Ticking TL. Video link.
Hello everyone again. I was just trying to get a feel if this idle noise seems normal for my TL.
https://youtu.be/wAKX8TSvC2w
it seems to go away when you accelerate but it might just be speeding the noise up and drowns itself out. Sounds like it's coming right from the engine. Definitely appreciate the help from this group!
Thanks!
Thanks!
In that case, I would call around and see if a mechanic will look at it for cheap before you open it up. A good trained ear is worth it. It's usually also worth the diagnostic fee to figure out an engine knock like that.
yeah i have someone I can bring it too. I've been trying to do it on my own to see how much I can do. Just had to open up and fix that air/water mixing valve that was stuck and in the middle of fixing the evap canister but this seems a lot more of an issue. Hopefully it's not too big.
Davius (04-15-2021)
It's not engine knock. It could be a loose intake valve. Have you made sure it's not your purge control solenoid? That's a common ticker, but it's next to the brake master cylinder.
This is what rod knock sounds like in a J engine:
https://www.youtube.com/watch?v=5VPPxRH2xL4
I haven't checked anything yet at all. Was just trying to check where I should start looking. I will look at those valves and see if I can find what's up. Thanks for the insight.
CenturionTL
08-15-2020 09:53 PM
btak49
10-18-2008 07:59 AM
