The 3G Ramblings & General Discussion Thread
Actually.. changing that filter would be a great idea as well. Also easy.
takin care of Business in
Received 4,732 Likes
^^^ that is the transmission filter....
here are the pix of the fill bolt...
where the arrow ends, thats your transmission filter....
The fuck Anil.. you buy your TL from the Pacific Ocean?
The following 2 users liked this post by Majofo:
SharksBreath (01-15-2013),
Undying Dreams (01-15-2013)
And you thought your transmission was bad Wacky.
:what:
Thanks Anil. As you can see in my first pic, that hole is taken by a tube. Im not taking that apart due to not having the appropriate o-rings to put it back together properly. I filled through the dipstick tube.....wasnt much of a problem....long funnel + the wife's turkey baster....perfect. Doing the switches now.
switches before refill because you will loose a little bit of fluid from the switches....
and Majofo, my car has always been like that, not sure why or where that corrosion is coming from
Road salt
Hardly any fluid loss from switches.. plus.. you're putting in more fluid than you drain so it equals out.
Chapter Leader (Midwest Region)
@Majofo
^^^ whatever happened to the precision???
also before measuring the fill using the dip stick, do go for a drive....switch into every gear, including reverse.....stay in every gear for around a minutes to get some new fluid in there.....
head home, park on a flat surface, check the fluid level...
Why u fuq'n me? I didnt do anything.
Anil: D8
@Majofo
Matt, I have a bad habit of not using quote and using ^^^ and you posted in the middle
and besides, you no like me fuqqing u ???
McCollins23 (01-15-2013)
:what:
John, havent spoken to you since that bad day...butt how are you feeling?
I'm assuming since you're crawling underneath the car that you're fine
2 drops?
picture taken from this thread:
https://acurazine.com/forums/3g-tl-2004-2008-93/110-diy-guide-replacing-3rd-4th-gear-pressure-switch-3g-tl-2004-2006-a-729149/
Notice how I come in there and educate everyone.
Also.. looks like two drops to me.
^^^ bish I went out in the cold to get pix for Wacky
gimme back that brownie point
Can we stop this tranny talk and start talking about what really matters!
We need to have an intervention with Justin who may or may not be dating a dude from NY
Wouldn't be the first time for Justn. True story.
:what:
I feel good other than nagging pain in my neck. It seems better every day though.
Mine didnt loose as much as in that pic...I think that pics fluid loss is diluted and looks worse due to the brake clean wash down..
First impressions on test drive....shuddered at first then slowly went away. Shifts are much more crisp, but that wasnt the complaint.....it was the torque converter lock up shudder.
gonna do at least two more drain/fills today. I need to go get an air filter, but the roads are icing up.
Look at this fluid!!!!
dont do the rest of the drain and refill today....drive it just a little bit more....wait maybe another day or so....
but you are the best judge of the situation...
:what:
Too late baby!!! Second drain had a bit better coloring but not by much. One observation: refilling with DW1 is easier than the type f. The DW1 seems thinner believe it or not. It's cold in the shop too (middle of an ice storm).
on the viscosity !!!
did you drive in every gear?
I remember seeing this video for a Honda Accord....I bet we can do something similar with the TL....
Received 6,470 Likes
Strangely.. it's not what you think Steven.. don't worry.. we'll get back to talking about "Trannys" again.
:what:
Interesting Anil. Somehow I feel I've wasted money today now.
And Majofo. I missed your post earlier about the banjo fitting. Yes...the tube does go to it. The hose that comes out of the "drain plug" goes into it with a T fitting.
haha i feel the same way when doing more than 1 drain and refill on the tranny....hence I keep a slightly longer interval than 5 minutes
but yeah if you are getting shudder, then well, it might a good reason to do another drain and refill after a nice drive....
http://www.youtube.com/watch?v=MsdPAadc9fY
:what:
I took a 20 mile round trip to get an air filter...yes I live that far out in the sticks. It acted up a little again once warmed up only not near as noticeable. I immediately did a third drain and fill when I got home. The fluid is still crazy dirty..after the 3rd drain and fill and another test drive to full warm up I could only get it to act up once and it was so mild I thought I may have imagined it. I have enough fluid to do one more drain and fill. The fluid is still dirty, but it is improving performance wise and cleanliness wise.
Anil. I looked for lines to allow us to do the youtube flush.....didnt see any. Do our cars not have trans coolers?
Yes, a 3x3 is recommended ...always....to get most of the old fluid out and new fluid in....
I think when you start the car maybe the car pushes out the fluid from the torque converter.... hence flushing out all the old fluid while u fill in new fluid...
Think about it, the automatic transmission capacity is 7.8 qts but you have to do a 5x3 in order to have more than 90% new fluid.... someday i would like to follow the video and do a flush and use only 9-10 qts of fluid....
Wacky, damn man....wish the final drain and refill will solve everything....make sure you engage reverse more than once...
What fluid are you using? Still on Redline?
No "external" cooler. . I will be installing one soon....the type s models do have one though. ...feel like stealing Stevens every time I work on his car lol
:what:
I will spend some time in Alldata this evening to see if there is a way to do a thorough flush like the video.
you should have used Redline on just Honda....or Amsoil ATF (If I reckon right, IHC was on Amsoil ATF for a while before switching to Redline).....
either way keep us updated....
btw, we can do a flush like in the video...just find the hose with 2 banjo fittings as in this thread (the pic is missing but I think you get the idea)
https://acurazine.com/forums/3g-tl-2004-2008-93/116-diy-transmission-cooler-5at-magnefine-filter-lots-pics-754752/
