Transmission performance
I just had the oil jet recall performed on my 2000 TL. I must say I actually notice a difference. Seems to shift better in all gears and pick up speed better. I dont know why but I definately can feel a difference and some fuel econemy improvement. I also have less vibration at high speeds
i dont know how you are feeling any thing, its just a little tube that sprays tranny fluid on the 2nd gear shaft. thats all it does
Didn't notice anything when I had it done.
I did notice an improvement when I flushed my tranny. They don't even change your tranny fluid for this service bulletin.
Yeah. Where the oil fill plug for the transmission is, in lieu of the plug itself, you will now see a hose leading up to the jet shown above.
The bracket is secured to an existing bracket and screw.
The fill plug for the tranny is located behind the throttle body.
fla-tls,
You have the lastest designed transmission, the oil jet kit is internal instead of external. I just went through this with my new transmission and my Acura dealer confirmed this.
I was surprized to notice a difference. is it possible they adjusted something. This tranny was replaced at 94,000 miles under the recall and I didnt really notice a problem but now after the oil jet kit I nitice better performance. What else could it be? Its not mind over matter
Do you guys think that we (99TLers) should need this? I have a 99TL that has around 55k miles, and alot of ppl hade thier trannys go out at around 60 -65k miles. I am so worried!!!
if you can do it, and its for free, then do it. If its cheap, then do it - I seems easy to do.
I think its mind over matter.
Like I mentioned earlier, I undoubtably noticed a difference when I flushed the tranny. I noticed nothing with the jet kit install.
People seem to be reacting like the "jet kit" puts a jet engine in your car or something.
Has anyone done this mod yet?? lol....
SidhuSaaB
05-30-2020 12:40 AM
joflewbyu2
10-08-2015 11:16 AM
09-17-2015 09:01 PM
