6 speed conversion, 2nd problem 9/2/17
Old 05-19-2006, 10:37 PM
  #641
I need 2 more gears
sbuswell's Avatar
pics pics pics! PLEASE. Have you driven it yet and does it go past 2k now? I bet your car is lighter now. So you got a CAI, now H/P/E and you will be in the 13's man.
Old 05-20-2006, 08:55 AM
  #642
On the way!
fla-tls's Avatar
Originally Posted by fsttyms1
... Right now for some reason it doesnt want to go above 2k rpm with out a revlimiter kicking in
Sounds like the VSA system in the new ECU?
When I first dyno'ed my car, I forgot to turn off VSA and the car wouldn't go above 2-3k RPM. Turned off VSA and had no problems. Maybe it's not getting the 4 channel speed signals that it needs (as opposed to the 3 channel TCS system).
Old 05-20-2006, 04:52 PM
  #643
05 C230K & 09 135i 6MT
03CoupeV6's Avatar
No VSA on 6MT CL-S, which is what his ECU is from.
Old 05-21-2006, 06:07 PM
  #644
GreenMonster's Avatar
Kris, I can't believe that you got the hood closed
In your picture thread you said you've got a 1/2 inch of clearance w/o the plastic covers and hood liner... I guess that's just minor details tho'
Getting it road ready is the first thing, then getting the fit and finish stuff can be done as you have time...
Great job !!
Old 05-21-2006, 09:36 PM
  #645
fsttyms1's Avatar
Received 3,063 Likes on 2,119 Posts
Originally Posted by blk2001tlon19s
cool kris.....I know you said you tried it wouldnt rev pass 2k however did you try to move the car or drive it out your garage? congrats on the progress so far. did you need me to send you my scanner or are you going to buy one?
It drives great. Shifts great, but its in a limp mode. Need to get it to get scanned this week when i get home from out of town
Originally Posted by GreenMonster
Getting it running is a BIG step forward... but now you get to tackle of those little details
Yep working on it as we speek
Originally Posted by ITL
truly impressive...can't wait to see some more pics. congrats, man
soon
Originally Posted by Phrosttz0
1 word awesome, this means you should have it up and runnign by the end of next week?
Hopefully
Originally Posted by blokhead
That is awesome.... Do you think it may be one of the new sensors you put in? Sounds like a limp home mode of the ECU. How much did honda charge you Kris?
?? i dont think so. i think its something to do with the IAC and cooling related. The honda dealer charged me 42 bucks!!
Originally Posted by Jack_n_Coke
Now dont go crazy with that six speed and the TL-S motor, I have heard its a deadly combo .
Nahhhh..
Ill Get them as soon as there is something good to take. Interior is only partially complete no headers yet but soon
No VSA on the CL-6 maybe its something to do with TCS???
Great job !!
Yea the hood closes with the engine cover and doesnt rub (so far) Its almost road ready. hopefully this week the honda dealer can get me in and plug it in to see whats up and what codes they come up with so i can address them. I got the windows figured out. The locks im going to go aftermarket alarm system/set up for them to work (much easier to work with) As soon as i get home ill be addressing them. then ill get the interiorslapped back together and get some pics
Old 05-21-2006, 10:35 PM
  #646
318whp/289wtq @ 6psi
blk2001tlon19s's Avatar
If you need me to send you my scanner tool since I'm not using it, let me know.
Old 05-22-2006, 09:08 AM
  #647
On the way!
fla-tls's Avatar
How did you measure the hood clearance (sorry if it's earlier in the thread). Did you put putty on the intake and close the hood to see how large the gap was?
Old 05-22-2006, 09:25 AM
  #648
fsttyms1's Avatar
Old 05-22-2006, 09:27 AM
  #649
fsttyms1's Avatar
I covered the whole IM with shaving cream about 1 inch thick then put a piece of saran wrap on top of it and closed the hood, then reopened it and saw the high and low spots.
Old 05-22-2006, 09:57 AM
  #650
On the way!
fla-tls's Avatar
Nice! Good thinking!
Old 05-22-2006, 11:07 AM
  #651
fsttyms1's Avatar
Yea that happens with me from time to time
Old 05-22-2006, 01:24 PM
  #652
fsttyms1's Avatar
Dont mind the mess. Its a little dirty.
the inner part of the center console
after i modified it to fit the new cupholder. I still need to clean it up and modify the rear heat ducts.
Needed a shifter so i drilled out the stock one to fit the new manual shaft.
Parking brake
more of the dash and cluster (i now have 16k miles on the car )hahaha
Old 05-22-2006, 01:40 PM
  #653
RickRoush03
RickRoush03's Avatar
its coming along nice and slow! did you figure out the not revving past 2k yet?
Old 05-22-2006, 02:48 PM
  #654
fsttyms1's Avatar
Nope its going to the dealer again wed, and me and a tech are going to try to figure out a few things while its hooked up to their computer. I just thought id throw in those pics to help tide some of the restless ones (cough cough blk2001tlon19s) over for awhile. If i had the windows and locks working (just need the time to run a few wires) id have the interior all put back together.
