check out like an A+ student's transcript, but seeing as the ATF stuff and the switches aren't listed as regular maintenance at the dealership, I'm sure its still riding on Honda ATF.
Edit: Nvm, well lol, yeah ain't gonna do that.
#5117
Confusing Name Guy
#5118
funny enough, his name is Justin. we worked together at some point in time and I didnt know he bought a TL.
he Dumped the TL shortly after that and picked up a G8.
dont know if it's the GXP in six speed or not, we lost contact.....probably because of fill plug incident.
#5119
Confusing Name Guy
Its a shame really because I think its an awesome car - I was considering one before the TL, but just couldn't find a V8 G8 with low mileage in Ontario or Quebec.
Honestly, would rather own a G8 versus a vette - same engine but all the creature comforts of a sedan
#5120
Redline and D4 mix bullshit. Everyone do yourself a favor and use D4 or stick with Honda ATF.
