Car feeling sluggish? It might be your battery
Old 08-26-2010, 11:57 AM
NSXNEXT's Avatar
Received 1,080 Likes on 661 Posts
So I'm going on god knows how many years on this battery.
Was getting gas Monday and left my lights and radio on while I filled up.
Jump into car...click....click....click
Get a jump and I'm on my way.
Then I'm talking to a car buddy here at work and told him what happened.
He read that performance suffers with a battery that is going bad.. I said hmmm that's funny because I've noticed the car not being as peppy as before.
Install a new battery and WOW!!! it's like a new car.
Easiest thing to do is check voltage when engine off, during starting, and while running and see if there is a big variance.
Old 08-26-2010, 02:58 PM
ballpast1's Avatar
I noticed that the subwoofer was even a tad louder after putting my battery in too. I also cleaned off and inspected my grounding straps while putting in the new battery
Old 08-26-2010, 06:33 PM
01tl4tl's Avatar
Received 1,137 Likes on 1,067 Posts
good job!
the battery actually runs all the electrics on the car, people dont understand--
the alternator only replaces the juice used from the battery
drive it for 45-60 minutes to fully charge the new battery- it wont be full after sitting on the shelf
Then go back to parts store and have a system ck
to be sure the alt is ok--having done extra workload covering for a weak battery
Old 08-26-2010, 09:54 PM
'12 & '13 AL West Champs!
Gfaze's Avatar
One thing I'd like to point out is that when your battery starts to seep out acid all over the place and your terminals begin to develop corrosion, just replace the battery because it's the beginning of the end. Plus you'll save yourself the headache (and money) of having to also replace the battery cables due to corrosion damage.
Old 08-27-2010, 01:58 AM
02TL4ATL's Avatar
interesting, I need to replace my battery to, it dies every time i leave the radio on for more than 5-10 mins. hopefully my tl will be more peppy when i change the battery.
Old 08-27-2010, 02:17 AM
Gfaze's Avatar
Your battery is toast. Get a new one ASAP. A weak battery puts a strain on the alternator because it has to work harder to keep the car running. Get a battery before you have to get an alternator along with it.
EDIT: I've got this one and it works great!
http://www.kragen.com/ProductDetail....e=5005&PTSet=A
Old 08-27-2010, 05:16 AM
02TL4ATL's Avatar
alright ill try to get a new batter asap.
Old 08-27-2010, 08:07 AM
It's the Halladay season!
hANDYcaptd's Avatar
And also when it dies, being stranded finding someone to help you get a jump.
Old 08-27-2010, 10:00 AM
01tl4tl's Avatar
I will repeat for all
at all cost!! avoid jump starting a dead TL--get the battery quick charged for an hour at parts store at least- that will help
a dead battery WILL overburden the alternator and shorten its life,,might get another month,,, or year,,,, but that thing took a hurting
especially if you drove home an hour from the hills with battery/charging light on
Running off the alternator output alone for the whole time...(shaking head)
Old 08-27-2010, 10:03 AM
01tl4tl's Avatar
10 year old battery cables are ready for replacement- ck the resistance in them!
if you run big tunes- they are even more important,
suggest upgrade to larger wires (lower number guage) to handle the constant heat thru them
02-25-2020 09:57 AM
gemz_acura
4G TL Problems & Fixes
15
09-26-2015 06:12 PM
Phambam12
09-06-2015 06:57 PM
jordanboi
09-05-2015 01:33 AM
chrisr
5G TLX Problems & Fixes
08-31-2015 08:24 PM
Quick Reply: Car feeling sluggish? It might be your battery
