Transmission performance
Old Oct 10, 2004 | 06:38 PM
I just had the oil jet recall performed on my 2000 TL. I must say I actually notice a difference. Seems to shift better in all gears and pick up speed better. I dont know why but I definately can feel a difference and some fuel econemy improvement. I also have less vibration at high speeds
Old Oct 10, 2004 | 07:09 PM
shawn744's Avatar
Kollage is funn!
i'm glad that's workin out for you, but when I go in next month, im specifically requesting a new PCM, and if i can get a new tranny, that too....
Old Oct 10, 2004 | 07:11 PM
fsttyms1's Avatar
i dont know how you are feeling any thing, its just a little tube that sprays tranny fluid on the 2nd gear shaft. thats all it does
Old Oct 10, 2004 | 08:15 PM
spl1011's Avatar
Didn't notice anything when I had it done.
I did notice an improvement when I flushed my tranny. They don't even change your tranny fluid for this service bulletin.
Old Oct 10, 2004 | 08:20 PM
fsttyms1's Avatar
they dont need to, the jet kit goes into the tranny fluid fill hole. i would recomend if you bring it in for the jet kit to have them flush the tranny when they put the kit on
Old Oct 10, 2004 | 08:23 PM
fla-tls's Avatar
On the way!
fsttyms1, is there a way of looking the transmission externally to see if the oil jet kit update has been done?
Old Oct 10, 2004 | 08:34 PM
spl1011's Avatar
Yeah. Where the oil fill plug for the transmission is, in lieu of the plug itself, you will now see a hose leading up to the jet shown above.
The bracket is secured to an existing bracket and screw.
The fill plug for the tranny is located behind the throttle body.
Old Oct 10, 2004 | 09:17 PM
Beeza's Avatar
1 B3AKOHE
After my car came out of service and they installed that oil jet, now when i accel my car starts to peel out in second gear.lol Its hot.
Old Oct 10, 2004 | 09:29 PM
fla-tls's Avatar
On the way!
spl1011, this is a pic of the filler plug on the new tranny. If what you wrote is correct, then they didn't actually install the oil jet kit?
Old Oct 10, 2004 | 09:44 PM
Southern's Avatar
fla-tls,
You have the lastest designed transmission, the oil jet kit is internal instead of external. I just went through this with my new transmission and my Acura dealer confirmed this.
Old Oct 10, 2004 | 10:45 PM
fla-tls's Avatar
On the way!
Thanks, Southern. I feel better now.
Old Oct 11, 2004 | 04:07 PM
I was surprized to notice a difference. is it possible they adjusted something. This tranny was replaced at 94,000 miles under the recall and I didnt really notice a problem but now after the oil jet kit I nitice better performance. What else could it be? Its not mind over matter
Old Oct 11, 2004 | 04:13 PM
Ianbiz3's Avatar
Do you guys think that we (99TLers) should need this? I have a 99TL that has around 55k miles, and alot of ppl hade thier trannys go out at around 60 -65k miles. I am so worried!!!
Old Oct 11, 2004 | 05:07 PM
spl1011's Avatar
if you can do it, and its for free, then do it. If its cheap, then do it - I seems easy to do.
I think its mind over matter.
Like I mentioned earlier, I undoubtably noticed a difference when I flushed the tranny. I noticed nothing with the jet kit install.
People seem to be reacting like the "jet kit" puts a jet engine in your car or something.
Has anyone done this mod yet?? lol....
Old Oct 11, 2004 | 05:22 PM
fsttyms1's Avatar
i think its in your head, there should be no performance gain from it
SidhuSaaB
May 30, 2020 12:40 AM
joflewbyu2
Oct 8, 2015 11:16 AM
tristann616
1/2G MDX (2001-2013)
Sep 22, 2015 11:40 PM
ROSSARONIE
Sep 22, 2015 11:46 AM
Sep 17, 2015 09:01 PM
