no brake lights, shift lock
Old Aug 20, 2008 | 03:48 PM
crazyasiantl's Avatar
my shift lock isnt disengaging properly and my brake lights arent coming on when i apply the brakes. i called the dealer and spoke to an advisor and he said it was the brake switch.. has anyone had this go out on them?
Old Aug 20, 2008 | 04:16 PM
hotwheljoe's Avatar
the same problem for me started yesterday
i see a switch at the brake pedal. is that the reason for the problem? if so, where can i get that switch. right now i have to use the shift lock release with a screwdriver.
any advise? thanks
joe
Old Aug 20, 2008 | 06:17 PM
wildcat71's Avatar
02 NBP TL-S W/Navi
call local parts store and ask for "brake light or stoplight" switch....$20-60 depending on where ya look. shows $36 when i look at "my" estore.
Old Aug 20, 2008 | 07:47 PM
01tl4tl's Avatar
local parts stores will have it- yes they fail on all types of cars-
stop using the brakes so much!!! and stop driving NOW!!!! with no brake lights!!!
Easy to install- a nut- a wire- adjust it back up- probably even in the gen2 DIY section
Old Aug 20, 2008 | 07:49 PM
01tl4tl's Avatar
there is a reason its hard to drive off with no brake lights......they really discourage that!
For others in an emergency: your ignition key is designed to fit in the emergency release- remove cover- insert key straight down and push to unlock
Old Aug 21, 2008 | 02:55 PM
totaledTL's Avatar
I make sure to check all my brake lights often- was rear-ended twice in less than 2 weeks! And with all 6 brake light bulbs working, no less-
Old Aug 21, 2008 | 03:00 PM
damn bro that hella sucks..im waiting to get rear-ended because the lot cant get me in til next week, so im thinking im just gunna drop off my car and get a loaner, dont wanna risk my car getting hit
Old Aug 21, 2008 | 07:37 PM
fsttyms1's Avatar
Go to teh dealer and pick up the 25 dollar switch, crawl under the dash and in 5 min you can have the old out and the new in. Its very simple and many have had it go out.
mada51589
Jan 9, 2025 04:40 PM
Feb 25, 2020 09:57 AM
02tljj
Sep 11, 2015 12:37 PM
ahsm
Sep 9, 2015 08:35 AM
HeloDown
Sep 8, 2015 06:51 PM
