Second Generation TSX Suspension Information
This is a compilation that I have from my research for the CU2/CU4 folks. Not exhaustive, as these are only products that I have looked up and I also want it to cover other things as well like OEM part numbers, chassis bracing, camber/toe adjustment kits, etc. but it's a start.
I'm pasting the information I have to date below, but also have it in Word if anyone wants to add anything. I guess I'll have version control and will just provide updates in subsequent posts within the thread since we can't edit our own posts after some time, I think. Not gonna do vendors and pricing info since that changes pretty frequently, but feel free to post that in here.
Feel free to send or post any comments or additional information. Thanks.
dave_88 (09-17-2014)
![](https://acurazine.com/forums/images/maestro/buttons/collapse_tcat.gif)
Popular Reply
11-08-2011, 11:42 AM
Useful discussion topics:
DIY spring install
https://acurazine.com/forums/2g-tsx-tires-wheels-suspension-300/diy-tein-s-tech-cu2-809439/
https://acurazine.com/forums/2g-tsx-tires-wheels-suspension-300/mrotocinclus-springs-replacement-journal-824807/
How to improve handling without lowering:
https://acurazine.com/forums/2g-tsx-tires-wheels-suspension-300/best-way-improving-handling-without-lowering-car-826238/
Lowering + camber adjustment
https://acurazine.com/forums/2g-tsx-tires-wheels-suspension-300/those-lowered-you-might-want-get-rear-camber-kit-759368/
https://acurazine.com/forums/2g-tsx-tires-wheels-suspension-300/do-we-need-alignment-kit-if-installing-springs-806738/
What coilovers should I get?
https://acurazine.com/forums/2g-tsx-tires-wheels-suspension-300/best-coilovers-2010-tsx-802476/
https://acurazine.com/forums/heeltoe-automotive-365/tein-ht-spec-megan-h-r-what-coilovers-should-you-get-801396/
Megan coilover review:
https://acurazine.com/forums/2g-tsx-tires-wheels-suspension-300/megan-racing-coilover-review-777550/
https://acurazine.com/forums/2g-tsx-tires-wheels-suspension-300/bbs-megan-ez-coilovers-836497/
How do different rims affect power:
https://acurazine.com/forums/2g-tsx-tires-wheels-suspension-300/how-do-rims-affect-power-delivery-834758/
https://acurazine.com/forums/2g-tsx-tires-wheels-suspension-300/stock-vs-aftermarket-wheels-my-observations-820000/
Impressions after lowering:
https://acurazine.com/forums/2g-tsx-tires-wheels-suspension-300/impressions-after-lowering-car-752205/
Lowering for wagons:
https://acurazine.com/forums/2g-tsx-tires-wheels-suspension-300/wagon-coilovers-822656/
https://acurazine.com/forums/2g-tsx-tires-wheels-suspension-300/lowering-options-wagon-834322/
Wheel and tire fitment (indirectly related to lowering):
https://acurazine.com/forums/2g-tsx-tires-wheels-suspension-300/wheel-tire-fitment-resources-821398/
DIY spring install
Suspension Upgrades for CU2/CU4 TSX
Springs:
Tein S-tech (lists 2009+)
Drop - 1.6 inches front 1.4 rear, PN SKB90-AUB00
Spring rates – 7.8 kg/mm front 4.1 kg/mm rear
Tein H-tech (lists 2009+)
Drop - 1.1 inches front 0.7 rear, PN SKB90-BUB00
Spring rates – 7.1 kg/mm front 3.8 kg/mm rear
H&R (lists 2009+)
Drop - 1.3 inches front 1.3 rear, PN 50152
Eibach (CU2 and CU4)
Drop CU2 – 1.0 front 1.0 rear, PN 4077.140
Drop CU4 – 0.8 front 0.8 rear, PN 4079.140
Progress (lists 2009+)
Drop – 1.2 front 0.8 rear, PN 40.0105
Spring rates – 7.0 kg/mm front 4.0 kg/mm rear
Coilovers:
H&R (lists 2009+)
Drop range - 1.2 - 2.4 inches front, 1.0 - 2.0 rear, PN 50153