Old 05-22-2006, 03:35 PM
  #655
I'm going to send you my center console man, is that ok?
Old 05-22-2006, 03:40 PM
  #656
Kris, I forgot to mention. PM Richie v6, he has the 6 speed swap on his accord with a j30a1 motor. He used his stock ecu(to my knowledge) and had an issue with not being able to go past a certain rpm. Might have been 2k. It fixed it, not sure how so he might be able to point you in the correct direction also. Good luck with that also.
Old 05-22-2006, 04:01 PM
  #657
FISHYTL's Avatar
Whats that hole next to the cruise control button?
Old 05-22-2006, 04:13 PM
  #658
fsttyms1's Avatar
that was probably from the ECU not seeing the auto tranny or gear positon. Ill see what they say wed and then work from there.
Old 05-22-2006, 04:14 PM
  #659
fsttyms1's Avatar
I had a toggle switch there for the indaglo gauges to turn them off at night so just the needles lit up
Old 05-22-2006, 05:16 PM
  #660
Mike_McCready's Avatar
These pictures make me incredibly jealous, hope you figure out the 2k problem soon
Old 05-22-2006, 06:58 PM
  #661
njzprettyboy's Avatar
amazing!
Old 05-22-2006, 07:25 PM
  #662
GaryBear's Avatar
I see your water temp gage is where mine always is, one notch below center. Stays there no matter what the outside temp is or how I drive the car.
Old 05-22-2006, 08:11 PM
  #663
fsttyms1's Avatar
Yea thats the old motor. That thing wouldnt move if the car was ideling all day in 110 deg weather.
Old 05-22-2006, 09:25 PM
  #664
FISHYTL's Avatar
mine is the same way
Old 05-23-2006, 09:16 AM
  #665
georgy_d28's Avatar
Did you leave the cat conv. off? could that be why its not going any higher, cuz there is no signal from the o2 sensor? or am i completely off
Old 05-23-2006, 09:59 AM
  #666
fsttyms1's Avatar
Cat is on. every thing is conected the way its supposed to be. There is a sensor that is causing it. Ill have to wait till tomorrow till they plug it in for me before i know.
Old 05-23-2006, 01:37 PM
  #667
almost done. suite
Old 05-24-2006, 02:40 PM
  #668
I need 2 more gears
sbuswell's Avatar
update us, is it fully operational now? please tell us how she drives.
Old 05-24-2006, 03:18 PM
  #669
kris!!!!!!!!!!! ...anyway, did you happen to take it too the dealer? If so, any good news?
Old 05-24-2006, 03:26 PM
  #670
fsttyms1's Avatar
Man you guys are ruthless. you just cat wait can you.
Well its coming up with 3 codes.
P0336 CKP sensor 1 -range
P0386 CKP sensor B-noise
P0141 HO2S2 heater
I need to figure the top 2 out to run normal.
Old 05-24-2006, 03:31 PM
  #671
That's right. can't wait
Never seen those codes before.
Old 05-24-2006, 03:33 PM
  #672
Blue_TL's Avatar
Ok. Figure that shit out and get back to us in 15....chop chop!
Old 05-24-2006, 03:37 PM
  #673
fsttyms1's Avatar
Ok i discovered that teh maunal motor also has a different timing belt pulley. Just ordered that. As far as the noise on CKP b ??? Im going to wait till i get the other one reading right. I may pull it out and look at it and see if its fully conected.
not worried about the O2 sensor (as im going ot buy a o2 emulator)
Old 05-24-2006, 05:14 PM
  #674
ITL
I do my own work.
ITL's Avatar
and what is an O2 emulator? educate me
Old 05-24-2006, 05:58 PM
  #675
fsttyms1's Avatar
it tricks the computer into thinking that the O2 sensors are working and every thing is the way it should be (for like when you dont have a cat
Old 05-24-2006, 06:12 PM
  #676
You want mine since I'm not driving my car and I'm not going to use it?
Old 05-24-2006, 06:13 PM
  #677
Different timing belt pulley? Wonder if I'm going to have to use that also. Thanks for the heads up.
Old 05-24-2006, 06:35 PM
  #678
fsttyms1's Avatar
Not sure. For the manual motor ECU like im running there is a different Crank position sensor on the manual than the auto. Since your running a bunch of standalones im not sure. I ordered it (it was only 60 bucks) and hopefully that fixes teh problem. I wont know till it comes (which will probably be tuesday and ill be out of town all week)
Old 05-26-2006, 09:23 AM
  #679
fsttyms1's Avatar
Well i took the crank pulley off and the timing belt cover/ timing belt last night. Man what a pain on the car. the part comes tuesday so i should hopefully be able to get it all back together tuesday night.
Old 05-26-2006, 09:32 AM
  #680
PenancE's Avatar
boourns
Quick Reply: 6 speed conversion, 2nd problem 9/2/17
