Intake Resonator
Intake Resonator
Probably a stupid question but want a definitive answer; I removed the large intake resonator box as one of my first mods but as I was tinkering with something yesterday came across what appears to be a u-shaped additional resonator. Curious if once removed if I need to replace it with a cap of any sort or is it safe to leave open? Thanks in advance.
I've had the intake resonator mod done for about a year and have had no performance issues period. I also haven't questioned why anyone else has done what they've done to their car and am only expecting a simple answer in return. Thanks for your input however.
Of course you will lose power removing the U-shaped resonator without capping it. You're basically running no intake tubing at all, and just sucking in hot engine bay air. You're also bypassing the filter and putting your engine at risk.
The resonator box in the fender does accumulate moisture over time but I'm not sure if it's supposed to by design. There was a small amount of water inside when I removed to install my AEM CAI.
And you know this because? I ask because manufacturers go to great lengths to tune the intake resonance for optimal volumetric efficiency; if you remove the resonators, then you eliminate that performance boost.
psengsouriya
Apr 13, 2008 06:09 AM
