2019 RDX Suspension Travel Noise - Front Left
Old Aug 3, 2019 | 05:21 PM
  #81
altayar's Avatar
They said once they adjusted the hatch on the loaner car it fixed the pop noise. However, adjusting the hatch didn't solve the popping sound on my car. I still think its a spot weld from the upper left pillar in the back.
Old Aug 3, 2019 | 10:41 PM
  #82
Dereileak's Avatar
Like a bad spot weld? Do you have a picture
Old Aug 4, 2019 | 08:52 AM
  #83
subin's Avatar
Thanks for reporting back. For whatever reason, mine happened a lot less now since March this year. Could be due to the weather is getting warmer.
Old Aug 6, 2019 | 02:42 PM
  #84
altayar's Avatar
No pictures: Dealership can't figure it out even though the tech who came to my house heard the pop sound more than once. Go figure. So now im onto Acura Client Relations.
Old Aug 7, 2019 | 12:29 PM
  #85
Ricky Diaz's Avatar
Originally Posted by wnally
Vehicle: 2019 Acura RDX SH-AWD with Technology Package
Miles: Approx. 1000
We noticed front end "suspension travel noise" going over speed bumps at approx. 7 miles per hour. The dealer replaced faulty (noisy) left front strut - the noise has not changed. The dealer stated that this noise is normal for this vehicle. The noise is similar to the noise an older car would make, sounds like a good lubrication is needed, however the dealer has performed lubrication as well.
We don't believe this is a normal sound this vehicle should make.
Please let me know if your RDX makes any suspension travel noises over speed bumps.
Thank You
yeah i have a 2019 a spec rdx same noise left front rattle. i brought it in they couldnt very the noise i told them im a tech for another company. the noise is there. they ended up replacing the sway bar links and both lower control arms. i thought great noise is gone im happy... yeahhh that was short lived till i heard the noise again. its a very annoying noise also
Old Aug 29, 2019 | 07:46 PM
  #86
Ricky Diaz's Avatar
i had the same noise coming from the left front. they changed the control arms and sway bar links. it was good for about 2 weeks and then bam noise came back. same sound same area.
Old Sep 29, 2019 | 01:49 PM
  #87
Taylola's Avatar
Poppong noise from left rear
2019 RDX, 6,000 miles: The popping noise happens when I drive down my driveway and when the left rear tire goes off the driveway lip and I turn left onto the street. The pop noise sounds like it is coming from the drivers side rear area. Warm and cold temperatures.
Ive been having the exact "popping" noise which I described as a "clunk" or "pop" to my Acura dealer, under the same circumstances on my 2019 RDX Tech. I told them it sounds to be possibly coming from the left rear strut. They took it on a test drive and thought it might me coming from a loose screw on the rear license plate, so they tightened that.🤣. I knew that wasn't it and the noise continues.
Old Sep 30, 2019 | 07:59 AM
  #88
Ricky Diaz's Avatar
i just started getting that pop noise in the rear same way your getting it. but it doesnt happen all the time. i know my tailgate is rattling when i hit bumps. i still have the front suspension noise and a noise from the passenger side headliner area. i bring it to the dealer they cant verify it. and these noises are consitant.
Old Sep 30, 2019 | 11:53 PM
  #89
-AoW-JP's Avatar
I get a clank noise when backing out of the driveway. The temp is just starting to drop here. While driving it’s good so far. Bronx roads so the suspension is getting a workout.
