Fog light install problem
Old Mar 1, 2016 | 09:07 AM
crewjones's Avatar
3rd Gear
I attempted to replace my fog light bulbs using the manual as a guide. I was able to remove the three clips but the cover does not open like shown.
I don't want to force the plastic guard to open but it also looks like the inner wheel well it part of this system. There's also three bolts holding the under skid protection in place. Do I need to remove all of this stuff to replace the fogs lights?
It's a 2012 TSX Special Edition with the ground effects. Could that be interfering with the removal process?
Old Mar 1, 2016 | 09:32 AM
cu2wagon's Avatar
I popped the three clips and pushed the access panel up and in. You can read some trials and tribulations here:
https://acurazine.com/forums/photogr.../#post15605318
Old Mar 1, 2016 | 09:33 AM
icu2tsx's Avatar
are you able to push it freely towards inside? if so then you just need to gently fold down on the lip and pull out outward like in diagram.
Old Mar 16, 2016 | 08:31 AM
crewjones's Avatar
3rd Gear
I tried pushing the door in then out and even took out more clips that I thought was preventing the door from swinging open. It seems that the front body skirts/ground effects are blocking entry to the fog light access.
What do I need to remove in order to access the fog lights in the special edition?
circled part is the fog light door where it meets the front lip. It won't swing down.
Old Mar 16, 2016 | 08:38 AM
just take the bumper off, it's a lot easier that way and way less daunting than it seems
Old Mar 16, 2016 | 08:39 AM
ulrblitzer's Avatar
I would've just removed the whole front bumper and replaced the fog bulbs by now if you're struggling that much with the access panel.
Old Mar 16, 2016 | 08:43 AM
cu2wagon's Avatar
Counterpoint: If you're struggling that much with the access panel, DON'T go attempting to pull the whole front bumper.
Old Mar 16, 2016 | 08:45 AM
Countercounterpoint: those access panels are significantly harder to deal with than the bumper.
Source: personal experience.
Old Mar 17, 2016 | 08:22 AM
crewjones's Avatar
3rd Gear
any guide for removing the front bumper for the special edition?
Is is different from the standard bumper?
Old Mar 17, 2016 | 08:42 AM
Should be one or two bolts in each of the wheel well, 2 or 3 on the top, a bunch of "bitch" clips aka bumper clips.. from the right and left pull away (to right and left respectively) just under the headlight, pull straight away from the car/headlights to unclip it. Grab the bumper from the top and 'unhinge' it off the radiator support.
done.
Old Mar 17, 2016 | 08:50 AM
ulrblitzer's Avatar
Click, save, refer to for all future projects. It's for the Non SE, but the concept is the same.
A moderator really needs to sticky this link for the CU2.
Old Mar 21, 2016 | 07:56 PM
notalk's Avatar
Many thanks, urlblitzer. Was going to post about any tips for removing front bumper, but this may be all the help I need.
Have to replace a broken fog light. It's already getting pretty warm in Phoenix, so, I better get off the couch and get this done before its too hot.
Skier4lyfe303
Jul 13, 2016 03:53 PM
wirelessnate
2G TSX Problems & Fixes
Mar 11, 2016 01:23 PM
SupremeOpinion
Feb 8, 2016 06:16 PM
DevtypeS
Feb 6, 2016 07:34 PM
mtiaz
Jan 24, 2016 11:21 AM
