vent is hot on manuel mode
Old Apr 5, 2011 | 11:49 PM
Twintt's Avatar
My vent are hot and I open all the vent in the car so that air is not trap. I just change my coolant and did a transmission flush already so I am puzzled on what it can be? The weather is not hot. I just notice my vent being hot because I always have to roll down the windows. My AC is working fine. I have black on black leather but that shouldn't be a problem.
Old Apr 6, 2011 | 01:04 AM
01tl4tl's Avatar
did you burp the cooling system properly? ck the res bottle - if its low reburp system
Ac goes thru all the vents?
could be the mixer door for hot/cold, been several ziners with that as recent problem
yours should be cable activated from the knob (assuming non-navi), you may have to remove glovebox to get access -easy diy
good time to replace the cabin filter too
Old Apr 6, 2011 | 01:32 AM
Karanx7's Avatar
Unregistered Member
WHY DIDN'T I THINK OF THAT?!?!! I spent an hour upside down in the most uncomfortable position ever to fix my heater air mix.
Old Apr 6, 2011 | 06:47 AM
totaledTL's Avatar
Lol... don't feel bad. I've done stuff like that. After completion realized an easier way. It's part of learning.
Old Apr 6, 2011 | 09:03 AM
Twintt's Avatar
I did a cabin filter change already. Is their a diy link for the cable knob. thanks
Old Apr 6, 2011 | 10:46 AM
01tl4tl's Avatar
did you ck the diy list? or try an outside search engine for it with +acurazine.com and it will ferret thru azine better than our own system--especially 3 letter terms like egr
Someone had this problem before- you can bet
I cant guarantee cable access with glovebox removed- wasnt paying attention to anything but cabin filter when I was in there
but it does seem reasonable
please correct me if you get in there and its blocked
Old Apr 6, 2011 | 02:33 PM
fsttyms1's Avatar
There isnt a cable from the knob. There is a cable that goes from the mix motor to the mixer hose in the engine compartment. You can see it operate from under the dash on the passenger side. Turn the key to run and lay on the floor looking up towards the center console with a flash light. Locate the mix motor and cable and turn the dial from full cold to full hot and see if it changes/moves. If so next have someone turn the dial for you and look under the hood passenger side towards the firewall behind the motor and locate the cable where it attaches to the heater hose. See if the valve moves there.
Old Apr 6, 2011 | 03:18 PM
Karanx7's Avatar
Unregistered Member
https://acurazine.com/forums/2g-tl-problems-fixes-117/halp-812723/
^That's what a broken one looks like. Yours should rotate freely.
Old May 9, 2011 | 06:06 PM
Twintt's Avatar
I notice when I drive car my vent get cold than hot later. I have the vent mode to blow on face. I'm wondering if it's my thermostat? My temp gauge needle is fine and doesn't jump. The knob is set to cold. When I press to automatic mode the ac is working fine and also when i turn off the ac and just leave the fan it's working fine. Only when I don't have it turn on that this is happening?
Old May 9, 2011 | 06:27 PM
Karanx7's Avatar
Unregistered Member
Hmmm, a good way to help eliminate a lot of things would be to let your car spit out a DTC code.
Turn the ignition to on(II) but don't start the car. Press and hold the AUTO button. Then press and hold the OFF button. Hold both of them for about a minute. If the temperature display starts flashing a weird segment, then you can pinpoint the problem. If not, then I don't know.
Old May 9, 2011 | 06:42 PM
Karanx7's Avatar
Unregistered Member
Old May 9, 2011 | 07:06 PM
Twintt's Avatar
My car vent get cold than hot and than cold . It switches. If I do the code than do i have to reset anything later? Thanks
Old May 9, 2011 | 09:37 PM
Karanx7's Avatar
Unregistered Member
No need to reset anything. Just take the key out, and it's completely back to normal.
Btw, not a big deal, but please don't quote posts with big pics. Just takes up a lot of extra space.
Jul 16, 2017 07:33 AM
12vancover
Oct 16, 2015 12:04 PM
Kres43
1G RDX (2007-2012)
Oct 3, 2015 07:16 PM
hashbrown
Sep 29, 2015 12:13 PM
