Let's Talk About Boost!
Old Jan 20, 2015 | 09:35 PM
  #161
optimusaccord's Avatar
Backwards engineering stuff is what a lot of people do.
Great for them I guess.
Good thing the scientists at places like Lockheed, and Wankel and Alfred Büchi weren't reverse engineers....
Old Jan 20, 2015 | 09:52 PM
  #162
ssjoeboe9's Avatar
ROTAREDOM
Im an engineer, and so is Ryan... Reverse Engineering is half the game really. We are always trying to figure out new ways to do things, and some times the competitor does something completely different than everyone else. Then we have to figure out why it worked better than any previous design, and how we can improve what is considered the "best."
Scientist don't make anything.. they discover things, then engineers use those discoveries to do things better, faster and cheaper than before.
Old Jan 20, 2015 | 10:06 PM
  #163
UTAH TSX's Avatar
This is why the TYPE-S pictures don't show the downpipe it's top secret LOL, I was looking at his intercooler and they ran the pipes under the frame and the intercooler is very low to the ground
Old Jan 20, 2015 | 11:46 PM
  #164
xtcnrice's Avatar
VTEC just kicked in, yo!
Call me biased because I'm an engineer as well, but this is true. Although, there is a fine line between what is considered okay and what is not when talking about reverse engineering. Obviously the company who owns the product being reverse engineered wouldn't approve of this, but it's done anyway; you have no real control. This is partly why patents are in place; to protect the intellectual property of those who came up with it first, for X number of years.
Of course like Joe said, it's also about figuring out what they did and why/not it worked well. This doesn't mean you have to copy their design. You can make notes on how you could perhaps improve upon it, and if you're careful, you're not exactly "copying" anything in that regard. When done right, it's more like doing research and even finding inspiration.
If reverse engineering doesn't exist, you might as well leave 4WD to the first company who invented it, or internal combustion engines for that matter to the first guys who ever made one. I enjoy diversity. It helps keep things interesting and provide incentive for people to constantly improve their products. No one wants to reinvent the wheel for no reason.
Old Jan 21, 2015 | 08:40 AM
  #165
I get that, I engineer things to allow people to use the internet.
Blatant RE I have issue with. Improving something that was RE, I'm fine with. I come in after other people and improve their system retro actively quite often - which involves understanding why someone did something so wrong....
Old Jun 3, 2015 | 02:00 PM
  #166
jomo's Avatar
Originally Posted by xtcnrice
Hey jomo, sorry for asking questions but not having any useful input of my own. I hope you can understand though, since your build is very interesting!
Pardon my ignorance in any of these questions
-Is this a Comptech/CT-Engineering SC (twin scroll) or a centrifugal unit?
-Did you have to make any big modifications to make it work (like delete A/C, relocate stuff in the bay, etc.)?
Hope you work out your issues!
- It is a CT-E roots style supercharger (not the centrifugal type that looks like a turbo). It is the MP62 or M62 type SC that CT-E has on their website. It is very similar to the Jackson Racing supercharger that was available to the K20s (civic Si and RSX). See pic below.
- I had to make some mods that I think wouldn't be necessary for everybody because I used the kit that was made for the 06-11 Civic Si. I had to trim the stock TSX bracket that holds the upper most pulley (idler pulley) in order to screw in one of the manifold bolts. I had to modify the peanut shaped coolant port on the intake manifold to a circular shape so coolant doesn't leak. This is a common mod that '12 Civic Si owners do to use the RBC intake manifold from the 06-11 Si. I had to wire in the 06-11 Si clips because the TSX clips are magically different and the manifold I have only fits K20 (06-11 Si or RSX) injectors or K24 (04-08TSX or k24A4) type injectors, which are much thinner than the 2009+ TSX / 2012+ Civic Si injectors. A simple tie strap holds the AC line closer to the side of the engine bay to ensure it doesn't touch the supercharger pulley while driving. My manifold support bracket didn't fit either because the TSX has a huge bulky mount in the way but I rigged it up with some washers and a much longer bolt so it could still support the manifold. This is simply a metal bracket that connects from the front of the I take manifold to the block to support the extra weight of the supercharger. Lastly, I had to use a shorter belt because the tensioner pulley setup that CT-E makes for the Civic Si doesn't fit on the TSX. I simply removed the idler and used a shorter custom sized belt from Napa.
