fuse issue?
Old Apr 2, 2011 | 06:55 PM
Vman159's Avatar
fuse issue?
Okay so on the odometer on my 02 TL both right and left turn signal(lights) do not blink or do anything. It happened today. can someone help me so i can resolve this today. Appreciate it
Old Apr 2, 2011 | 07:24 PM
Karanx7's Avatar
Unregistered Member
I don't think it's a fuse problem if the rest of the cluster is working. It might just be a strong current causing the bulbs to burn out. Easy enough to check for the bulbs burning. There are three bulbs for the ODO and two bulbs for the turn signals.
There are three green connectors that attach to the cluster. Make sure those are connected properly.
Old Apr 2, 2011 | 08:14 PM
Vman159's Avatar
well heres the thing they dont work on the outside either (neither front or back for both sides dont shine/blink)
Old Apr 2, 2011 | 09:45 PM
Vman159's Avatar
I changed the (10) turn lights fuse and still no luck
Old Apr 2, 2011 | 10:30 PM
01tl4tl's Avatar
bulbs ok? try new one and see if that cures it
When the outside lights dont work- the inside indicator wont light either
If a turn signal bulb on one corner is out - it usually makes that side blink super fast on remaining bulb-- to alert you to a problem--,,,`say whys that arrow flashing so much`??
Old Apr 2, 2011 | 10:36 PM
Vman159's Avatar
ill check it out. but how is it possible that all turn signals dont work, they should still be working in the rear, correct???
Old Apr 2, 2011 | 10:41 PM
Vman159's Avatar
could it be a relay and if possible where can i find it in the car?
Old Apr 2, 2011 | 10:50 PM
Karanx7's Avatar
Unregistered Member
It might be a connection issue. Did you work on your electrics recently?
When I was installing my reverse glow gauges, I had my Hazard button disconnected. While that was disconnected, my signals didn't work.
Did your odo go out at the same time as your signals? I don't think the odo depends on anything but the cluster, so those might be burnt bulbs.
Turn signals are probably a fuse or something.
Old Apr 2, 2011 | 11:16 PM
Vman159's Avatar
The only thing i did was install a new license plate bulb. Nope my odometer was/is working fine..
Old Apr 2, 2011 | 11:21 PM
Vman159's Avatar
also my bulb burnt out on the a/c off display button. and i did remove the trim. where is the hazzard button disconnect
Old Apr 3, 2011 | 12:08 AM
Karanx7's Avatar
Unregistered Member
When you removed the trim, you had to disconnect the hazard button connector. You probably forgot to reconnect it when you put the trim back.
99% that's your problem.
Old Apr 3, 2011 | 12:34 AM
Vman159's Avatar
I did connect it but turns out not good enough. thank you so much problem fixed by the way i want to post pics of the new finished tl but the weather just sucks
Acura9915
Feb 24, 2020 01:27 PM
01CLOwner
Oct 9, 2015 01:07 PM
lovic87
Sep 15, 2015 06:07 PM
Soul_Deamon
Sep 7, 2015 04:25 PM
drewdeezy03
Sep 3, 2015 08:04 PM
