My both headlights are not working
Old Aug 22, 2007 | 02:01 PM
simerjots's Avatar
9th Gear
Hello Everyone,
My low beam headlights are not working. I changes the my HID buld on one side and the lights are still not working. The high beam works fine. I checked all the fuses and they are all fine.
Can anyone suggest something?
Old Aug 22, 2007 | 02:06 PM
pearl tls's Avatar
Originally Posted by simerjots
Hello Everyone,
Maybe both of your ballast's are blown. If power come to the wire before the ballast then the ballast or bulb is the problem. If you don't get any power in the wires at all then the problem is most likely fuse or another electrical issue.
Old Aug 22, 2007 | 02:08 PM
simerjots's Avatar
9th Gear
THANKS FOR THE QUICK REPLY
how can I check power in the wire?
Old Aug 22, 2007 | 02:21 PM
pearl tls's Avatar
You'll need a voltage meter tester. Get it at pepboys. The problems might be a ballast, igniter, or either fuse.
Old Aug 22, 2007 | 02:24 PM
simerjots's Avatar
9th Gear
also is it possible to use regular buld instead of HID
Old Aug 22, 2007 | 03:16 PM
pearl tls's Avatar
No because the ballast has way higher voltage than a regular bulb can handle.
Don't do that because it can melt the bulb causing the car to catch on fire.
My HID kit was stolen out of my TLS but I just splice the wire and soldier 9006 sockets onto it, I put in regular Hyper Purple Bulbs from PIAA.
Its cheaper and it easier maintenance.
Old Aug 22, 2007 | 03:20 PM
simerjots's Avatar
9th Gear
Yes thats what I mean Can I spice the wire and put a 9006 or other socket on to it and then Put regular bulb.
I will not use the the HID Kit.
How bright will that be?
Old Aug 22, 2007 | 06:35 PM
blackuraTLS's Avatar
Before you worry about that get the lights working. I had issues with mine last month. I ended you having to replace the igniter. Before you spend any money on parts diagnose the problem and go from there
Old Aug 22, 2007 | 07:09 PM
simerjots's Avatar
9th Gear
Ok I bought a voltage meter and there is no power in the wire that goes into HID Cup .
i check all the fuses all of them are good.
What could the problem be.
Old Aug 23, 2007 | 01:05 AM
hmmm you'll wanna check out the igniter, its the cap that the actual bulb plugs into oh, and make sure you don't touch the glass on the bulb. bad idea.
Old Aug 23, 2007 | 09:37 AM
simerjots's Avatar
9th Gear
ok , but there is no power before the cap in that white wire
TLrascal
Aug 3, 2018 11:00 PM
acurajj
Sep 19, 2015 03:47 PM
JnC
Sep 11, 2015 06:06 AM
theinsvnity
Sep 10, 2015 10:22 PM
prox
5G TLX Problems & Fixes
Sep 1, 2015 02:03 AM
