Code P1399 after a WOT in 3th gear
Old Mar 24, 2009 | 08:56 PM
acurabum's Avatar
Hi guys
My tl-p 02 is running great with the new transmy installed 2 months ago .
So today I went for a WOT sportshift in 3th gear at almost red zone and Engine light flashing for a few seconde ...slowing down and the light stop
flashing ......a few minutes later do the same WOT in 3th gear and same reaction....
Got home and scan the ECU and get the multiples misfires P1399 ....
What do you guys think that I got ???Bad coil or O2 or injector ?
Old Mar 24, 2009 | 09:09 PM
Rajca's Avatar
wham bam thank you ma'am
how are your spark plugs? mileage wise? and take a couple of them out and check them out for any pre-detonation, fouling
Old Mar 24, 2009 | 09:46 PM
acurabum's Avatar
Remember I did change my plugs a week ago to NGK Iridium but swap them back to my original Double Platinum with 90k miles on them 'cause I did feel a lost of power with the Iridium .
Do you think my old plugs are fouling ?
Old Mar 24, 2009 | 09:50 PM
Rajca's Avatar
might be. or majority of the plug is covered in carbon deposit and its hard to get a spark at higher rpm.
Old Mar 24, 2009 | 09:58 PM
acurabum's Avatar
I will try to check and clean them this week-end .
So you do not think the problem is fouling coil ????
Old Mar 24, 2009 | 10:02 PM
Rajca's Avatar
spark plug fouling. was it doing the same thing with the new plugs in? recheck the gap.
Old Mar 24, 2009 | 10:12 PM
acurabum's Avatar
No , with the Iridium the car feel slow to accelerate and response .....so I put the old plugs back and the response is a lot better ....
Now with my WOT in 3th the car pull strong and accelarate great but got the flashing Engine light ... P1399 ...
Just want to have your oponions in which direction to attack the problem ...
Old Mar 25, 2009 | 02:13 AM
01tl4tl's Avatar
put the new ngk plugs back in after a good seafoam treatment to rid carbon from pistons and valves-injectors etc
Then it can deal with WOT- gas doesnt ignite well on piston carbon layer~
Your mind is fooling you- old plugs are not better than new- assuming gap is correct on all the new plugs
One ziner found 1 ngk plug gap incorrect, so it can happen
The codes often mean several things- WOT will superheat heat the cat and cause codes
My question would be- when you got a CEL the 1st time why did you push the car again?
Old Mar 25, 2009 | 07:20 AM
acurabum's Avatar
Amazingly this morning ,after arriving to work and scanned the ECU again and the code is gone .....
What make the code desaspear ???Can you guys explain .
Because remember reading somewhere in the Racing/competition section that
some members while doing WOT got the same flashing Engine CEL at almost red zone and the light was gone when slowing down .....he said it's was normal
I will pull the olds plugs out and check them for any sign of rich/mixture or gap .And will give the Iridiums another try ....
But how you guys could explain the Code 1399 just disapear ????
Old Mar 26, 2009 | 09:38 AM
EL19's Avatar
it used to happen to me in 3rd gear at wot close to redline after i installed the lightweight crank pulley. It didint affect anything and it would just blink it would never stay on and the ecu would erase it almost immediately. I just forgot about it and after about 2 months it never happened again.
Old Mar 26, 2009 | 02:57 PM
acurabum's Avatar
Glad to hear from you I know that I hear it from someone in here about this problem . My ECU erase the code P 1399 the next day only ..
Now my car is running fine .
Did you notice any decrease of performance after flashing CEL ?
Thanks man .
Old Mar 27, 2009 | 08:47 AM
EL19's Avatar
Nope no decrease in performance or anything. Just a blinking CEL and an almost immediate (maybe a few hours) code erase. The CEL blink would stop once I shifted gears. I figured since the engine was spinning so fast compared to the when the oem crankpulley must have caused the random misfire. I was guessing after the ecu "learned" the pulley and that fixed the misfire prob.
Old Mar 27, 2009 | 11:04 AM
ProjectTLS's Avatar
o.O
what spark plugs would you guys recommend using? Reading all these good plugs and better plugs make me wonder which plugs to invest in. 4, 2, or just a regular single electrode? Bosch or NGK?
Old Mar 27, 2009 | 11:16 AM
01tl4tl's Avatar
USE ONLY NGK Iridium IX(upgrade on gen2 and came stock on gen3) or NGK Platimun (stock for gen2)
NO bosch!!!!
denso is approved but cost more and last less miles
No multi electrode bs either- the TL needs a super fine wire setup to work with the coil on plug ignition
Old Mar 27, 2009 | 11:31 AM
EL19's Avatar
NGK Iridium IX- These plugs are gr8. 01tl4tl told me about them years ago and i havent looked bak since.
Old Mar 27, 2009 | 11:39 AM
acurabum's Avatar
USE ONLY NGK double Platinum or maybe NGK Iridium IX only , nothing else please ! ( double Platinum 'cause NGK has Platinum only too .)