Old Oct 1, 2019 | 12:20 PM
  #90
Ricky Diaz's Avatar
im in long island. i feel you on those ny rfs. they arent very forgiving lol
Old Oct 14, 2019 | 11:41 AM
  #91
luvacura3's Avatar
Bought my ASpec RDX in March just noticed my suspension making noises with the cold weather coming. Going to wait until 1 yr warranty is closer as noise is not to bothersome yet. This is my 3rd RDX and by far it it iS the best one yet
Old Oct 20, 2019 | 09:41 PM
  #92
mike232232's Avatar
So my 2019 RDX Advanced makes a loud POP noise also when pulling out of the driveway, it is very loud and usually only happens once intermittently. Dealear says can't reproduce and nothing wrong. I can hear the noise clearly about 50% of the time when pulling out of the driveway or sometimes when driving over railroad tracks but that's it. Anyone got that fixed successfully?
thx
Old Oct 21, 2019 | 04:23 PM
  #93
altayar's Avatar
thx
Yep, posted the same a few months back. Dealership knows it exists, because they had a tech come to my house to listen to it. However they can’t replicate it at the shop, in order to fix it. I’ve taken it in several times. Dealership told me Acura is aware of it because of my complaints in my car and the 2019 RDX loaners I’ve had.
simply annoying....
Old Oct 21, 2019 | 11:49 PM
  #94
mike232232's Avatar
Acura knows about it is simply unacceptable to me anyway, I will record the noise and will escalate this as high as I can, this is not normal behavior of 50K car, we know about it but can't replicate is not good enough but my dealership hasn't said that yet. Please post if you get it resolved and I will do likewise.
Old Oct 22, 2019 | 07:00 AM
  #95
altayar's Avatar
Please update, if you get further than I did, as far as what can be done to fix it, or other options that are available. I still think its a spot weld issue. I too have recorded the noise several times, as I have over 15 recordings. I do have an agent from Texas Lemon Law woking my case. Next steps are arbitration with American Acura / Honda. This could take several months, plus no guarantees.
Old Oct 22, 2019 | 10:24 AM
  #96
hockeyaddict's Avatar
Originally Posted by stephensils
For those that got their struts or control arms changed... how is the road travel noise now? I brought mine to the dealership with the same noise complaints, only to have them "lube" up the front struts. Told the tech that it ain't going to fix it, so we'll wait and see. So far, been to the dealership far too many times for a brand new car.
Been six months since I had the control arms replaced and lubed. No noise since.
Old Nov 15, 2019 | 09:09 AM
  #97
russianDude's Avatar
Seems like I am getting some small squeak going over speedbumps on driver front side...
I am afraid dealer will say he cant reproduce as its very small noise
Old Nov 16, 2019 | 10:03 AM
  #98
UPDATE: Went to dealer, replaced lower arm driver side, the noise is gone. They think it was defective from factory.
Old Nov 16, 2019 | 11:44 AM
  #99
My car was made on 10/19, so you would think that old part was already 51360-TJB-A04 (updated)? To add to confusion, parts cross reference lists 51360-TJB-A04 for 2020 RDX, and 51360-TJB-A03 2019 on oemacuraparts.com and others. why?
Old Dec 11, 2019 | 11:06 AM
  #100
Cesar Maldonado's Avatar
2019 Acura RDX aspec
My car is doing the same thing but it’s all over front and back so far they have replace strut and control arm and still nothing as type this I’m in the dealer again with corporate looking at the car
Old Dec 11, 2019 | 11:09 AM
  #101
It still making noise
After having a few parts changed the noise this exists so far Acura has no clue what to do I’ve been back and forth to dealer for over 2 months
Old Dec 11, 2019 | 12:26 PM
  #102
Yeah, I heard some creaks over speed bumps even after they replaced it, but then it disappeared, would need to go there when they can hear it
Old Dec 11, 2019 | 08:33 PM
  #103
coffeemaker's Avatar
I have a three week old 2020 and have noticed this issue as well.
Old Dec 11, 2019 | 08:51 PM
  #104
seems to be getting worse in cold, it’s also may not be easy to reproduce. It needs to be reproducible for dealer to do anything, so annoying.
I first heard it in the front driver side, it was pretty obvious, so they replaced lower arm. No I hear something similar in the passenger side, but it’s very faint and I am not sure they will do anything.
