car wont start
Old Jul 20, 2006 | 05:35 PM
CAB NEWYORK's Avatar
car wont start
how can you tell if the immobilizer is bad on the 03tl car just cranks it always started then one day just stop
Old Jul 20, 2006 | 05:47 PM
honda_inspire99's Avatar
Skeet Skeet Skeet
When u put the key in does the green key light blinks then goes off? try taking off all the other keys off the key chain and try it. Sometimes other keys with chips or other metals can affect it.
Old Jul 20, 2006 | 05:49 PM
the green lights blinks when you put the key in and 5 times when you take the key out
Old Jul 20, 2006 | 06:02 PM
fsttyms1's Avatar
does the car crank at all?
Old Jul 20, 2006 | 06:05 PM
yes it sounds like it out of gas
Old Jul 20, 2006 | 06:44 PM
fsttyms1's Avatar
so does it sputter while trying to start??
Old Jul 20, 2006 | 10:25 PM
no just sound like no gas
Old Jul 20, 2006 | 10:31 PM
thanks for the help but it still wont start just turns over
Old Jul 21, 2006 | 01:40 PM
TintemDark's Avatar
4th Gear
Did you check you fuel pump??? Fuse???? from my understanding about the immoblizer it will not even let it crank......I would check the fuel system.....
Old Jul 21, 2006 | 04:26 PM
i checked the fuse now ill check the fuel pump relay thanks anymore help if not i got to tow to the shop
Old Jul 21, 2006 | 04:43 PM
fsttyms1's Avatar
try removing the key from the key chain and see if that works
Old Jul 21, 2006 | 07:03 PM
is there any indication to let you know the key code is bad or the immoblizer is not reconizing the key
Old Jul 24, 2006 | 05:25 PM
thanks to everybody it was the fuel pump
Old Jul 25, 2006 | 05:49 PM
fsttyms1's Avatar
Yes, weather or not the key is blinking on the dash and how it blinks
Old Jul 25, 2006 | 11:02 PM
MrAlex's Avatar
99 SSM Tl
its happened with my car once .. it was the battery .. i think you already tried do boost it ..
saberlove
Mar 11, 2021 09:29 AM
Feb 25, 2020 09:57 AM
bearingman07936
Jan 7, 2016 03:22 PM
jordanboi
Sep 5, 2015 01:33 AM
NSolace
Sep 3, 2015 08:02 PM
