Emissions System Problem
Old Aug 11, 2019 | 12:59 PM
hdellenger's Avatar
6th Gear
Anybody get this message and know what it may mean. "Emissions System Problem. Power May be Reduced. See your dealer."
2020 Tech with 720 miles on it.
Had driven it about 5 miles and it came on after starting to go from a stop light.
And so it begins I guess.
Old Aug 11, 2019 | 02:04 PM
mathnerd88's Avatar
Bring it to a dealer. There’s no way we would know from what you’ve described or what the computer tells you.
Old Aug 11, 2019 | 02:08 PM
hdellenger's Avatar
6th Gear
Thanks, bringing it in Monday morning. Was just wondering if others had seen this issue early in their ownership of the RDX.
Old Aug 11, 2019 | 03:25 PM
ceb's Avatar
ceb
When did you last gas up?
Old Aug 11, 2019 | 03:37 PM
hdellenger's Avatar
6th Gear
I put just short of a full tank of premium on Friday, so 2 days ago. (I had a gift card to finish off, so did get to completely full, if that matters)
Old Feb 9, 2020 | 03:20 PM
Farcus's Avatar
Did you ever get a reason why this happened. Mine just came on at 6k miles.
Old Feb 9, 2020 | 07:40 PM
ceb's Avatar
ceb
The most common reason for this on a new'ish car is the gas cap. If the cap isn't closed properly (or the door on capless cars), then the car can throw a code. Check the gasket to make sure that there is no debris there and (with a cap) make sure you tighten it until it clicks a couple of times.
Take the cap off, put it back on and remember that it can take several start cycles to clear the code.
Old Feb 9, 2020 | 08:22 PM
russianDude's Avatar
does the car run fine? Maybe bad gas?
Old Feb 9, 2020 | 08:23 PM
mathnerd88's Avatar
The RDX doesn’t have a gas cap. It’s capless.
Old Feb 9, 2020 | 09:01 PM
ceb's Avatar
ceb
Sure. You still need to check the gasket for debris.
Old Feb 9, 2020 | 11:02 PM
hdellenger's Avatar
6th Gear
When mine happened they took the back seat out and checked something related to the fuel, but found nothing wrong. The good news is that it has never come back, so hopefully yours won't either.
Old Feb 9, 2020 | 11:47 PM
sonyfever's Avatar
Emission System Problem always comes with OBDII code(s). So if you have a OBDII scanner, you can read the code(s) and immediately know what went wrong without visiting dealership.
Old Feb 10, 2020 | 10:21 AM
ceb's Avatar
ceb
and most autoparts stores (Autozone, Advance Auto, Pep Boys etc.) will scan your car for free in a couple of minutes.
Fritchit58
2G RDX Problems & Fixes
Mar 13, 2024 11:24 PM
Bob Violence
3G RDX (2019+)
Aug 22, 2019 12:12 PM
S_K
3G RDX (2019+)
Jan 24, 2019 04:57 PM
babyduke
3G MDX (2014-2020)
Mar 20, 2018 07:05 PM
leo
1G TSX Problems & Fixes
Jan 2, 2009 10:54 PM