However, to answer your question, if you buy the TSX kit from CT-E, you shouldn't have any of those issues. It appears to be a direct plug and play. It doesn't require any major mods- simply remove your current intake manifold, replace it with a manifold that can hold a supercharger on top, bolt it all together, and then get a belt to fit around your supercharger pulley. Of course you'll need Hondata to handle the boost though and use the bigger injectors they provide.
Old Jun 3, 2015 | 02:44 PM
  #167
jomo's Avatar
Anybody know of any colder spark plugs that will fit our car? I'm getting along knock, on the Flashpro and I can actually hear it at low load. I asked Napa and they couldn't find anything, just the iridiums that are made for the car: ILZKR7B-11S. Joeboe, you mentioned something about Evo plugs? Any input appreciated!
Old Jun 3, 2015 | 04:42 PM
  #168
UTAH TSX's Avatar
Ngk - ilkr8e6
Old Jun 3, 2015 | 04:46 PM
  #169
I hate cars's Avatar
Colder plugs are very unlikely to help. If you're getting knock at low load it's a tuning issue.
Old Jun 3, 2015 | 05:02 PM
  #170
ssjoeboe9's Avatar
ROTAREDOM
Yeah to clarify, I wasn't getting knock at idle, only when accelerating. But like a lot.. 300 knocks in cylinder one in like 2min.
The ct map was optimized for for 780cc injectors, no aftercooler core, and stock spark plugs. I can confirm what Utah said, we are all running the same spark plugs.
Did you have problems with your manifold core not having large enough holes form he bolts? or was that just a problem for me?
You asked about the pump.. It's so lights weight and the tuning is so rigid there was no need to secure it to anything, and it sits behind the bumper so it has protection from hitting anything. We're my pictures helpful in mounting the aftercooler up front?
Side note.. You're gunna need a hondata 5bar MAP sensor. I assume your civic already had one, but you didn't mention it.
Old Jun 4, 2015 | 05:21 AM
  #171
jomo's Avatar
Utah/joeboe, thanks for spark plug info. placing my order now...
Ok so that crazy amount of knock you're talking about during acceleration is exactly what I'm getting. Trying to get to the bottom of this. Do you think Aftercooler core could play a role? Injector size was already adjusted in Flashpro and I assumed that would only become a factor when it comes to maxing out injectors, not at lower loads/daily driving... Very frustrating to be getting so much knock at low load.
No problems with the Mercracing Aftercooler core. Fitment was perfect. Mine was the latest batch just finished this past month, so he may have had that issue addressed by now. Yes, your pictures helped with installing the heat exchanger. I didn't finish the install but I mocked everything up and using similar brackets and bolt holes. Did you ever find a pump signal wire somewhere outside? I dont want to run a wire thru the firewall if possible.
My 4 bar died so I'm back to stock for now. Thanks for reminding me. Going to order that now...
Old Jun 4, 2015 | 06:10 AM
  #172
jomo's Avatar
Everything looks fine but knock is going crazy. The audible knock is evident while driving as well.
Old Jun 4, 2015 | 06:29 AM
  #173
ssjoeboe9's Avatar
ROTAREDOM
Aww good, I actually made a difference in the tuning community!
Upload a video of the knock you hear. I have a few videos at idle that seem really loud for just idle, but I have a feeling I need to adjust my valves. I haven't done that for the life of the car (111K miles)... damn I just realized I have put nearly 13K miles on the supercharger!
Idk what your tuning experience is, but I would honestly let Vit handle the knock issue and tuning. I really wouldn't be discouraged by how much knock you are getting, it's all pretty much phantom.
Unfortunately there is no "Switched Power" in the engine bay, the only option is to run it to the fuse box under the dash. If I recall correctly it was fuse #2 which is for power seats. I can show you how I ran the wire without going through the firewall, albeit it wasn't my favorite option, it works well, and isn't too much of an eye sore.
Old Jun 4, 2015 | 09:16 AM
  #174
jomo's Avatar
The below Youtube link is the car idling. It did not sound like this before the supercharger install. People have told me that I need to adjust valves but when I removed it from my Civic, the noise disappeared. So, I am convinced it is the sound of my supercharger. In regards to knock, this is not the sound I am referring to.
Idling:
https://youtu.be/HwRprJ-UEm0
The below link is knock while driving and if you listen closely, you may be able to hear it. I can see the Hondata knock sensor go crazy on the computer but at the same time, I'll hear short little spurts of the actual audible knock.
