Megan Header Install Question
Old Oct 21, 2019 | 01:35 PM
Marsalis Simms's Avatar
UA7_Unknown
Wasn’t able to find any specifics online as Megan discontinued making these. However, I am curious if I should reuse the OEM gaskets on my 00 TL? I know brands like DC just used the OEM and didn’t supply one to my understanding. Also curious if there are any other additional gaskets Megan supplied with the headers/flex pipe that I should pick up/be aware of. Thanks in advance.
Old Oct 22, 2019 | 06:23 PM
Karanx7's Avatar
Unregistered Member
Should be pretty similar.
Old Oct 22, 2019 | 08:00 PM
UA7_Unknown
This is incredibly helpful. Thank you very much for this info.
Old Oct 25, 2019 | 03:33 PM
UA7_Unknown
Having trouble finding them online, anyone recommend a site to order the 2 1/4 compression gaskets?
Old Oct 25, 2019 | 04:40 PM
2.25 in=57.15mm
Closest to 57.15mm is #17 on the link below?
Or search that part # to see if a local to you auto parts store has them in stock?
https://www.acuraoemparts.com/v-2000...--exhaust-pipe
Old Oct 25, 2019 | 04:53 PM
UA7_Unknown
Originally Posted by zeta
2.25 in=57.15mm
Thank you. I will check right now.
Old Oct 27, 2019 | 01:01 PM
UA7_Unknown
Checked a few local auto places and none of them had them in stock. Will wait if I have to and order from that site, but was curious if I could reuse whatever gaskets are on the stock j pipe?
Old Oct 30, 2019 | 01:51 PM
Chojun's Avatar
I had to drop my exhaust to reseal my oil pan and re-used the gaskets. While it's probably not the best thing to do I don't notice any change in exhaust so I assume you're good to re-use them if they're in good shape. With that said I plan to replace them sooner than later.
Old Nov 2, 2019 | 03:48 PM
UA7_Unknown
Tried lining up the headers with the downpipe and it appears at each flange, all 3 bolts dont appear to want to line up 100% to where one bolt wont go through. Anyone else had this issue or is there a quick fix without cutting/welding the flange back on the downpipe?
Old Nov 2, 2019 | 04:36 PM
If you have the headers already tightened to the exhaust heads, you may have to loosen them to get each flange to line-up with the downpipe.
IIRC'ly, when I installed my CT-Engineering CLS6 headers, back in the day, I followed the advice of the guy below:
Originally Posted by ChadT
One other thing I didn't pay attention to was the fact that you DO NOT TIGHTEN ANYTHING until all the bolts are in and everything is lined up. I tightened the A-pipe to the cat and it made it a bitch to get it to line up with the headers, then the next day I noticed my exhaust was crooked so I had to loosen those bolts and re-align everything.
Once '...all the bolts are in...', tighten the headers to the exhaust heads, then tighten bolts at the down pipes, then tighten A-pipe to the cat. Everything worked out great and there where no leaks. The fitment of the CT headers were spot-on once assembled, though. Not sure how the fitment is with Megans. You may have to play around (adjust) as you see fit to get them on with no leaks.
AMGala
Jun 24, 2009 05:57 PM
nap76
Apr 8, 2007 02:33 AM
ChucksCL-S
Sep 6, 2002 08:23 PM
