auto tranny question!!!
Old Jul 26, 2011 | 08:03 AM
BarryTL's Avatar
Question auto tranny question!!!
i have a 01 TL
when i drive it seems to shift fine and all good but when i let off the gas it seems to pull back. sort of like a 5 speed when your in a gear and let of the gas it will pull back a little. it does not do it really bad but i can feel it. is it just because of the sport tranny? or is it something else!?
Old Jul 26, 2011 | 10:43 AM
01tl4tl's Avatar
are you in D5? are you on a downhill when it happens (see grade logic)
hows the fluid look and smell- ever change atf?
Old Jul 26, 2011 | 10:44 AM
01tl4tl's Avatar
what about the egr system cleaning by removing intake manifold- clogged egr really messes with the engine
thats needed every 75kmiles
whats your current miles?
original trans?
Old Jul 26, 2011 | 04:09 PM
BarryTL's Avatar
yes in d5 and no not on hills just in general it does it! i have never cleaned egr and i dont know about previous owners. it has about 225k but i have the carfax and it was wel maintaned and as far as i know its original
Old Jul 26, 2011 | 06:08 PM
01tl4tl's Avatar
carfax only knows what its told
you need real info on trans fluid changes- often not done!! ever!!
warranty trans have blue paint on the bolt heads of things attached to trans on top, and the main bolts thru trans= cant miss them
Old Jul 26, 2011 | 06:10 PM
01tl4tl's Avatar
is the car new to you and you dont know how it should feel-
or its changed since you got it
egr cleaning not found in repair books- azine special knowledge!!
do that -it never hurts!!
use Regions link at top of pages to find local ziner meets and members near you-
drive another one ...
Old Jul 27, 2011 | 05:55 PM
BarryTL's Avatar
Well im going to have to look at the bolts and the car is new to me i was gonna change the atf but a friend said flushong it would possibly mess up any thing being held together inside possibly due to build up of some sort and if i did it it would add to the issue. Also now when i go into d5 it takes a min to engage!!!
Old Jul 27, 2011 | 06:25 PM
thewrangler99's Avatar
it shouldn't take a min to engage into d5. do a 3x3 drain and fill with acura oem trans fluid.
Old Jul 27, 2011 | 10:23 PM
BarryTL's Avatar
whats a 3x3? and will flushing it do anything else stupid to the tranny
Old Jul 28, 2011 | 12:53 AM
01tl4tl's Avatar
flushing with a machine would be bad- stay away from shops!!
the TL can drain and refill DIY eaiser than an engine oil change
forget your buddies, give us details and we can steer you right based on real experience.
If the trans has 100kmiles and never a fluid change- fluid is brown and smells like burnt sugar- the trans is toast and no amount of fluid is going to help
if its a replacement trans= thats better but you have severe symptoms of selenoid or somthing worse,,
get a flashing D5 light getting on freeway hard throttle?
or what happens cruising in D5 at 25 and 35 mph, stand on the gas and hold it down as it downshifts into 2nd and launches forward smoothly
or it revs and wont catch then clunks and thunks into gear
start with a fluid condition and the blue paint bolt heads
report back
do not do 3 qts 3 times = 3x3, thats not a good idea yet- need to know a few things
only half the total fluid will drain out at once, you refill and push more old fluid forward to drain, repeat,,
technically thats only to be done if you added Dextron3 to the atf, thats death fluid for our trans
Old Jul 28, 2011 | 08:38 AM
BarryTL's Avatar
My fluid looks more of a brownish clear smells like an oil not really a burnt smell at all. I cant see any blue on any bolts on tranny.
D5 never flashed that i can remember but im gonna watch for it.
I went and drove and idk it never seems to shift bad . And i just went for a ride and seems the first ride of the day or first few d5 takes no time at all to engage..
I seem to shift fine the only time it will a little hard is when i romp on it. But i neer feel a slip and im always watching the rpms!
