Tailgate open beeping
Anyone know how to stop the tailgate open beeping? I was rear ended. Click to see pics in Post #133 and 143 The car is drivable, and gate is closed, but sensor doesn't think so. I will need to drive the car to the body shop, which will likely be 30-45 minutes. The beeping is very annoying, and surprisingly, is also heard outside at the rear. There must be a wire I can clip or disconnect? Thanks!!!
Someone posted this link in another thread. https://acurazine.com/forums/3g-rdx-.../#post16321156
Hopefully it helps.
Ron
2020 RDX SH-AWD Advance
Lunar Silver with Ebony interior
Hopefully it helps.
Ron
JB in AZ (04-11-2021)
Appreciate the replies so far. What I am hoping to stop is the audio (beeping) ALERT that notifies the driver that the tailgate is not closed. This may or not be the same beep that alerts when the tailgate starts closing. Thank you..
GW208 (04-12-2021)
To exit, press Home or Back. If it is set the way you like it I would purposely set it to something else, turn OFF the ignition, then go in and reset it the way you like. This often provides a reset function to a setting that although it appears to be correct, is corrupted.
Legend08
02-27-2021 02:31 PM
