Tailgate open beeping
Old Apr 11, 2021 | 12:01 PM
JB in AZ's Avatar
Anyone know how to stop the tailgate open beeping? I was rear ended. Click to see pics in Post #133 and 143 The car is drivable, and gate is closed, but sensor doesn't think so. I will need to drive the car to the body shop, which will likely be 30-45 minutes. The beeping is very annoying, and surprisingly, is also heard outside at the rear. There must be a wire I can clip or disconnect? Thanks!!!
Old Apr 11, 2021 | 01:34 PM
Madd Dog's Avatar
Maybe set System-System Volume to as low as it goes?
Old Apr 11, 2021 | 03:46 PM
Ron T's Avatar
Someone posted this link in another thread. https://acurazine.com/forums/3g-rdx-.../#post16321156
Hopefully it helps.
Ron
2020 RDX SH-AWD Advance
Lunar Silver with Ebony interior
Old Apr 11, 2021 | 11:34 PM
FunToDrive's Avatar
I would guess if your hazard lights are on (that was how gen 2 worked). Though then your hazard lights are on.
Old Apr 12, 2021 | 09:12 AM
JB in AZ's Avatar
Appreciate the replies so far. What I am hoping to stop is the audio (beeping) ALERT that notifies the driver that the tailgate is not closed. This may or not be the same beep that alerts when the tailgate starts closing. Thank you..
Old Apr 12, 2021 | 07:27 PM
JB in AZ's Avatar
One of the collision center estimators was able to close it more forcefully than I could and the beeping is gone, for now.
Old Jul 27, 2024 | 12:35 PM
the4ner's Avatar
9th Gear
Did that solve it permanently? Having a similar issue where the trunk is closed but the car thinks it is open & beeps nonstop. (Internal system beeps, not the loud opening/closing beep)
Old Jul 27, 2024 | 03:16 PM
John from PA's Avatar
I'm assuming you mean the 2020 Advance which I think comes with the hand free opener. If so double check the settings at Home screen. Select Settings > Vehicle > Power Tailgate Setup > Hands Free Access Power Tailgate > On.
To exit, press Home or Back. If it is set the way you like it I would purposely set it to something else, turn OFF the ignition, then go in and reset it the way you like. This often provides a reset function to a setting that although it appears to be correct, is corrupted.
Legend08
Feb 27, 2021 02:31 PM
Michael Foerster
3G RDX Performance Parts & Modifications
Jun 3, 2019 12:35 PM
getakey
3G MDX (2014-2020)
Oct 11, 2017 08:59 PM
AcuraJTL
Dec 1, 2013 05:59 PM
stlgasman
Nov 20, 2003 08:34 AM