Old Jul 28, 2011 | 10:10 AM
01tl4tl's Avatar
that fluid is bad for sure,,
burnt sugar is a death sign so thats good news to not find!!
but color is supposed to be reddish,,brown means its doing its job picking up crud
and its done its job a long long time
replace the fluid with honad dw-1 and replace the external atf filter
SS mode may help it shift if it gets stubborn- ss increases line pressure and can force the engagement
Old Jul 28, 2011 | 10:11 AM
01tl4tl's Avatar
quit romping on it for now- until you get the fluid sorted out etc
just putting the severe hurt on it driving hard with an issue present~
Old Jul 28, 2011 | 11:37 AM
BarryTL's Avatar
Yea i can see the redish in the fluid! But im almost positive no burnt sugar smell!
So do i go to dealer for the fluid? Any specific way i should change the fluid since people are telling me not too lol! And i barley romp on it just for testing it more less i baby her! Im just trying to avoid a new tranny lol!
Thanks for all the info so far! Let me know my next step
Old Jul 28, 2011 | 11:39 AM
BarryTL's Avatar
And what is ss mode Im new to a tl sorry
Old Jul 28, 2011 | 12:11 PM
01tl4tl's Avatar
register with owner.acura.com and access the free owner operation book
register with acura care 1 800 382 2238x5 and ask if all recalls are taken care of
SS mode is the left section of the shifter- allows manual control of shifting up and down
buy 4 qts honda dw-1 at honda dealer
remove filler plug on top of trans
remove drain plug on bottem rear of trans- clearly marked and uses a 3/8" breaker bar or ratchet to fit into square cutout in plug- cant miss it, even says ATF above drain!
between 3 and 3.4 qts will drain out, refill with same amount- MEASURE removed fluid!
low or high fluid level messes up the trans
drive and see how it does before trying a full capacity changeout right now,
thats the 3x3= 3 qts 3 times, and is for a special reason
Old Jul 28, 2011 | 02:30 PM
BarryTL's Avatar
so i will drain it measure what came out and replace the same amount!? i can do that! and if its all set i dont have to do the 3x3 but if not then i will do the 3x3? just making it clear for myself!
thanks for all the help so far i will let you know what happens when i do this and keep you posted and i will register now!
Old Jul 28, 2011 | 02:48 PM
BarryTL's Avatar
Concerned about safety? So is Acura. That's why My Acura provides up-to-date recall information about your vehicle. Because My Acura recall listings are based on your Acura's Vehicle Identification Number (VIN), they are specific to your vehicle.
(This is an electronic version of the letter that will be mailed to you. Please wait until you receive the actual letter before contacting your dealer.)
Your 2001 Acura is included in the 1999-2003 3.2TL; 2001-2003 3.2CL Automatic Transmission Warranty Extension Campaign.
Description
Type Recall Customer Letter
Status Open
Your 2001 Acura is included in the 2001-2003 3.2CL; 2000-2003 3.2TL; 2004 TL Automatic Transmission 2nd Gear Campaign.
Description
Status Fixed
this is what that site listed.. but for the extended i have to many miles it says 7 years 100k
Old Jul 28, 2011 | 03:37 PM
01tl4tl's Avatar
yeah thats the standard notice-
recall= oil jet kit installed = fixed
and `open` on the extended warranty means `In vin range`,,but of course over the 7 year 9 months limit so tough luck now
Old Jul 29, 2011 | 08:24 PM
BN3DC2's Avatar
sir, how do i find out about up-to-date recall information? i have 03 acura tl-s...thanks!
Old Jul 30, 2011 | 12:33 AM
03tl-s04mdx's Avatar
Register as the current owner at www.myacura.com - you'll need your VIN.
Old Jul 30, 2011 | 11:14 AM
01tl4tl's Avatar
that site doesnt always have the most current info -despite being the website!
usa cars call 1 800 382 2238 x5
canada cars 1 888 9acura9
thats `acura care` and has all your cars recall and warranty info
Yikes
May 3, 2021 04:29 PM
mugen_kid
Nov 13, 2015 10:38 PM
Junior Noboa
Sep 21, 2015 06:28 PM
datadr
Sep 12, 2015 09:12 PM
HeloDown
Sep 8, 2015 06:51 PM