A lot of members switch to Iridium IX with no problem at all but my experience was a bit diff ..... but I will give the Iridium IX another try .
Old Mar 27, 2009 | 12:05 PM
ProjectTLS's Avatar
o.O
thats what ive been eyeing..its what I used on my integra. Just wanted a few second opinions.
Old Apr 19, 2010 | 09:45 PM
dudeinaTL's Avatar
Was the root of this problem ever found? Experiencing same thing - blinking CEL at WOT in 3rd (4k+ rpm). Have not taken 4th over 3k rpm. Blinking is only indication of malfunction; no stumbling or roughness of engine. Idle is fine. P1399 found as pending code, no solid CEL at all and no other codes. Can get it to blink on request 80% of the time by simply flooring it.
Old Apr 20, 2010 | 09:33 AM
dudeinaTL's Avatar
Video:
http://www.youtube.com/watch?v=b49ApuN3aBo
Old Apr 21, 2010 | 08:53 PM
d4atls's Avatar
soft codes vs hard codes
the light resetting itself is because for minor issues (random misfiring) the ecu throws what's called a soft code.... meaning it's gives the car a chance to correct itself, if it's something more major (bad o2 or other sensor, coil, something it has no chance of correcting on it's own) it throws a hard code, won't reset untill back up fuse is pulled (have radio anti theft code ready) or reset with a code reader.
Old Apr 21, 2010 | 08:55 PM
d4atls's Avatar
oh and the blinking is letting you know to back off so the ecu can check to see if problem is resolved..... if not it will throw a hard code.
Old Apr 21, 2010 | 09:03 PM
Rajca's Avatar
blinking check engine light means that its misfiring. check ur spark plugs, clogged cat
Old Apr 21, 2010 | 09:14 PM
dudeinaTL's Avatar
Wouldn't bad plugs cause a misfire at idle? My idle is fine; seems like the misfires happen at high engine speed.
Old Apr 21, 2010 | 09:19 PM
Rajca's Avatar
it can happen at idle or at wot. fouled plugs or oiled plugs/ burnt plugs will all cause misfires
Old Apr 21, 2010 | 09:21 PM
dudeinaTL's Avatar
Okie dokie...I'm gonna change the plugs soon. But just trying to think ahead in case new plugs don't solve it.
Old Apr 21, 2010 | 09:27 PM
Rajca's Avatar
is ur cat clogged? can also be one or more partially opening injectors. or clogged injectors. run some seafoam in the gas tank and through the vac port
Old Apr 21, 2010 | 09:36 PM
dudeinaTL's Avatar
Yup, ran some seafoam already...that's when I discovered how common the misfire was thanks to the seafoam "blowoff" stage. From what I remember to determine clogged cats you do some vacuum readings and mess with the throttle; any other way you know of?
Old Apr 24, 2010 | 03:14 PM
dudeinaTL's Avatar
Interesting. Did an oil change, tried some WOT runs & no blinking CEL / misfires / P1399.
I will mention this was the first change since I had the car, and it's been about 5k miles. Don't know what was in it before as the dealer claimed to have done a change for sales prep, but I put in fully synthetic (Mobil-1).
Bad part is I didn't change the filter. Thought I had bought the filter and it was in the trunk but after I dumped the old oil out & was about to do the filter, looked in the trunk & no filter. Found the receipt & I guess the guy forgot to ring it up & put it in my bag 'cause I know I grabbed it off the shelf & had it in my hand at the register.
Remains to be seen if P1399 comes back.
Old Apr 24, 2010 | 04:38 PM
fsttyms1's Avatar
Go buy a new filter. You can change it out and the only oil you will lose is whats in the filter. Just top it off if low.
Old Apr 25, 2010 | 02:32 PM
dudeinaTL's Avatar
Nice. I was envisioning a nasty mess if I wasn't super quick (and I'm a slow poke with cars).
Old Apr 28, 2010 | 07:22 PM
dudeinaTL's Avatar
Came back today. Guess the oil change wasn't the [sole] culprit.
Gonna just do a full change of the oil and put conventional in - car seems sluggish with synthetic.
Old Jan 30, 2012 | 09:28 AM
StreetKA's Avatar
Have you ever find out what it was ? I have same issue i changed all coils n spark plugs cleaned egr and injectors. I even did compression test and adjust the valves. I think egr and o2 sensors are next on my list. CEL flashes at the high rpms and sometimes throws the misfire code usually its 3/4/5 cylinders but sometimes all of them. After i cleaned egr car is running much much better but something is still not right. Anyone ?
I also recently found out that my runner was cracked by cylinder #4 i replaced both runner and used all new oem gaskets.
Old Feb 18, 2012 | 05:18 PM
StreetKA's Avatar
so i found that my compression on cyl 5 & 6 was low ->> new engine
i
Mike Pilipenko
Mar 26, 2024 09:21 PM
Jamus22
Jun 11, 2023 10:08 AM
SidhuSaaB
May 30, 2020 12:40 AM
DerrickW
Nov 15, 2015 05:52 PM
Houston
Oct 8, 2015 01:27 AM
