02 tl s mufflers
Old Dec 17, 2015 | 01:25 PM
justin676's Avatar
02 tl s mufflers
I'm looking for an inexpensive set of mufflers that will bolt right up and give me a little better sound. Does anyone know of any that work well? Maybe a little less restrictive and that look good. Let me know thanks
Old Dec 19, 2015 | 12:41 AM
justin676's Avatar
Is the 02 accord exhaust fit on a tl? As far as cat back? It looks similar and the aftermarket for the accord is way bigger! But I'm not convinced enough to buy. Anyone know?
Old Dec 20, 2015 | 11:07 AM
Groovemaster's Avatar
I have the Tsudo axelback setup, but you will need to mod your mid pipe to get a better sound, I removed my mid muffler and replaced my cat and resonator with free flow versions. My car sounds about the same as a 370Z or G37 now, very subdued at idle, very pronounced at WOT.
Old Dec 20, 2015 | 06:25 PM
03-6/6's Avatar
M90booosted
comptech mufflers if you can find them. i found a set in the jy last week.
or tsudo's are good too.
Old Dec 21, 2015 | 06:48 PM
justin676's Avatar
I don't want to mess with the cat. I did notice a difference from my headers but I just want to free up some of that throaty sound that is muffled. Tsudo system is great but would be a little too far out of my price range. If a resonator delete would get me where I want to be I could do that but if after market mufflers for less that $200 would give me the same results I'd prefer doing that.
Old Dec 22, 2015 | 08:52 AM
You won't find any "New" mufflers for that price, unless they are generic, and unless you weld, you will have to pay a shop to install them. I originally had a straight pipe (rear and mid muffler delete), it had a drone and I didn't think it sounded very good inside the cabin. What I have now I like very much, but everyone has a different opinion of "what sounds good". I have a deep rumble, but not loud, with normal driving. At WOT, when the Vtec kicks, it gets louder, but not obnoxious. You could have a shop pull your rear cans and install pipes with tips, you will be louder, I think there are some sounds clips on here with that setup.
Old Dec 26, 2015 | 07:57 PM
justin676's Avatar
Is the cat back systems for the 3Rd generation tls the same as the 2nd gen? It looks very similar but I want to be sure
Old Dec 27, 2015 | 08:15 AM
Absolutely not.
Old Dec 27, 2015 | 03:12 PM
02tl-p's Avatar
Just do what skirmich did and do an axleback straight pipe. Look up his thread under "my straight pipe sound". It sounds nice. I'm planning on doing it to my tl. I had to find a guy that does custom exhaust because there is t a shop around me that does the custom bend. It also should be cheaper then any name brand mufflers.
Old Dec 27, 2015 | 03:13 PM
justin676's Avatar
Alright I'll check it out.
eaglesfan398
22
Mar 16, 2017 10:21 AM
lltfly
Jan 22, 2016 06:10 PM
eaglesfan398
Dec 5, 2015 04:57 PM
cauraLT101
Nov 30, 2015 08:55 PM
CL721
Nov 20, 2015 12:56 PM
