My CD changer got jammed - Need Help..
I need help to fix my cd changer and receive signal on my radio in my 02 TL. I can't eject or load cds now. I told the dealer about it but they gave me a number to a radio repair shop. I called them and they don't answer. The machine says they will be closed for the holidays until the 9th of Jan. We are 11 now and they still have that machine up and don't answer. So....I need help to fix my cd changer because I am getting bored driving in silence.
Please help
Please help
So will the radio turn on at all?
Ok just came back from the radio shop..They are charging me $450 to repair it...That's crazy...
So now I will try to see if I can fix it myself. Anybody know how to take out the cd changer out of my dash?? I didn't find a DIY..
Head unit removal
http://www.skyeflye.com/acura_cls/In...01-2003_CL.pdf
Thanks a lot!!! Who's DIY is this? I wanted to know it is really necessary to take apart the whole center console to take out my cd changer??? Because there are so many screws all over the place that I have to unscrew. Then I noticed there are about 6 screws for the cd changer. Just want to make sure...
I used the above linked guide when I replaced my TL radio and it was extremely helpful. I printed out a hard copy of the instructions and I checked off each step as I completed it. I also used small ZipLoc bags to keep all of the screws and fasteners organized. When the fasteners looked similar I wrote a quick note as to which type went where. That really helped when I reassembled everything.
Good luck.
i took me about 20-30 mins the first time i took it out. now i could do it in about 10. Like bob said print out a hard copy of it and use it. it helps ALOT!! i put the file on m PDA and had it handy when it needed it.
Good luck!!!
Good luck!!!
Ok another question. Basically once I have the radio out I want to open it and see if I can fix the jam cd inside. Anybody try to do that part?
Search the forum for more details and try those methods before you remove your console.
Maybe the jammed CD is somehow causing the other problems with the radio.
Good luck!
Bob
cycdaniel
12-17-2019 10:58 AM
frozenpenguins
08-29-2015 12:54 AM