Slight audible knock:
http://youtu.be/-vcT8IDcnQM
Once I get the Aftercooler installed, I will get the etune from Vittuned. In the meantime, Ill continue to poke around. I did find that the TSX SC basemap has some individual cylinder ignition retard whereas the K20Z3 basemap does not. Didn't fix the problem though, still knocks. I checked my plugs and the metal tips and ceramic center are still intact but there is a new fresh layer of ashy white covering the entire top portion of the plug to include the metal tips and insulator. Ideas?
Yes, your thread really did help me out for my install. I really wanted to go with the Full Race kit or the RV6 kit, but who knows when that will finish so I settled for the blower. If you get a chance, pls show me how you routed your Aftercooler pump switch. Thanks.
Old Jun 4, 2015 | 12:12 PM
  #175
ssjoeboe9's Avatar
ROTAREDOM
Mine idles exactly like that as well.. I couldn't really hear the knock on the video though.
Ashy is pretty normal, black is pretty normal.. white specs that look like metal has attached to the plugs is obviously not normal.
I'll try to post some pics of how I ran the wires/relay tonight. I also have pics of my plugs that I pulled a couple weeks ago. Should give you something to compare too, although I have ran a lot more miles than you have.
btw.. where are you located? It's cool that someone else is finally taking on this project. For a while I was going at it all alone, so every problem seem to take me twice as long to fix because I had to consult the civic guys then adapt the answer for my tsx.
Old Jun 4, 2015 | 01:36 PM
  #176
I don't want to insult anyone but just in case anyone was thinking it's real knock at idle, it's impossible. Probably the blower itself or something else on the engine making the noise and setting off the knock sensor.
Old Jun 4, 2015 | 09:22 PM
  #177
Is it knock, or is it injector noise? Injectors tend to make quite a bit of chatter.
Old Jun 4, 2015 | 10:07 PM
  #178
ssjoeboe9's Avatar
ROTAREDOM
Sorry I didn't get around to taking pics of the wiring.. here are my plugs. Pulled two weeks ago. Should give you some peace of mind.
Old Jun 6, 2015 | 09:36 AM
  #179
ssjoeboe9's Avatar
ROTAREDOM
Here is the updated pump/wiring diagram. I supplied the image to MercRacing as well, so he should update his website soon.
Old Jun 19, 2015 | 09:43 PM
  #180
obert's Avatar
Just curious why the 9th gen guys are making 400hp with the stage 2 set up like what we run ?
Old Jun 19, 2015 | 11:23 PM
  #181
ssjoeboe9's Avatar
ROTAREDOM
They aren't..
The highest I've seen is 385whp on E85 with a Jackson supercharger (centrifugal, non roots style). They also have been blowing up on too high of boost.
Old Jun 19, 2015 | 11:33 PM
  #182
obert's Avatar
They aren't..
Oh okay I was just reading a thread on 9thgen and they are claiming either close or a little over. I had a 8th gen that was getting 350 whp with the c/t with just a smaller pulley and bigger injectors. No aftercooler and a CAI. Tunned by Vit of course. And I believe I was at around 9-10 psi.
I was hoping to get at least the same south of the TSX. I mean I know the 8th has a K20 not a K24. Maybe different compression or something ?
Old Jun 19, 2015 | 11:40 PM
  #183
obert's Avatar
I just went back and looked and yeah maybe it was a Jackson or a kraftsworks that was making the higher numbers.
The Official: Q&A for the CT-E Supercharger Kit - Page 2
So do you think 12psi is to much for the comptech to handle safely ?
Old Jun 19, 2015 | 11:47 PM
  #184
obert's Avatar
Damn I can't edit yet so I have to make a new post. I am just trying to gather info because I am very interested in going stage 2 soon after I get the stage 1 runner by Vit on the 27th.
I know there is a ton more things out now for the kit then back in 2009 that you can do to it and buy to get more out of it. But I also don't want to ruin the motor or blower by over doing it.
Did you upgrade your fuel pump with your set up ? Or mess with the fuel pressure regulator like I had to do for the 8th gen ?
Thanks for all the info you give and have given already !
Old Jun 20, 2015 | 10:51 AM
  #185
ssjoeboe9's Avatar
ROTAREDOM
The first post in that thread is very informative. When you start decreasing pulley size you're gunna want to start thinking about aftercooler setups.
