Check Engine Light?
Old Aug 2, 2002 | 01:02 PM
nicholasomer's Avatar
Exclamation Check Engine Light?
My check engine light came on about two weeks ago but nothing seems to be wrong. What do you guys think?
Old Aug 2, 2002 | 04:41 PM
I know that for the 99 TL, there is an EGR recall that will fix this.
Larry
Old Aug 2, 2002 | 05:28 PM
what is EGR?
Old Aug 2, 2002 | 06:07 PM
Exhaust Gas Recirculation. They installed a new "kit" in my 99 TL, and the Check Engine Light stayed off. A side effect of this problem was that the Traction Control System light would also come on, even though it seems to be unrelated to EGR. I have read of at least one other cause of check engine light on; not keeping the gas filler cap tight enough.
Old Aug 2, 2002 | 08:23 PM
Bitium's Avatar
Retired MOD
Re: Check Engine Light?
Go by the dealer and get it check. Is possible that it is the EGR clogged, which there is a fixed with a recall already mention. It could also be your tranny! I had the engine light come on last week for transmission failure, but I had acura reset it and is running fine.
Old Aug 4, 2002 | 02:09 PM
fla-tls's Avatar
On the way!
The check engine light can even come on because of a loose gas cap. Go to the dealer and get the codes read. They'll tell you what went wrong (if anything).
Old Aug 5, 2002 | 11:33 AM
songoku's Avatar
BlingBling INSPIRE 32V
You don't want to drive the car too long with Engine Check lights on.
Take your car to the dealer ASAP!!
Old Aug 5, 2002 | 11:46 AM
bigman's Avatar
'Big Daddy Diggler'
I am having the same problem with my check engine light coming on and traction light coming on, on my 99. Can a clogged egr hurt performance, because on the highway my car is a pig sometimes.
MikeYutkin
Sep 10, 2015 10:13 PM
Bahamanurse1
Sep 10, 2015 10:05 PM
HeloDown
Sep 8, 2015 06:51 PM
bryan zaragoza
Sep 8, 2015 12:28 AM
whitesoxsfan12
Sep 7, 2015 04:07 PM
