Water on my rotor?
Old Aug 15, 2012 | 12:09 PM
imKing's Avatar
Water on my rotor?
So Ive been having an issue with my front left wheel area. When the car is in motion im hearing a "tsk" type of sound every time the wheel rotates. I took it to Les Schwab to take a look and they said it could be because of a car wash I had before the noise started and said it might be that they got water on my rotor. Is this possible? if so why hasnt the sound gone away yet? Ive driven all the way from Vancouver to Seattle and when I got back the noise is still somewhat there..
Old Aug 15, 2012 | 12:10 PM
it could be a lot of things.
is the noise speed dependent? meaning, when you go faster, does it "tsk" faster?
Old Aug 15, 2012 | 12:42 PM
PyroDave's Avatar
is your mother in the car, disapproving of everything you are doing in life, saying "tsk tsk"??"
Old Aug 15, 2012 | 05:13 PM
imKing's Avatar
Yes it does, I can start to notice it more when I pass the side of a building. I think it is starting to die down a bit I wasn't hearing it too much today.
Hahaha sometimes but that was before my car started having that problem.
Old Aug 15, 2012 | 05:29 PM
musty hustla's Avatar
Water on your rotor? That makes no sense.
Old Aug 15, 2012 | 05:32 PM
something might be rubbing.
One time, in an older car, I had a ticking noise that increased with speed.
it turned out to be a wheel weight hitting something stationary, like a shock or a control arm.
I can assure you that its not water on the rotor.
if water were to be on the rotor, it would cause it to rust.
and as soon as you step on the brake, the pad would wipe the rotor clean free of rust.
Old Aug 15, 2012 | 07:20 PM
ceb's Avatar
ceb
OMG - water on the rotor. LOL
Old Aug 16, 2012 | 12:13 PM
Slo AP2's Avatar
every rotor is exposed... water on it will make no difference. check the backing plate of the rotors. Possible that they could be touching the rotors slightly.
Old Aug 16, 2012 | 03:19 PM
TSXV6Guy's Avatar
Could also be something as trivial as a pebble or something similar lodged within the thread of your tire. You can hear it when it "hits" the pavement as the tire rotates.
Old Aug 17, 2012 | 01:41 AM
imKing's Avatar
Well I dunno what happened but the noise is gone... And no I'm not crazy there was a noise!
Old Aug 17, 2012 | 06:40 AM
^i would still check to see if nothing is hitting.
maybe it was a pebble stuck in the treads of the tire, like one poster pointed out
Old Aug 17, 2012 | 09:06 AM
ceb's Avatar
ceb
Or a pebble or some other debris stuck between the rotor and caliper
Old Aug 17, 2012 | 11:07 AM
imKing's Avatar
I took it to a few places in my area and I kinda of got the whole "water on my rotor" theory explained to me. One guy told me that the water could of settled on the rotor on the bottom edge of wear the brake pad doesn't touch, which cause a small part to flake up (rusted part) and that's what was hitting the brake pad every time it rotated. Make sense cause I think he kinda took of the flaked part with his finger and the noise is gone
Jul 16, 2017 07:33 AM
Jboat
Sep 30, 2015 10:58 AM
Boraxo
1/2G MDX (2001-2013)
Sep 29, 2015 04:35 PM
STL TL-S
Sep 23, 2015 08:52 PM
