My both headlights are not working
Hello Everyone,
My low beam headlights are not working. I changes the my HID buld on one side and the lights are still not working. The high beam works fine. I checked all the fuses and they are all fine.
Can anyone suggest something?
Originally Posted by simerjots
Hello Everyone,
No because the ballast has way higher voltage than a regular bulb can handle.
Don't do that because it can melt the bulb causing the car to catch on fire.
My HID kit was stolen out of my TLS but I just splice the wire and soldier 9006 sockets onto it, I put in regular Hyper Purple Bulbs from PIAA.
Its cheaper and it easier maintenance.
Yes thats what I mean Can I spice the wire and put a 9006 or other socket on to it and then Put regular bulb.
I will not use the the HID Kit.
How bright will that be?
Before you worry about that get the lights working. I had issues with mine last month. I ended you having to replace the igniter. Before you spend any money on parts diagnose the problem and go from there
Ok I bought a voltage meter and there is no power in the wire that goes into HID Cup .
i check all the fuses all of them are good.
What could the problem be.
prox
5G TLX Problems & Fixes
Sep 1, 2015 02:03 AM