Anything is possible, just how much money do you wanna spend? I have about $6k in supercharger parts, and my goal was to get 300+ whp on my daily setup.
-Spec Stage 2 clutch +Civic flywheel
-780CC supplied injectors
-1 step colder plugs
-2.95" pulley
-Merc Racing aftercooler
-catless exhaust
-boost+Wideband gauges
-Hondata FP
VIT tuned me conservativtely as per my request and I'm really happy with it.
Now.. If I was building a #racecar. This is personally what I would do..
-Send my Eaton blower +manifold to be ported and polished
-upgrade to forged rods/pistons/valves
-upgrade to 1000CC injectors
-trade in my merc cooler for Vit tuned cooler
-upgrade my fuel pump to Deatsch Werks
-install venom snout cooler
-install civic Limited Slip differential
-install meth injection system
-fabricate front mount intercooler sprayer (or cryO2, I never decided)
-Full 3" catless exhaust
-Hondata Traction Control
-VIT boost by gear
But ya know... that's just me.
Old Jun 20, 2015 | 11:08 AM
  #186
obert's Avatar
-2.95" pulley
-catless exhaust
-Hondata FP
-VIT boost by gear
I totally agree ! And yeah lots more things to buy and do with the kit then there was 6 years ago when I had my first one.
Thanks for the info
Old Jun 20, 2015 | 11:29 AM
  #187
obert's Avatar
I will post up state one numbers after I get my dyno tune done next Saturday. I am just running the Stock pulley with 550cc injectors
Old Jun 20, 2015 | 12:19 PM
  #188
ssjoeboe9's Avatar
ROTAREDOM
I would expect around 250WHP
Old Jun 20, 2015 | 12:36 PM
  #189
obert's Avatar
Yeah that's what I was thinking to, I am just running a base map Vit tweeked to work with the different injectors. So I have not really been able to get on it but it is faster already and I love the sound. So it can only get better with a full dyno tune.
Old Jun 20, 2015 | 12:42 PM
  #190
ssjoeboe9's Avatar
ROTAREDOM
Yeah you're gunna love it. Stage 2 is awesome! The boost is freakin' addicting, gets to 100mph on the highway real quick. Tell Vit I said wassup. He finished me up only a couple weeks ago.
Old Jun 20, 2015 | 12:47 PM
  #191
obert's Avatar
I am making the 5hr drive to do it in person like I did last time before he had his shop. And I will start to collect parts for a stage 2 and possible make a mother trip back down next year for retune since I will be buying his after cooler
Old Jun 21, 2015 | 01:30 PM
  #192
I actually had the deatschwerks pump, and 1100cc injectors.
The turbo was rising up and kissing 12 psi.
It was quick. Back in December there was that 5.0 new mustang, that was playing around on the highway, that was a lot of fun.
memories.
Old Jun 21, 2015 | 04:26 PM
  #193
obert's Avatar
memories.
How was installing the pump ? Was it a easy swap out or did you have to modify anything ? What pump model did you go with ?
Old Jun 21, 2015 | 04:31 PM
  #194
UTAH TSX's Avatar
The dw65c needs no modifications just use the stock screen and one extra o ring seal on the top of the pump, it's a piece of cake to install
Old Jun 21, 2015 | 06:41 PM
  #195
obert's Avatar
Thanks for the info
Old Jun 21, 2015 | 08:51 PM
  #196
Jaheri_cbp's Avatar
Is the fuel pump lid trunk accessible.. Or remove Bottom of back seat?? I took a quick look in the trunk and didn't notice one.
Old Jun 21, 2015 | 08:54 PM
  #197
obert's Avatar
When I did one on my 08 si the access panel was right in the middle close to the rear seat backs in the trunk.
Old Jun 22, 2015 | 10:22 AM
  #198
UTAH TSX's Avatar
It's under the rear seat bottom you do not have to remove the seat back just the bottom cushion
Old Jul 1, 2015 | 01:54 PM
  #199
obert's Avatar
Could not help my self, ordered a Vit Viper aftercooler and I already have a 3inch pulley. The collecting of parts for the stage 2 upgrade has begun
Old Jul 1, 2015 | 02:01 PM
  #200
That's a lot of work just to get to 300 whp give or take a few.
That's why I went turbo over the s/c setup.
Hopefully it's fun, and exactly what you want.
