Tight transmission drain bolt on 02 TL
Old Mar 1, 2007 | 05:26 PM
Submariner2's Avatar
anyone have problem open up their tranny's drain bolt the very 1st time, i am standing infront of my car and reach under the car with my 3/8 rachet wrench turning counterclockwise, am i doing this right?
Old Mar 1, 2007 | 06:06 PM
01tl4tl's Avatar
If you were under the car looking at the bolt, would the action you are taking result in
leftie loosie or righty tighty?
Old Mar 1, 2007 | 06:14 PM
i have only tried one direction with the hammer hitting from top to bottom (counterclockwise)when i am under the car, i am pretty positive about the turning direction, just not sure why is it so tight, perhaps a trip to the autoshop for them to loosen it up for me.
Old Mar 1, 2007 | 06:26 PM
fsttyms1's Avatar
Its going to be tight. counter clock wise is the correct way to go but it would be from the side of the car. Reef away.
Old Mar 1, 2007 | 07:51 PM
thanks for the info fsttyms1, i'll give it another try
Old Mar 1, 2007 | 11:07 PM
Rpappi's Avatar
DRINKING HAS A ME PROBLEM
yup its on there tight. when you get the fluid changed it will feel like a new car.
Old Mar 1, 2007 | 11:12 PM
SodaLuvr's Avatar
I use a 18" long (maybe a bit longer) 1/2" drive ratchet and a 1/2" to 3/8" adapter. Works perfect.
Use a 12mm on the oil jet...
Old Mar 1, 2007 | 11:32 PM
Malayalee King's Avatar
ഥഎണഡഏ Fellas Inc.
how often should one change transmission fluid on 2G TL? What brand of fluid do you use? Anyone with a DIY?
Gracias Senors!
Old Mar 1, 2007 | 11:38 PM
SodaLuvr's Avatar
I would replace every 30k at the minimum.
Genuine Honda ATF-Z1 works. Dexron-III(H) + Lubegard HFM works. Amsoil ATF works. Your choice.
Old Mar 2, 2007 | 12:09 PM
newbie question, what is an oil jet?
Old Mar 2, 2007 | 01:39 PM
phipark's Avatar
Not Asian
It's a part that was included in one of the recalls.
Old Mar 2, 2007 | 02:07 PM
does this "oil jet" needs to be remove for changing tranny fluid? and where is this oil jet locate? will be greatful if someone have a picture.
Old Mar 3, 2007 | 12:22 AM
njzprettyboy's Avatar
Mine was tight every time....use a breaker bar!
Old Mar 5, 2007 | 11:37 AM
tranny's fluid drained and changed, smoothssssssssss........ thanks all
Old Mar 5, 2007 | 11:48 AM
ഥഎണഡഏ Fellas Inc.
cool -- got any tips/instructions?
Old Mar 5, 2007 | 02:48 PM
SodaLuvr's Avatar
Remove oil jet with 12mm socket
Use 3/8" Breaker Bar to remove drain bolt.
Use 3 qts of ATF-Z1 type fluid.
Old Mar 5, 2007 | 05:01 PM
01tl4tl's Avatar
Curious has got me
Why remove the oil jet when doing the trans fluid change?
Old Mar 5, 2007 | 05:13 PM
SodaLuvr's Avatar
Originally Posted by 01tl4tl
Curious has got me
How else are you going to fill it?
Remove the 12mm bolt that holds down the oil jet onto the bracket. GENTLY pull the jet assembly up and out. Some fluid will drip out so be sure to have a towel handy. Remove the 24mm (?) hollow bolt if necessary if your funnel does not fit.
Filling through the dipstick tube is the worst idea...ever...beyond me why someone would want to do that when oil jet removal can be done in less than two minutes, and this is coming from a person who has never been under the hood of a Honda in recent years.
Old Mar 5, 2007 | 05:14 PM
MikePA's Avatar
To add in the new fluid.
Old Mar 5, 2007 | 05:28 PM
fsttyms1's Avatar
No oil jet
(where you fill it)
This is the oil jet
Old Mar 5, 2007 | 05:29 PM
fsttyms1's Avatar
Curious has got me
to add trans fluid.
Old Mar 5, 2007 | 07:00 PM
ഥഎണഡഏ Fellas Inc.
Nice, someone should throw this in the DIY thread if its not already there...if its enough for a DIY
Old Mar 5, 2007 | 09:09 PM
pixrob's Avatar
Totally agree on this DIY! 116,000 on my '99 with the original transmission fluid let alone transmmission.
It took my 20 minutes at the most because I let the transmission drain until it stopped dripping. Being able to let ATF or the engine oil drain until all of it comes out is one of the benefits of doing it yourself. There isn't a line of cars waiting to get the oil changed...
And change your cabin air filters!
SidhuSaaB
May 30, 2020 12:40 AM
joflewbyu2
Oct 8, 2015 11:16 AM
STL TL-S
Sep 23, 2015 08:52 PM
tristann616
1/2G MDX (2001-2013)
Sep 22, 2015 11:40 PM
ROSSARONIE
Sep 22, 2015 11:46 AM
