Big problem need some help/input
Old Aug 26, 2010 | 11:15 PM
mmendelzon's Avatar
So recently i have heard a knocking and screeching noise on my front passenger side so i check and saw i needed a new tie rod i got that changed and noise is still there so then i lift the car up ad no noise but assooon as the car is on the ground and there is pressure on the wheels i turn the steering wheel all the way to right and here a screech like something is grinding.So took it to my mechanic and he could not find the problem but realized all my bolts on my frame were VERY loose so he tightened them. So today ride was perfectly smooth though everything was fixed until 25 miles into the day i hear the noise again! My guess bumpy ride knocks bolts off???? HELP
Old Aug 27, 2010 | 02:22 AM
Gfaze's Avatar
S E L L
Take the car to a front end/suspension shop, not a general mechanic. They should be able to perform a more thorough inspection. Have them drive the car so they can hear the noise themselves.
Old Aug 27, 2010 | 10:12 AM
Tom Blasing's Avatar
is the Mighty Favog
A very long time ago my brother had a 71' Plymouth Roadrunner (yes, it was purple) and the idler arm had been loose for a long time even before he bought the car.
The steering wheel would shake violently sometimes (manual steering). By the time he figured out what the problem was the threaded hole in the frame for the idler arm had been elongated so bad it wouldn't even tighten up anymore.
Hopefully that's not what's happening to your TL.
Old Aug 27, 2010 | 10:30 AM
NSXNEXT's Avatar
That's just "Plum Crazy" Do you see what I did there?
Old Aug 27, 2010 | 11:08 AM
01tl4tl's Avatar
mm--what bolts were loose? the steering rack- the pump- the entire right control arm?
Old Aug 27, 2010 | 12:52 PM
is the Mighty Favog
Close!
Dodge's color was called Plum Crazy but Plymouth's was called Violet.
The bottom line is though they are the same color.
Old Aug 27, 2010 | 03:25 PM
mmendelzon's Avatar
i dont know what parts were loose but Ihave been looking it up and some pl have said possible strut mount? the noise disappears when the car is on a jack soo still have no idea?
Old Aug 27, 2010 | 07:23 PM
mmendelzon's Avatar
could it be my lower ball joint?
cycdaniel
Dec 17, 2019 10:58 AM
Aug 15, 2019 12:58 PM
CheeseyPoofs McNut
Oct 11, 2015 11:25 AM
Junior Noboa
Sep 21, 2015 06:28 PM
brandnewcolony
Sep 12, 2015 10:39 AM
