2012 Acura TSX: Power Steering, Driver side fog light, & vehicle vibrates
First time poster (clearly), been a bad week. I was curious if anyone knows prices for the stuff I'm about to take into the dealership this weekend?
"Check Power Steering System" light is on, and stays on. What's the worse case scenario that I'm looking at price wise for this?
Driver side dog light completely shattered and needs to be replaced?
Does anyone know if for the power steering job will they need to remove the bumper? The reason I'm asking is because I know they need to remove the bumper for the fog light replacement, so if they did then hopefully I could only get hit once on that part of the labor charge?
Last but not least, vehicle vibrates when I am driving 60+ MPH and hit my brakes? Any ideas on what that might be?
Thanks to everyone in advance!
The vibration at 60 with brakes could be warped rotors. Do you feel the vibe in the steering wheel? Light braking - light shake. Heavier braking, heavier shaking. Really hard braking often stops it tho.
No idea on the other stuff.
Thanks. The warped rotors is what the dealership said, they are replacing the breaks and adjusting the rotors accordingly, he said they are in good shape and no need to replace them. So just changing the break pads will fix it, he says. Do you know if that's accurate?
Graphite Ghost
And it's 2 screws and bulb plug. And it can be done without removing the bumper. There are access panels right under the fog.
Received 7,772 Likes
Without the resonator, I think it's entirely possible to go through the access panel. And the passenger side can be reached through the access panel.