Old Dec 11, 2019 | 08:53 PM
  #105
There are multiple speed bumps at my child's school and I hear it every single time, so it should be reproducible. I think it is front driver side too, but sometimes I have trouble determining where a sound is coming from. In any case, my liftgate makes a gun shot sound when it rises, so I think I will bring it in for both issues.
Old Dec 16, 2019 | 06:56 PM
  #106
Could hear it on a speed bump, made appt with the dealer. Its sounds like rusty strut movement, if my dealership does not have speed bump, how the heck can they reproduce it. What if they tell me its normal for this suspension? I dont think its normal
Old Dec 16, 2019 | 08:52 PM
  #107
Leaf 68's Avatar
Find a speed bump close by the dealership and take the tech with you to replicate the noise... that is what I did. It is the Lower Control Arms.. Make sure they do a 4wheel alignment under warranty too. The repair will throw the alignment off.
Old Dec 16, 2019 | 08:56 PM
  #108
Leaf 68's Avatar
This is a common issue and It is not normal..mine started making the suspension travel noise 14 months after I bought my RDX. After the Lower Control Arms were replaced 2weeks ago the vehicle sounds like it did when new.
Old Dec 16, 2019 | 09:26 PM
  #109
yeah, I had driver side lower arm replaced already, but not the passenger, so I think it’s going too.
Old Dec 18, 2019 | 07:40 AM
  #110
Tried it again today on the same speedbump, no noise... must be related to moisture or temperature, might have to cancel my appt since they will not do anything if they cant reproduce
Old Dec 18, 2019 | 01:34 PM
  #111
Leaf 68's Avatar
My noise was temperature related, between about 32F and 45F. If it was too cold the noise went away.
Old Dec 18, 2019 | 09:02 PM
  #112
interesting, I was thinking it’s more happening when it’s wet outside, it was colder than usual today
Old Dec 19, 2019 | 12:19 PM
  #113
Creaked again today at 20F, now I dont know what
causes it.
Old Dec 19, 2019 | 06:06 PM
  #114
Leaf 68's Avatar
Keep your appointment and take it in. Tell them about your many many friends on Acurzine With the same noise and that the fix has been replacing the lower control arms & a wheel alignment. The day I took my RDX in the front suspension wasn’t creaking but did on the way home, so I went back to the dealership and asked to take the technician with me to verify the noise. I told him what I thought the fix was (Based on the info on Acurazine) and they ordered the parts right then and there..
Old Dec 19, 2019 | 06:33 PM
  #115
yeah, they should have just replaced both of lower arms, they only did one, so no its another one.
Old Dec 19, 2019 | 09:15 PM
  #116
I just picked up my car today -- they replaced both lower arms. I think first they tried to do something with the original arms, but that didn't work and they ended up replacing it. I asked about alignment twice, and they said that the arms are simply bolted in and didn't require re-alignment, so they wouldn't do it.
I noticed the sound mostly on speed bumps in cold weather, and haven't had a chance to try it under those conditions yet, but driving around this afternoon, I didn't hear anything.
How would I know if the alignment is off?
Old Dec 19, 2019 | 09:29 PM
  #117
They did alignment on mine. If you have bad alignement the car will not go perfectly straight and will tend to go left or right.
They updated parts for arms, I am surprised that 2020s have old parts or its new parts going bad already?
Old Dec 21, 2019 | 08:31 AM
  #118
What I want to understand is this:
new parts were updated around March 2019, my 2020 car was built in September 2020, I would expect it to have updated parts? If yes, why are they still failing. They gave me 2020 RDX loaner with 1000 miles, and it makes the same noise.
Old Dec 22, 2019 | 12:10 PM
  #119
sonyfever's Avatar
I would request to have alignment done, as it is part of the factory SOP after changing control arms.
Old Dec 23, 2019 | 08:15 AM
  #120
Picked up my car, so far so good. I am hoping that my 2020 got updated parts, otherwise it would mean that updated parts are also failing.
the scary part, I had 2020 loaner with 1k miles making horrible suspension noises, much worse than what I had. Is it a part issue, or install issue at factory?