Tein Basic (CU2 and CU4 apps listed separately, drop range slightly different but PNs are the same)
Drop range CU2 0.7 to 2.1 front, 0.1 to 2.1 rear, PN DSB90-LUSS2
Drop range CU4 0.9 to 2.3 front, 0 to 2.1 rear, PN DSB90-LUSS2
Spring rates– 10 kg/mm front 5 kg/mm rear
Other notes: Uses OEM upper mounts
Tein Super Street (CU2 and CU4 apps listed separately, drop range slightly different but PNs are the same)
Drop range CU2 0.7 to 2.1 front, 0.1 to 2.1 rear, PN DSB90-KUSS2
Drop range CU4 0.9 to 2.3 front, 0 to 2.1 rear, PN DSB90-KUSS2
Other notes: Uses OEM upper mounts, EDFC available
Megan Racing Street Series (lists 2009+)
Drop range not specified, PN MR-CDK-HA08
Spring rates - 10 kg/mm front 6 kg/mm rear
Other notes – Fully assembled, utilizes pillowball upper mount, dampers accommodate +/- 2 kg/mm spring rate differences, 32 damper settings
Megan Racing EZ Series (lists 2009+)
Drop range not specified, PN MR-CDK-HA08-EZ
Spring rates - 10 kg/mm front 5 kg/mm rear
Other notes – Fully assembled, utilizes aluminum upper mount, 15 damper settings
BC Racing (lists 2009+)
Drop range not specified, PN BR A-26 TSX
Other notes – Fully assembled, utilizes pillowball upper mount, 30 damper settings
Shocks/struts:
Koni Yellow
Left PN 8041 1406LSpor
Right PN 8041 1406RSpor
Rear PN 8041 1407Sport
Some URLs:
http://www.hrsprings.com/scripts/appguide.php
http://www.progressauto.com/products/sfID1/71
http://performance-suspension.eibach...cation_look_up
http://www.meganracing.com/product_page.asp?catid=28
Springs:
H&R (lists 2009+)
Coilovers:
H&R (lists 2009+)
Shocks/struts:
Koni Yellow
Some URLs:
The following 21 users liked this post by Puppetmaster:
bagwell (02-11-2013),
gaTorSXtasy (03-12-2013),
Glepage22 (08-13-2014),
jeroplex (11-08-2011),
live2hit01 (11-08-2011),
and 16 others liked this post.
DIY spring install
https://acurazine.com/forums/showthread.php?t=809439
https://acurazine.com/forums/showthread.php?t=824807
https://acurazine.com/forums/showthread.php?t=826238
https://acurazine.com/forums/showthread.php?t=759368
https://acurazine.com/forums/showthread.php?t=806738
https://acurazine.com/forums/showthread.php?t=802476
https://acurazine.com/forums/showthread.php?t=801396
https://acurazine.com/forums/showthread.php?t=777550
https://acurazine.com/forums/showthread.php?t=836497
https://acurazine.com/forums/showthread.php?t=834758
https://acurazine.com/forums/showthread.php?t=820000
https://acurazine.com/forums/showthread.php?t=752205
https://acurazine.com/forums/showthread.php?t=822656
https://acurazine.com/forums/showthread.php?t=834322
https://acurazine.com/forums/showthread.php?t=821398
DIY spring install
The following 11 users liked this post by Puppetmaster:
MrOtocinclus (01-12-2012),
opboarding (12-20-2011),
and 6 others liked this post.
SPC engineering makes rear camber arms.
Ultra Racing chassis braces for the 08+ accord fir the 09+ TSX. These are all already on my car been on for 12+ months. I think honda tuning did an issue on it a few months ago.
Ultra racing has a 19mm rear sway bar which fits in the stock location.
Progress has a 22 mm rear sway bar it requires drilling into the sub-frame for mounting the bigger bolts it uses.
CU2-Fred
Great list. I'm looking in buying some coilovers soon. Don't forget to include the OEM Honda Euro Sports suspension, M/T, 2.4 08W60-TL3-600A and Sports suspension, A/T 2.4 08W60-TL3-600B.
There's also the Mugen CU2 Sports Suspension.
