Gear shift lights do not illuminate
the ones down by the shifter? If so most likely its the bulb. you have to pop the black trim ring off, then the sliver shift gate off. then pull the prn54321 cover off and that exposes the bulb. grab it and pull up.
welcome to the forum
[QUOTE=fsttyms1]the ones down by the shifter? If so most likely its the bulb. you have to pop the black trim ring off, then the sliver shift gate off. then pull the prn54321 cover off and that exposes the bulb. grab it and pull up.
I have the same problem, what kind of bulbs are they?
Bulb
I had the same exact problem, but I was NOTable to buy the bulb from 2 different car parts store. I don't remember the number, but I am almost sure #74 will NOT fit. You need to go to the dealer to get the bulb.
rockyboy
Aug 4, 2024 10:35 AM
Mike Bertram
Sep 10, 2015 09:27 AM
HeloDown
Sep 8, 2015 06:51 PM