Great info puppet master. Im sure many of our members will look at this thread when looking at lowering options. I'll write a review about my Megan EZstreet later when I have more time. They have exceeded my expectations thus far though. They ride great...better than my H&R springs for sure
Thanks guys. I'll update with the added info later. Busy day at work today. But please keep the info coming if you have it, thanks.
Next on my mind - brakes.
Rotora
Brembo
Stop-tech
Wilwood
Spoon
Endless
Rotora
Brembo
Stop-tech
Wilwood
Spoon
Endless
Edmunds posted an educational walk-around of the wagon's suspension, which I believe is very similar to the sedan.
http://blogs.insideline.com/roadtest...alkaround.html
Old news, but Tire Rack lists the H&R coilovers, FYI:
http://www.tirerack.com/suspension/S...toModClar=Base
I know that someone on this forum already has them, and another person has them on order from TR currently.
spongebill (12-16-2011)
Ultra Racing chassis bracing review and install guide here, video clip format:
https://acurazine.com/forums/2g-tsx-tires-wheels-suspension-300/installed-ultra-racing-ur-chassis-kit-diy-test-drive-video-841000/
For those who want a comprehensive primer to handling and modifying your suspension for improved handling, here is some great reading from Mike Kojima, mainly focused on sport compacts:
Making It Stick Part 1: Four basic steps to better handling
Making It Stick Part 2: Four more steps to better handling
Making It Stick Part 3: It's all in the geometry
Making It Stick Part 4: More lessons in suspension geometry
Making It Stick Part 5: Damper fundamentals
Making It Stick Part 6: More advanced dampers
The following 2 users liked this post by Puppetmaster:
spongebill (12-16-2011),
ttk5 (12-16-2011)
For those with aftermarket rims or winter setups and need TPMS info:
https://acurazine.com/forums/2g-tsx-tires-wheels-suspension-300/cu2-compatible-tpms-840242/
https://acurazine.com/forums/2g-tsx-2009-2014-143/best-place-get-tpms-sensors-836218/
https://acurazine.com/forums/2g-tsx-performance-parts-modifications-299/ht-spec-brake-kits-hit-99-08-acuras-now-up-2g-tsx-4g-tl-824318/
https://acurazine.com/forums/2g-tsx-performance-parts-modifications-299/ht-spec-stage-4-5-brake-kits-all-new-rb-performance-bbks-824304/
http://www.heeltoeauto.com/pitboard/?p=1135
HT visiting to Racing Brakes:
https://acurazine.com/forums/2g-tsx-performance-parts-modifications-299/visit-racingbrake-some-great-tech-stuff-2-piece-rotor-heavy-info-826611/
Thread discussing "budget" big brake options:
https://acurazine.com/forums/2g-tsx-performance-parts-modifications-299/budget-brake-upgrades-840198/
PuppetMaster, Man! some great info your compiling for our community. Though it may not all be "new," you are putting it all in one dedicated thread which is super helpful. I wont write too much because I dont want to clutter this thread but thanks and goodjob. I didnt read all those articles yet but I read the first one and Ill read the rest when I have time.
Good reading from StopTech on brakes, technically not suspension, but brakes and wheels/tires are all so closely related and have a significant impact on handling and suspension, and vice versa.
http://www.stoptech.com/technical-su...l-white-papers
Some that I'd highlight:
Basics and Upgrade Selection
http://www.stoptech.com/technical-su...rade-selection
Brake Bias
http://www.stoptech.com/technical-su...alance-matters
Warped Brake Myths
http://www.stoptech.com/technical-su...nd-other-myths
Pad and Rotor Bed-In Theory
http://www.stoptech.com/technical-su...and-procedures
Bleeding Brakes
http://www.stoptech.com/technical-su...leeding-brakes
Stainless Steel Lines Q&A
http://www.stoptech.com/technical-su...rake-lines-q-a
Brake Bias
Warped Brake Myths
Bleeding Brakes
And yeah, those Kojima articles are great and very useful for any enthusiast.
KW Variant 1
Drop range- 0.9"-2.1" front and rear
Spring rates– not specified
Other notes: Uses OEM upper mounts, rebuildable, lifetime warranty for original owner, linear springs, INSTALLATION INSTRUCTIONS "CLICK"
Puppetmaster (02-17-2012)
This was in the Tein install DIY thread, but it is VERY helpful info for coilovers that use OEM top mounts:
Part numbers and quantities to fully put coilovers together without needing parts from stocks.
> 51686-TA0-A01---2
> 51631-SV7-004---8
> 51728-SR0-003---4
> 51675-TA0-A02---1
> 51676-TA0-A02---1
> 51621-S84-A01---8
> 51685-SH3-014---4
> 52675-TA0-A01---2
> 52686-SDA-A01—2
All parts ordered from www.hondapartsdeals.com
Total cost was $73 shipped.
> 51686-TA0-A01---2
> 51631-SV7-004---8
> 51728-SR0-003---4
> 51675-TA0-A02---1
> 51676-TA0-A02---1
> 51621-S84-A01---8
> 51685-SH3-014---4
> 52675-TA0-A01---2
> 52686-SDA-A01—2
The following 2 users liked this post by PPower:
bagwell (03-06-2013),
Adding two more threads with (mostly) good information.
Megan EZ Coilovers on TSX Wagon:
https://acurazine.com/forums/2g-tsx-tires-wheels-suspension-300/megan-ez-coilovers-2011-sportwagon-847224/
How long before springs "settle" and alignment:
https://acurazine.com/forums/2g-tsx-2009-2014-143/how-long-does-take-springs-settle-852254/
I wish i had the budget for endless brakes.....solely because of the blue color hahaha kidding of course...ill probly end up going with wilwood brakes because they are a great price and they have good reviews
Great write up on coilovers tho, I really appreciate it...im really really looking into this and want ones that are great for track duty...dont mind so much about lowering the car...looking for maximum handling advantage
Thanks for the compilation. tons of useful info, its like a shortcut for us. thanks guys.
question tho.
if i want a subtle drop, can i use
Eibach for CU4 on a CU2 car? just so that ill get .8 drop only ???
question tho.
question tho.
question tho.
If you search, a few members have the eibach and they aren't really that low and is fairly subtle.
Bump for updates on other coils like ISC along with other suspension mods and refinements.
And for the search impaired.
Konis installed on a 2G TSX, includes discussion as well as install pictures and tips. Some adjustments had to be made for certain stock components to be reused with the Koni dampers, and this thread documents that very well. There are also pictures of the car with the Konis installed with stock springs, as there is a slight reduction in ride height.
https://acurazine.com/forums/2g-tsx-tires-wheels-suspension-300/anyone-konis-their-2nd-gen-871916/
holy frog (02-04-2016)
2013 bump
H&R coilovers on TSX wagon:
https://acurazine.com/forums/2g-tsx-photograph-gallery-144/2012-bwp-tsx-sport-wagon-879567/
Ground control coilover sleeves:
https://acurazine.com/forums/2g-tsx-tires-wheels-suspension-300/ground-control-coils-880485/
This is tremendous for myself just getting started so thank you.
So the consensus is that on wagons, springs (although currently listed as compatible from sedan to wagon by many manufacturers like Tein) will most likely not hold up in the rear over the long term and begin to sag in the bum hence all the coilover speak, correct?
https://acurazine.com/forums/2g-tsx-tires-wheels-suspension-300/tsx-wagon-suspension-resources-links-pictures-etc-882217/
Eibachs are good springs, and over time, should not droop significantly. However, one point that I failed to bring up in the other discussion is HOW are you typically using the trunk of the wagon. I don't carry heavy cargo in it, but if I did, I probably would not even consider dropping it, or I'd get coilovers and maybe only lower the rear 0.5" to allow for that.
If you don't mind, maybe we could continue this discussion in the wagon specific thread. Then again, I link them all back and forth anyway, so I guess it doesn't matter.
http://www.motoiq.com/tech/the_ultim..._handling.aspx
Great suspension resource for anyone interested.
Adding my Koni + Eibach install notes here too:
https://acurazine.com/forums/2g-tsx-tires-wheels-suspension-300/notes-koni-eibach-diy-install-890160/
Excellent step by step of installing coils on a wagon, very similar process for a sedan:
https://acurazine.com/forums/tires-w...hile-i-928923/
BROlando (04-15-2015)
